1312 "NetUseAdd" since new client
mfournier
Beitrag von mfournier »
Hello,
Ever since I updated the OpSi server, I've been having problems installing packages on new workstations.
As soon as we perform a PXE boot for new installations, the agent installs correctly but does not proceed to install the packages.
Here is the error:
[3] [2026-08-04 11:38:55.198] [event processing gui_startup{installation_pending}] Failed to mount depot share: (1312, ‘NetUseAdd’, 'The specified session does not exist. It may have already ended.') (EventProcessing.py:452)
However, for workstations that already have OPSI installed and have been updated to the new version, there are no issues.
Re: 1312 "NetUseAdd" since new client
Hello,
please check if opsi-client-agent 4.3.23.1-1 solves the issue.
https://opsipackages.43.opsi.org/experi ... 3.1-1.opsi
Best regards,
mfournier
Hello,
I just checked, but version 4.3.23 is no longer available in the experimental section.
So I went with 4.3.24 instead.
This only displays “opsi-script” on the computer and attempts to install the packages.
However, they all fail.
Sorry, we are currently working on multiple opsiclient-agent branches.
Please try this version:
https://opsipackages.43.opsi.org/testin ... 2.8-1.opsi
mfournier
Hello,
With the version provided, the problem is resolved.
I can install applications for new installations via PXE.
