OPSI Client Agent
OPSI Client Agent
Hello Everybody,
Is it possible to Install OPSI Client Agent remotely from the opsi-configed.
if yes, please let me know how to do this task step by step.
I've had a look at the manual but it is a bit confusing.
thank you very much
thank you very much
- SisterOfMercy
Re: OPSI Client Agent
What are you trying to do? Do you want to reinstall the opsi client, or is this on a client that does not have the client yet?
And is this a linux client or a windows client?
These are actually Windows and Linux Clients and don't have client installed yet.
but what is more important for me now are the Windows Clients.
- SisterOfMercy
https://download.uib.de/opsi4.1/documen ... ntegration
Have you looked at this exact chapter?
Either you use the service_setup.cmd in a manual way, or you use the opsi-deploy-client-agent script from the command line (on the opsi server).
currently facing the same problem, Is there a link for updated documentation?
- j.schneider
- uib-Team
You can find the documentation here:
https://docs.opsi.org/opsi-docs-en/4.3/ ... psi-deploy
