Lenovo E14 Gen 2 failure to run OPSI client boot CD
mhambrecht
Beitrag von mhambrecht »
I am currently trying to boot to USB created using Rufus for opsi4.1.0-client-boot-cd_20200624.iso. I tried this using an older version and they both did the same thing. It boots ask 64 or 32 bit image. I choose, as usual, 64 bit and then language english and it just hangs on the next screen. I almost forgot to mention, this is so that I run OPSI-Clonezilla. Also, to make it clear, OS Optimized defaults = Off, Secure boot = off, Secure boot mode = Setup Mode. No where to set UEFI to Legacy.
Any assistance here would be appreciated.
Re: Lenovo E14 Gen 2 failure to run OPSI client boot CD
Have you seen this post? viewtopic.php?p=51616#p51616
I don't know how to set these parameters for the boot CD :(
mhambrecht
No I hadn't but this for the Boot CD not running it's OS. Not even getting to the options for netboot.
mhambrecht
Okay. I've done everything in the bios to attempt to make this work. The USB drive with OPSI boot CD on it works on earlier Lenovo models E480, E490, Thinkbook E14, and E495 but not this new one E14 Gen 2. Any suggestions on what I can do to make this work. In the meantime I have just run clonezilla, and it worked, and cloned the image to the same repository. However, I'd prefer to use OPSI in every way for all of my needs.
mhambrecht hat geschrieben:No I hadn't but this for the Boot CD not running it's OS. Not even getting to the options for netboot.
As far as I know the bootimage (in the win 10 topic) and the boot cd are the same thing.
If you have it on usb you can try editing the grub files, or wherever you set these options.
mhambrecht
Thank you. This didn't help but thank you anyway.
could you try to do it the netboot way to check if its the CD ?
Regards
