OPSI Setup Failed
Imker79
OPSI Setup Failed
Beitrag von Imker79 »
Hi everyone,
im trying to setup OPSI on my Testsystem but the setup keeps failing. I tried manual installation and also the quicksetup.
Installed on a Debian 11
lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
Full Log was uploaded here
https://pastebin.com/GCQYXLZd
What im doing wrong or what im missing?
Regards
Max
Re: OPSI Setup Failed
Please try this version of the quick-installation
https://tools.43.opsi.org/testing/opsi-quickinstall.zip
If it fails, the l-opsi-server log is the one to take a look at.
Regards
Imker79
Hi, thanks for your reply. But this also fails, and i can not see whats causing the issue.
i also uploaded the log here
https://pastebin.com/BuCv7Act
Is a VM on HyperV not supported?
running opsi on HyperV is not tested by us, but it should work.
The problem is, the earlier installation failed in a later stage and I can't tell why as the log provided was not the one with the error message (post #1).
Running the quick-install again triggered a security mechanism in the quick-install itself not to install over an existing installation. In this case the script checks if there is already an opsi group existing.
You would need ti either delete everything opsi related on your VM, or reinstall the VM and create a snapshot to prevent another installation error.
Regards
