I get the following error on an UEFI 64bit machine with secure boot disabled:
tftp://<private-ip>/linux/pxelinux.cfg/shimx64.efi.signed... ok
shimx64.efi.signed : 1191448 bytes [EFI]
dppath: shimx64.efi.signed
Fetching Netboot Image
Malformed binary after Attribute Certificate Table
datasize: ? SumOfBytesHashed: ? SecDir->Size ?
hashsize: ? SecDir->VirtualAddress: 0x0034B8A18
Failed to load image: Invalid Parameter
start_image() returned Invalid Parameter
Could not boot image: Error 0x7f048282 (http://ipxe.org/7f048282)
No more network devices
See below for more information:
Opsi server version: 4.2 on Debian 10 with opsi-server-full package installed (opsi-tftpd-hpa is installed as well)
Log file /var/log/opsi/opsipxeconfd.log:
[5] [2021-12-15 13:50:38.306] [Opsipxeconfd ] Got connection from client (opsipxeconfd.py:231)
[3] [2021-12-15 13:50:38.315] [ ] Cannot use more than one pxe config template, got: /tftpboot/linux/pxelinux.cfg/install-grub-x64, install3264 (opsipxeconfd.py:773)
[5] [2021-12-15 13:50:38.315] [ ] Did not find any alternate UEFI pxeConfigTemplate, will use the default UEFI template (opsipxeconfd.py:782)
[5] [2021-12-15 13:50:38.322] [ ] UEFI GRUB configuration detected for redacted.domain.de (pxeconfigwriter.py:146)
[5] [2021-12-15 13:50:38.326] [ ] PXE boot configuration for host redacted.domain.de is now set at '/tftpboot/linux/pxelinux.cfg/01-a4-4c-c8-14-47-67' (opsipxeconfd.py:630)
(Nothing after this, even when starting PXE on the client)
backend config dir = /etc/opsi/backends
dispatch config file = /etc/opsi/backendManager/dispatch.conf
pid file = /var/run/opsipxeconfd/opsipxeconfd.pid
log file = /var/log/opsi/opsipxeconfd.log
log level = 5
log format = %(log_color)s[%(opsilevel)d] [%(asctime)s.%(msecs)03d]%(reset)s %(message)s (%(filename)s:%(lineno)d)
pxe config dir = /tftpboot/linux/pxelinux.cfg
pxe config template = /tftpboot/linux/pxelinux.cfg/install
uefi netboot config template x86 = /tftpboot/linux/pxelinux.cfg/install-elilo-x86
uefi netboot config template x64 = /tftpboot/linux/pxelinux.cfg/install-grub-x64
max control connections = 5
max pxe config writers = 100
tftp-server: 10.10.1.1
next-server: 10.10.1.1
Standard BIOS filename: linux/pxelinux.0
UEFI 32Bit Filename: linux/pxelinux.cfg/elilo-x86.efi
UEFI 64Bit Filename: linux/pxelinux.cfg/shimx64.efi.signed
root-path: empty (I also tried using /tftpboot, but same error)
UEFI Boot: enabled
clientconfig.dhcpd.filename: linux/pxelinux.cfg/elilo.efi
Also if I enable Secure boot, I instead get the following error: "Operating System Loader has no signature. Incompatible with SecureBoot."
Any ideas how I can debug this?
