Hi there,
I have an issue with authentication where the setup are :
1. active Directory hosted DHCP and DNS.
2. opsi server ubuntu OS.
3. client windows 10
I try to Create a New Client using the opsi-client-bootcd then I got first screen to add host name and opsiconfd then the second screen ask to log in where I have an issue as (PAM authentication failed for use opsi-admin error on server).
would you guide me to solve this issue please.
Thank you in advance
login failed opsi authentication error
- SisterOfMercy
Re: login failed opsi authentication error
Have you followed the manual where you set the password for adminuser?
Yes I have follow the Instauration of manuell
- SisterOfMercy
Here you say you use opsi-admin.. which is a non-existent user if you have followed the manual.rere632000 hat geschrieben:I try to Create a New Client using the opsi-client-bootcd then I got first screen to add host name and opsiconfd then the second screen ask to log in where I have an issue as (PAM authentication failed for use opsi-admin error on server).
Hi, thank you for update
I have use start manual (https://download.uib.de/opsi4.1/documen ... 4.1-en.pdf) page 35 Figure 7.4
Regards
Regards
- SisterOfMercy
That is just a placeholder for whatever name you gave to the admin user.rere632000 hat geschrieben:I have use start manual (https://download.uib.de/opsi4.1/documen ... 4.1-en.pdf) page 35 Figure 7.4
Have you followed the example in 5.2.3 on page 27?
