der Server Host Parameter
clientconfig.depot.user
(802) [3] [Sep 10 11:18:24] Failed to mount '//*hostname*/opsi_depot': Command '/bin/mount -t cifs -o "iocharset=utf8,domain=*domain*,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi' failed (32):
(803) mount error(5): Input/output error
(804) Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) (Posix.py|1252)
(813) [3] [Sep 10 11:18:24] Failed to mount '//*hostname*/opsi_depot': Command '/bin/mount -t cifs -o "vers=1.0,domain=*domain*,iocharset=utf8,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi' failed (32):
(814) mount error(5): Input/output error
Sep 10 01:18:01 *hostname* smbd[9420]: [2020/09/10 01:18:01.090385, 0] ../../source3/auth/auth_winbind.c:122(check_winbind_security)
Sep 10 01:18:01 *hostname* smbd[9420]: check_winbind_security: winbindd not running - but required as domain member: NT_STATUS_NO_LOGON_SERVERS
Sep 10 01:18:03 *hostname* smbd[9420]: [2020/09/10 01:18:03.095232, 0] ../../source3/auth/auth_winbind.c:122(check_winbind_security)
Sep 10 01:18:03 *hostname* smbd[9420]: check_winbind_security: winbindd not running - but required as domain member: NT_STATUS_NO_LOGON_SERVERS
default=opsi
timeout=0
image=/linux/install-x64
label=opsi
initrd=/linux/miniroot-x64.bz2
append="initrd=/linux/miniroot-x64.bz2 debug video=vesa:ywrap,mtrr vga=normal --no-log console=tty1 console=ttyS0 dn=*domain* product=win10-x64-ltsc pckey=4bd47ca6674252e41f243437042969ed service=https://*serverip*:4447/rpc hn=*hostname* pwh=*removed*"
796 [6] [Sep 14 13:14:12] Mountpoint: /mnt/opsi (Repository.py|1238)
797 [6] [Sep 14 13:14:12] Mounting 'smb://*hostname*/opsi_depot' to '/mnt/opsi' (Repository.py|1239)
798 [7] [Sep 14 13:14:12] Command 'mount' found at: '/bin/mount' (Posix.py|867)
799 [6] [Sep 14 13:14:12] Executing: /bin/mount -t cifs -o "iocharset=utf8,domain=*domain*,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi (Posix.py|926)
800 [6] [Sep 14 13:14:12] Using encoding 'UTF-8' (Posix.py|959)
801 [7] [Sep 14 13:14:12] >>> mount error(5): Input/output error (Posix.py|1003)
802 [7] [Sep 14 13:14:12] >>> Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) (Posix.py|1003)
803 [7] [Sep 14 13:14:12] Exit code: 32 (Posix.py|1010)
804 [3] [Sep 14 13:14:12] Failed to mount '//*hostname*/opsi_depot': Command '/bin/mount -t cifs -o "iocharset=utf8,domain=*domain*,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi' failed (32):
805 mount error(5): Input/output error
806 Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) (Posix.py|1252)
807 [4] [Sep 14 13:14:12] SMB3 mount failed, trying fallback (master.py|1543)
808 [6] [Sep 14 13:14:12] Mountpoint: /mnt/opsi (Repository.py|1238)
809 [6] [Sep 14 13:14:12] Mounting 'smb://*hostname*/opsi_depot' to '/mnt/opsi' (Repository.py|1239)
810 [6] [Sep 14 13:14:12] Executing: /bin/mount -t cifs -o "vers=1.0,domain=*domain*,iocharset=utf8,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi (Posix.py |926)
811 [6] [Sep 14 13:14:12] Using encoding 'UTF-8' (Posix.py|959)
812 [7] [Sep 14 13:14:12] >>> mount error(5): Input/output error (Posix.py|1003)
813 [7] [Sep 14 13:14:12] >>> Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) (Posix.py|1003)
814 [7] [Sep 14 13:14:12] Exit code: 32 (Posix.py|1010)
815 [3] [Sep 14 13:14:12] Failed to mount '//*hostname*/opsi_depot': Command '/bin/mount -t cifs -o "vers=1.0,domain=*domain*,iocharset=utf8,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi' failed (32):
816 mount error(5): Input/output error
817 Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) (Posix.py|1252)
818 [2] [Sep 14 13:14:13] Traceback: (Logger.py|798)
819 [2] [Sep 14 13:14:13] File "/usr/lib/python2.7/dist-packages/OPSI/Util/Repository.py", line 72, in getRepository
820 return CIFSRepository(url, **kwargs)
821 (Logger.py|798)
822 [2] [Sep 14 13:14:13] File "/usr/lib/python2.7/dist-packages/OPSI/Util/Repository.py", line 1225, in __init__
823 self._mount()
824 (Logger.py|798)
825 [2] [Sep 14 13:14:13] File "/usr/lib/python2.7/dist-packages/OPSI/Util/Repository.py", line 1256, in _mount
826 raise mountError
827 (Logger.py|798)
828 [2] [Sep 14 13:14:13] ==>>> Failed to mount '//*hostname*/opsi_depot': Command '/bin/mount -t cifs -o "vers=1.0,domain=*domain*,iocharset=utf8,credentials=/tmp/.cifs-credentials.*hostname*" //*hostname*/opsi_depot /mnt/opsi' failed (32):
829 mount error(5): Input/output error
32 EPIPE Broken pipe
