Keine SSH Verbindung mehr möglich
Moderator: pandel
eniac
Beitrag von eniac »
Guten Tag zusammen.
Seit einiger Zeit kann ich keine Pakete mehr erstellen, da der oPB keine SSH Verbindung mehr zum Server aufbauen kann.
Leider sagen mir die Fehlermeldungen so garnichts ...
Wer hat ne Idee ?
[2023-03-20 03:53:45 PM] - oPB.gui.mainwindow.MainWindow                 -    ERROR -
[2023-03-20 03:55:46 PM] - oPB.gui.mainwindow.MainWindow                 -    ERROR -
[2023-03-20 03:55:55 PM] - oPB.gui.mainwindow.MainWindow                 -    ERROR -
[2023-03-20 03:56:00 PM] - oPB.core.processing.OpsiProcessing            -      SSH - --------------------ACTION: BUILD--------------------
[2023-03-20 03:56:00 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - ConnectionError("Error creating SSH connection --> Original error: ('W.X.Y.Z', <[2023-03-20 04:03:45 PM] - oPB.core.processing.OpsiProcessing            -      SSH - --------------------ACTION: GET DEPOTS--------------------
>, <paramiko.ecdsakey.ECDSAKey object at 0x00000196342E08D0>)")
[2023-03-20 03:56:00 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - Set return code to RET_SSHCONNERR
[2023-03-20 04:03:45 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - ConnectionError("Error creating SSH connection --> Original error: ('W.X.Y.Z', <paramiko.ecdsakey.ECDSAKey object at 0x000001962DF87080>, <paramiko.ecdsakey.ECDSAKey object at 0x000001962DFAC550>)")
[2023-03-20 04:03:45 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - Set return code to RET_SSHCONNERR
[2023-03-20 04:04:12 PM] - oPB.core.processing.OpsiProcessing            -      SSH - --------------------ACTION: BUILD--------------------
[2023-03-20 04:04:12 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - ConnectionError("Error creating SSH connection --> Original error: ('W.X.Y.Z', <paramiko.ecdsakey.ECDSAKey object at 0x000001962DFACEF0>, <paramiko.ecdsakey.ECDSAKey object at 0x000001962DF87278>)")
[2023-03-20 04:04:12 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - Set return code to RET_SSHCONNERR
[2023-03-20 04:06:01 PM] - oPB.core.processing.OpsiProcessing            -      SSH - --------------------ACTION: BUILD--------------------
[2023-03-20 04:06:02 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - ConnectionError("Error creating SSH connection --> Original error: ('W.X.Y.Z', <paramiko.ecdsakey.ECDSAKey object at 0x000001962E005DA0>, <paramiko.ecdsakey.ECDSAKey object at 0x000001962DFAC2E8>)")
[2023-03-20 04:06:02 PM] - oPB.core.processing.OpsiProcessing            -    ERROR - Set return code to RET_SSHCONNERR
eniac
Re: Keine SSH Verbindung mehr möglich
Beitrag von eniac »
Ok .. Eventuell werden hier doch noch ein paar Daten benötigt.
opsiconfd = 4.2.0.306
oPB = 8.5.0
W.X.Y.Z ausgeblendete IP des Servers
Putty verbindet sich ohne Fehler
oPB Einstellungen :
SSH Port : 22 (kein priv Key)
Server version : opsi 4.1 oder neuer
Opsi Workbench : /var/lib/opsi/workbench
Kompatibel : opsi 4.0.4 oder neuer / SUDO ohne PW (geht aber auch mit PW nicht)
