where can i find old packages
Re: where can i find old packages
normally I would recommend
preloginloader 3.4-39
from testing in opsiclientd Modus
regards
Perhaps it will help if You describe Your issues.......We're having issues with the current stable version of the preloginloader package
regards
* loginblocker does not work, the machines in question perform their automatic login while OPSI is working
* possibly related to that, some of our startup processes do not happen correctly while OPSI is installed. Removing OPSI fixes them.
to get the changelog just extract the opsi package with
opsi-package-manager -x preloginloader_3.4-27.opsi
preloginloader/OPSI/changelog.txt
