Updates opsi 4.1 / 4.2 stable und testing
News and announcements
fkalweit
Beitrag von fkalweit »
Dear opsi users,
today we have released more packages for opsi 4.1 and 4.2 in testing and stable.
Bootimage
- Better support for Hyper-V clients
- Kernel 5.13 for support of new hardware.
Debian/Ubuntu Netboot:
- Fixes an error so that the keyboard layout is now correct
### Updates in stable:
Linux Netboot:
* debian9 4.2.0.1-3
* debian10 4.2.0.1-3
* debian11 4.2.0.1-3
* ubutnu18-04 4.2.0.1-3
* ubuntu 20-04 4.2.0.1-3
* centos7 4.2.0.1-3
* redhat7 4.2.0.1-3
Linux Localboot:
* l-opsi-server 4.2.0.5-1
opsi Server:
* opsi-linux-bootimage 20210903-1 (opsi 4.1)
* opsiconfd 4.2.0.203-1
* opsi-utils 4.2.0.130-1
* ospipxeconfd 4.2.0.20-1
* redis-timeseries 1.4.10.1-1
* opsi-server 4.2.0.57-1
* zsync2 2.0.0-alpha-1
### Updates in Testing:
Windows Netboot:
* opsi-clonezilla 4.2.0.0-1
Linux Netboot:
Linux Localboot:
* l-opsi-server 4.2.0.5-2
* l-debuntu-upgrade 4.2.0.0-3
opsi Server:
* opsiconfd 4.2.0.204-1
* opsi-directory-connector 47.1-1 (opsi 4.1)
* opsi-quick-install 4.2.0.1-2:
With kind regards
Fabian Kalweit
l-opsi-server (4.2.0.5-2); testing; urgency=low
  * fixed error with l-opsi-server-quick-install
 -- Mathias Radtke <m.radtke@uib.de> Thu, 30 Sep 2021 12:00:00 +0200
opsi-clonezilla (4.2.0.0-1) stable; urgency=low
  * update drbl-2.25.10 to drbl-4.5.0
  * update from clonezilla 3.27.16 to clonezilla 4.4.12
-- detlef oertel <d.oertel@uib.de>  Mon, 06 Sep 2021 15:00:00 +0200
opsi-linux-bootimage (20210920-1) testing; urgency=low
  * using SMB vers=3 instead of vers=3.0
 -- Mathias Radtke <m.radtke@uib.de> Mon, 20 Sep 2021 14:55:00 +0200
opsi-linux-bootimage (20210916-1) testing; urgency=low
  * added wimlib
  * added hivex
  * added patch for better Hpyer-V support
 -- Mathias Radtke <m.radtke@uib.de> Thu, 16 Sep 2021 10:30:00 +0200
opsi-linux-bootimage (20210906-1) testing; urgency=low
  * Allow to process file and kernel params at once
  * made link detection faster
 -- Jan Schneider <j.schneider@uib.de> Mon, 06 Sep 2021 16:09:00 +0200
l-debunut-upgrade (4.2.0.0-3) stable; urgency=low
  * quitting of target OS version is current OS version
 -- Mathias Radtke <m.radtke@uib.de> Thu, 30 Sep 2021 14:00:00 +0200
l-debunut-upgrade (4.2.0.0-2) stable; urgency=low
  * fixed possible error with confnew/confdev when upgrading to bullseye
 -- Mathias Radtke <m.radtke@uib.de> Mon, 27 Sep 2021 09:32:00 +0200
opsi-linux-bootimage (20210903-1) testing; urgency=medium
  * kernel 5.13.11
  * adapted submitted patch for better Hyper-V compatability
 -- Mathias Radtke <m.radtke@uib.de> Fri, 03 Sep 2021 12:31:00 +0200
debian9/10/11 (4.2.0.1-3) testing; urgency=low
  * fixed setting xkblayout properly
 -- Mathias Radtke <m.radtke@uib.de> Tue Sep 07 13:30:00 2021 +0200
ubuntu18/20-04 (4.2.0.1-3) testing; urgency=low
centos70/redhat70 (4.2.0.1-3) testing; urgency=low
  * kickstart: added wget
 -- Mathias Radtke <m.radtke@uib.de> Wed Sep 08 15:11:00 +0200
l-opsi-server (4.2.0.5-1); testing; urgency=low
  * added Rocky Linux 8 support
  * added Alma Linux 8 support
 -- Mathias Radtke <m.radtke@uib.de> Mon, 13 Sep 2021 16:40:00 +0200
psi-quickinstall (4.2.0.1-2) experimental; urgency=low
  * new default l-opsi-server 4.2.0.5-2
  * openSUSE 15.3 added as supported distribution
  * Debian 11 added as supported distribution
