Name or service not known
jamesbond
Beitrag von jamesbond »
Hello everyone,
I need your help. I recently installed OPSI 4.3 on Ubuntu 22.04 using the quickinstall method. I'm using Windows Server as my DNS server. I added a client to OPSI and tried to install Windows 10.
The client connects to the OPSI server and boots normally, but before the installation begins, I get an error: 'Failed to resolve 'servername.test.tld' Error -2 Name or service not known'.
I've reinstalled OPSI 4.3 multiple times and ran health checks, which all came back green. I've attached a screenshot for reference.
Could you please help me :roll:
Thanks in advance
Re: Name or service not known
this is a name resolution error. Seems the fqdn is not resolved properly.
You'd have to check your dns settings if they are configured properly.
Regards
jamesbond
Thanks for your quick response Mathias.
Here is how my resolv.conf looks like:
nameserver 127.0.0.53
options edns0 trust-ad
search domain.tld
Is there is anything else I have to check?
Thanks
Hello,
is your domain really domain.tld? Is your OPSI-Server really called "servername.test.tld"?
Without logs it's difficult to guess what happens in your case.
I assume, your Client uses PXE /UEFI Netboot, you have created the Client in OPSI and have set a Netboot Product to "setup".
In this case, the DHCP Server seems to be configured correctly as it tells the client to connect to the OPSI-Server which in turn tells the client to do the netboot install.
But there seems to be a misconfiguration, as the Client tries to reach the opsi-server with "servername.test.tld".
Can you set the netboot product for your client to setup and post the content of the file "/tftpboot/opsi/opsi-linux-bootimage/cfg/01-MAC_ADDRESS_OF_CLIENT" here?
jamesbond
Hello Thomas,
No my server name is not domain.tld it is called something else but I just used domain.tld as an example.
Here is the output of the file:
set timeout=0
menuentry 'Start netboot installation' {
set gfxpayload=keep
linux (pxe)/opsi/opsi-linux-bootimage/install-x64 initrd=miniroot-x64 video=vesa:ywrap,mtrr vga=791 quiet --no-log console=ttyS0 pckey=a545bdade59c599e9c7479c2acd7feec hn=vm dn=DOMAIN.TLD product=win10-x64 macaddress=08:00:27:ee:8e:38 service=https://HOSTNAME.DOMAIN.TLD:4447/rpc
initrd (pxe)/opsi/opsi-linux-bootimage/miniroot-x64
I have changed the server name in the log above to HOSTNAME.DOMAIN.TLD and the dn to DOMAIN.TLD.
Thanks
Ok, this looks about right, so please try the following:
When the Client displays the error switch to another tty by using the key-combination Ctrl-Alt-F3
Login with user: root / password: linux123
Issue command:
nslookup HOSTNAME.DOMAIN.TLD
Take note of the responding DNS Server's IP Adress, it is the correct one?
If not, try issueing
nslookup HOSTNAME.DOMAIN.TLD IP-OF-YOUR-DNS
The answers should indicate the IP-Address of your OPSI-Server.
jamesbond
nslookup doesn't seem to be installed. Here is the output after running nslookup in tty:
-bash: nslookup: command not found
jamesbond
Hello again,
Since nslookup is not pre-installed when I swtiched to tty, I tried using ping and host commands:
ping HOSTNAME.DOMAIN.TLD
I got:
ping: HOSTNAME.DOMAIN.TLD: Name or sevrice not known
Output using the host command:
host HOSTNAME
Host HOSTNAME: not found: 3(NXDOMAIN)
I tried to ping other computer names within the network and I got a response but when I try to ping my opsi server from within the tty I won't get a response.
Thanks for your assistance
then this means your opsi server is not reachable via DNS.
Please check the DNS configuration.
Regards
jamesbond
Thanks. It got fixed.
I have added an A record of OPSI hostname and its IP to the DNS server which is the domain controller.
