microsoft visual c++ runtime 2008
Re: microsoft visual c++ runtime 2008
Beitragvon SisterOfMercy » 14 Nov 2018, 18:41
n.wenselowski hat geschrieben:Any news on this regard?
It seems to work allright. :)
[7] [nov 14 18:16:26:932] [opsi-client-agent]       (string  12)prodInfoText=PRODUCT_PROFESSIONAL_N
[6] [nov 14 18:16:26:932] [opsi-client-agent]     Set  $INST_ProductType$ = getValue("product_type_nr",$INST_Resultlist$)
[8] [nov 14 18:16:26:933] [opsi-client-agent]         retrieving strings from $INST_Resultlist$
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   0)major_version=6
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   1)minor_version=1
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   2)build_number=7601
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   3)platform_id=2
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   4)csd_version=Service Pack 1
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   5)service_pack_major=1
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   6)service_pack_minor=0
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   7)suite_mask=256
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   8)product_type_nr=1
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string   9)2003r2=false
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string  10)ReleaseID=
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string  11)prodInfoNumber=49
[8] [nov 14 18:16:26:933] [opsi-client-agent]             (string  12)prodInfoText=PRODUCT_PROFESSIONAL_N
[6] [nov 14 18:16:26:934] [opsi-client-agent]       The value of the variable "$INST_ProductType$" is now: "1"
[6] [nov 14 18:16:26:934] [opsi-client-agent]     Set  $INST_vcredistx86_installed$ = "false"
[6] [nov 14 18:16:26:934] [opsi-client-agent]       The value of the variable "$INST_vcredistx86_installed$" is now: "false"
[6] [nov 14 18:16:26:934] [opsi-client-agent]     If
[8] [nov 14 18:16:26:935] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:935] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:935] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:935] [opsi-client-agent]       Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BE518E6-ECC6-35A9-88E4-87755C07200F}]  opened
[6] [nov 14 18:16:26:935] [opsi-client-agent]       Key closed
[6] [nov 14 18:16:26:936] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BE518E6-ECC6-35A9-88E4-87755C07200F}] DisplayVersion") = "9.0.30729.6161"   <<< result true
[6] [nov 14 18:16:26:936] [opsi-client-agent]     Then
[5] [nov 14 18:16:26:936] [opsi-client-agent]       comment: vcredistx86 Version 9.0.30729.6161 is installed
[6] [nov 14 18:16:26:936] [opsi-client-agent]       Set  $INST_vcredistx86_installed$ = "true"
[6] [nov 14 18:16:26:937] [opsi-client-agent]         The value of the variable "$INST_vcredistx86_installed$" is now: "true"
[6] [nov 14 18:16:26:937] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:937] [opsi-client-agent]     If
[8] [nov 14 18:16:26:937] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:937] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:937] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:938] [opsi-client-agent]       Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}]   could not be opened by RegOpenKeyEx,  Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:938] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}] DisplayVersion") = "9.0.30729.4148"   <<< result false
[6] [nov 14 18:16:26:938] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:938] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:938] [opsi-client-agent]     If
[8] [nov 14 18:16:26:939] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:939] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:939] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:939] [opsi-client-agent]       Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}]   could not be opened by RegOpenKeyEx,  Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:939] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A25302D-30C0-39D9-BD6F-21E6EC160475}] DisplayVersion") = "9.0.30729"   <<< result false
[6] [nov 14 18:16:26:939] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:939] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:940] [opsi-client-agent]     If
[8] [nov 14 18:16:26:940] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:940] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:940] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:940] [opsi-client-agent]       Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5DA8F6CD-C70E-39D8-8430-3D9808D6BD17}]   could not be opened by RegOpenKeyEx,  Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:941] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5DA8F6CD-C70E-39D8-8430-3D9808D6BD17}] DisplayVersion") = "9.0.30411"   <<< result false
[6] [nov 14 18:16:26:941] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:941] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:941] [opsi-client-agent]     If
[8] [nov 14 18:16:26:942] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:942] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:942] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:942] [opsi-client-agent]       Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}]   could not be opened by RegOpenKeyEx,  Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:942] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E503B4BF-F7BB-3D5F-8BC8-F694B1CFF942}] DisplayVersion") = "9.0.21022.218"   <<< result false
[6] [nov 14 18:16:26:942] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:942] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:942] [opsi-client-agent]     If
[8] [nov 14 18:16:26:943] [opsi-client-agent]       key0 = HKEY_LOCAL_MACHINE
[7] [nov 14 18:16:26:943] [opsi-client-agent]       Registry started readonly
[7] [nov 14 18:16:26:943] [opsi-client-agent]       Registry started with redirection (32 Bit)
[6] [nov 14 18:16:26:943] [opsi-client-agent]       Info: Registry key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}]   could not be opened by RegOpenKeyEx,  Errorno 2 "The system cannot find the file specified.<"
[6] [nov 14 18:16:26:943] [opsi-client-agent]       GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}] DisplayVersion") = "9.0.21022"   <<< result false
[6] [nov 14 18:16:26:943] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:943] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:943] [opsi-client-agent]     If
[6] [nov 14 18:16:26:945] [opsi-client-agent]       CompareDotSeparatedNumbers($INST_NTVersion$,"4.0") <= "0"   <<< result false
[6] [nov 14 18:16:26:945] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:945] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:945] [opsi-client-agent]     If
[6] [nov 14 18:16:26:946] [opsi-client-agent]       CompareDotSeparatedNumbers($INST_NTVersion$,"6.1") < "0"   <<< result false
[6] [nov 14 18:16:26:946] [opsi-client-agent]     Then
[6] [nov 14 18:16:26:946] [opsi-client-agent]     EndIf
[6] [nov 14 18:16:26:946] [opsi-client-agent]     Switch : 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent]       Case : 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent]       Case match: 6.1 = 6.1
[6] [nov 14 18:16:26:947] [opsi-client-agent]         Set  $OCD_DIST_DIR$ = "dist.win7"
[6] [nov 14 18:16:26:948] [opsi-client-agent]           The value of the variable "$OCD_DIST_DIR$" is now: "dist.win7"
[6] [nov 14 18:16:26:948] [opsi-client-agent]         EndCase
[6] [nov 14 18:16:26:948] [opsi-client-agent]       Case : 6.2
[8] [nov 14 18:16:26:948] [opsi-client-agent]       Case mismatch: 6.2 != 6.1
Beitragvon n.wenselowski » 16 Nov 2018, 13:59
Hi SisterOfMercy,
SisterOfMercy hat geschrieben:
Great! It is in testing now and will come to stable in the future if no further problems arise.
Kind regards
