Opsi - Progress OpenEdge silent installation OpenJDK, JavaHome path
haito
Beitrag von haito »
Hello everyboby,
i`m trying to install progress openedge 12.2.4 with opsi.
I made an autoit-script (converted to .exe) and ran it in setup.opsiscript (opsi-package).
The silent installation uses a .ini-file with the java_home directory (openjdk), allready exists on c:\dlc\java.
Problem:
The installation via opsi gets stuck when the installer opens the java-path C:\dlc\java\11_x86\bin\java.exe
Installation without opsi works fine:
When i run the autoit-script or the oe122_client_installieren.exe without opsi, everything works fine!!
Solution:?!
Is it possible that opsi can`t open two .exe-files (setup.exe and java.exe) at the same time (installing-procedure)?
setup.opsiscript
Message "Installing OpenEdge-12 Client (ca. 5min)"
DosInAnIcon_install
[DosInAnIcon_install]
"%ScriptPath%\oe122_client_installieren.exe"
;AutoIT-Script
$ini_path = @TempDir & "\oe12client.ini"
FileCopy (@ScriptDir & "\oe12client.ini", $ini_path, 1)
ShellExecute (@ScriptDir & "\PROGRESS_OE_12.2.4_WIN_32\setup.exe", ' -psc_s -psc_f1="' & $ini_path & '" -psc_f2=C:\oe12client.log', "", "", @SW_HIDE)
oe12client.ini-File
; JAVA_HOME - select the java home directory.
;OpenJDK 11 (LTS)
[Select JavaHome Dialog]
JavaHome=C:\dlc\java\11_x86
Result=1
Thanks for your help! :)
haito
Re: Opsi - Progress OpenEdge silent installation OpenJDK, JavaHome path
Beitrag von haito »
Installation-Logfiles
oe12client.log
[Installshield]
Version=22.0.0.330
[Application]
Name=OpenEdge
Version=12.2
Company=Progress Software
[CompletedEvents]
Event7=[3-15-2021 17:47:54] Checking for OpenEdge programs and or processes in use .......
Event8=[3-15-2021 17:47:54] The Update Setup Utility has checked the system requirements.
Event9=[3-15-2021 17:47:54]  cmd /c C:\dlc\java\11_x86\bin\java.exe -version 2> "C:\WINDOWS\TEMP\{173D28E1-8A40-4684-93BE-D1CFBDEDA43D}\{E0D8975D-FA3C-4ED2-B6B8-27B3553781A5}\ver.log"
Event10=[3-15-2021 17:47:54] Command Executed successfully: cmd /c C:\dlc\java\11_x86\bin\java.exe -version 2> "C:\WINDOWS\TEMP\{173D28E1-8A40-4684-93BE-D1CFBDEDA43D}\{E0D8975D-FA3C-4ED2-B6B8-27B3553781A5}\ver.log"
Event11=[3-15-2021 17:47:54] Read - openjdk version "11.0.10" 2021-01-19
Event12=[3-15-2021 17:47:54] Selected JavaVersion is : 11.0.10
Event13=[3-15-2021 17:47:54] Supported JavaVersion is : 11.0.4
Event14=[3-15-2021 17:47:54] cmd /c C:\dlc\java\11_x86\bin\java.exe -cp "P:\windows_oe122_client_installer\PROGRESS_OE_12.2.4_WIN_32" JvmProperties 1> "C:\WINDOWS\TEMP\{173D28E1-8A40-4684-93BE-D1CFBDEDA43D}\{E0D8975D-FA3C-4ED2-B6B8-27B3553781A5}\JvmArch.log"
Event15=[3-15-2021 17:47:54] Command Executed successfully: cmd /c C:\dlc\java\11_x86\bin\java.exe -cp "P:\windows_oe122_client_installer\PROGRESS_OE_12.2.4_WIN_32" JvmProperties 1> "C:\WINDOWS\TEMP\{173D28E1-8A40-4684-93BE-D1CFBDEDA43D}\{E0D8975D-FA3C-4ED2-B6B8-27B3553781A5}\JvmArch.log"
Event16=[3-15-2021 17:47:54] Read - 32
As mentioned, when I run the installation script by hand (without opsi distribution) the installation works and the logfile continues after "Read - 32" until "Installation successful". What the "Read - 32" means I could not find out but it is also in the logfile at the successful installation.
haito hat geschrieben: i`m trying to install progress openedge 12.2.4 with opsi.
Why the hell are you doing that?
Anyway, I don't seem to be able to download that client somewhere, are you able to provide it?
It looks like a installshield thing, but I'm not sure if all that java detection can be disabled.
haito
Beitrag von haito »
Hi SisterOM,
here is the AutoIT-Script (converted to startoe12.exe):
#RequireAdmin
#include <File.au3>
#include <FileConstants.au3>
#include <MsgBoxConstants.au3>
#include <Array.au3>
ShellExecuteWait (@ScriptDir & "\PROGRESS_OE_12.2.4_WIN_32\setup.exe", ' -psc_s -psc_f1="' & $ini_path & '" -psc_f2=C:\oe12client.log', "", "", @SW_HIDE)
DirCopy(@ScriptDir & "\dlc122_x64_gui_src_cfg\gui", "C:\dlc\dlc122\gui", $FC_OVERWRITE)
DirCopy(@ScriptDir & "\dlc122_x64_gui_src_cfg\src", "C:\dlc\dlc122\src", $FC_OVERWRITE)
FileCopy (@ScriptDir & "\dlc122_x64_gui_src_cfg\progress.cfg", "C:\dlc\dlc122\progress.cfg", $FC_OVERWRITE)
FileCopy(@ScriptDir & "\*.lnk", @DesktopCommonDir, 1)
FileCopy(@ScriptDir & "\*.lnk", @DesktopDir, 1)
And here the setup.opsiscript:
Message "Installing OpenEdge-12 Client"
DosInAnIcon_oe112_install
[DosInAnIcon_oe112_install]
"%ScriptPath%\startoe12.exe"
Hint:
When in double-click the "startoe12.exe" without opsi, then the installation works fine...
And the installation needs the java-path during the installation - without the java-detection (path is in the .ini-file) the installation fails and says "no java-path found".
Here you can find something about the silent installation and how it works with the response.ini file:
Search-Engin --> "Performing a silent install of OpenEdge 10.1A and above on Windows"
You are including a lot of stuff in an autoIT script, but that stuff can all be put in the opsi-script itself. This can cut down on a lot of troubleshooting, and you don't have to maintain multiple scripts. Have you looked at the opsi-template package?
Sometimes an installshield installer creates an msi file in a temporary directory. Taking that msi file might also work.
I'll see if I can dig up some more.
edit: I downloaded an older zip file, but that is probably the version to install manually. I can't get your version anywhere, so I can't help you with this. But it should be simple.