  * default admin name in NOGUI-version changed from 'Alexandra' to 'adminuser'
  * error with adding release key fixed
  * bug fixed in closing Opsi-QuickInstall
-- Anja-Melanie Schmitz <a.schmitz@uib.de>  Tue,  30 Sep 2021 18:30:00 +0200
opsi-quickinstall (4.2.0.1) experimental; urgency=low
  * installing opsi 4.2 from stable (default), testing or experimental
  * try downloading latest l-opsi-server now from stable
  * log the version number of downloaded l-opsi-server
  * correctly assume yes in all package management shell commands
  * nogui:
    * error of empty l-opsi-server folder directory in option -f <file> fixed
    * use repo from file in option -f <file> instead of default repo
  * gui:
    * layout improved
-- Anja-Melanie Schmitz <a.schmitz@uib.de>  Wed,  01 Jun 2021 17:30:00 +0200
opsi-quickinstall (4.2.0.0) experimental; urgency=low
  * initial
  * installing opsi 4.2 from testing or experimental
-- Anja-Melanie Schmitz <a.schmitz@uib.de>  Thu,  29 Apr 2021 13:00:00 +0200
opsiconfd (4.2.0.205-1) stable; urgency=medium
  * Improvement:  add debug option: rpc error log
 -- uib GmbH <info@uib.de>  Tue, 28 Sep 2021 08:11:57 +0000
opsiconfd (4.2.0.203-1) stable; urgency=medium
  * Bugfix:  arm64 pam workaround
  * Bugfix:  logger reload (stderr,file)
 -- uib GmbH <info@uib.de>  Wed, 22 Sep 2021 13:21:55 +0000
opsi-utils (4.2.0.130-1) stable; urgency=medium
  * Improvement:  Update python-opsi
 -- uib GmbH <info@uib.de>  Tue, 21 Sep 2021 12:33:06 +0200
opsi-utils (4.2.0.129-1) stable; urgency=medium
  * Bugfix:  package build copy of opsi-util confs
  * Improvement:  arm64 build
 -- uib GmbH <info@uib.de>  Mon, 20 Sep 2021 17:28:13 +0200
opsi-utils (4.2.0.128-1) stable; urgency=medium
  * No public changes
 -- uib GmbH <info@uib.de>  Thu, 16 Sep 2021 10:45:23 +0200
opsi-utils (4.2.0.127-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Thu, 16 Sep 2021 09:19:57 +0200
opsi-utils (4.2.0.126-1) stable; urgency=medium
  * Improvement:  Add dependency to zsync2
 -- uib GmbH <info@uib.de>  Wed, 15 Sep 2021 14:12:21 +0200
opsi-utils (4.2.0.125-1) stable; urgency=medium
  * Improvement:  Add dependency to pigz
 -- uib GmbH <info@uib.de>  Fri, 10 Sep 2021 11:53:53 +0200
opsi-utils (4.2.0.124-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 07 Sep 2021 17:30:28 +0200
opsi-utils (4.2.0.123-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 07 Sep 2021 12:14:38 +0200
opsi-utils (4.2.0.122-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Tue, 07 Sep 2021 09:01:54 +0200
opsi-utils (4.2.0.121-1) stable; urgency=medium
  * Improvement:  Update proxy comments in conf files
  * Improvement:  add opsi-python example scripts
 -- uib GmbH <info@uib.de>  Mon, 06 Sep 2021 11:32:34 +0200
opsi-utils (4.2.0.120-1) stable; urgency=medium
  * Bugfix:  fix error with pcpatch password on ucs member
 -- uib GmbH <info@uib.de>  Fri, 03 Sep 2021 13:23:10 +0200
opsi-utils (4.2.0.119-1) stable; urgency=medium
 -- uib GmbH <info@uib.de>  Fri, 03 Sep 2021 08:04:06 +0200
opsipxeconfd (4.2.0.20-1) stable; urgency=medium
-- uib GmbH <info@uib.de>  Wed, 22 Sep 2021 14:21:32 +0200
opsi-server (4.2.0.57-1) stable; urgency=medium
  * Improvement:  Fix method setProductActionProgress with empty string as progress
 -- uib GmbH <info@uib.de>  Mon, 06 Sep 2021 07:22:49 +0200
