Installation Microsoft Surface Pro 7 fails
Re: Installation Microsoft Surface Pro 7 fails
dark alex hat geschrieben:Hi Mathias,
Could you tell me what exactly you need? Then I could probably try to solve the problem here.
I don't think I will be able to send a device...
(You got my mail address if you got instructions not meant for public)
Regards alex.
sorry i lost your mail from my overview, too much work :(
you could edit the install-elilo-x64 Netboot template and add a verbose=5 line to get more verbosity and maybe we will see more response from elilo
default=opsi
timeout=0
verbose=5
image=/linux/install-x64
label=opsi
append="initrd=/linux/miniroot-x64.bz2 debug video=vesa:ywrap,mtrr vga=normal --no-log console=tty1 console=ttyS0"
Another try could be to change the boot file to grubx64.efi in the DHCP and start the Client in UEFI Netboot _without_ a netboot product on setup. This will use the Grub2 bootloader that is used by the Secureboot module. Maybe the result will be different.
Regards
dark alex
Beitrag von dark alex »
Hi so the (very professional) "screenshot" below is made with elilo.
The grub boot just reports
acpiphp_ibm: ibm_acpiphp_init: acpi_walk_namespace failed
after hitting enter on the opsi bootimage entry in the grub menu.
in both cases processing stops at this point.
Please add acpi=off and/or noapic to the grub.cfg localted in /tftpboot/grub/ pr /var/lib/tftpboot/grub/, depending on OS and see if this changes anything with grub. You can also try these options as bootimage.append parameters with elilo, of course after setting back the UEFI DHCP default to elilo.efi.
Regards
dark alex
elilo:
with grub no console output at all (after selecting the boot entry).
unfortunately that didn't change anything useful.
dark alex hat geschrieben:elilo:
please remove the 'quiet splash' parameters and add 'verbose' to the grub.cfg. It should show more infos then.
Cheers
dark alex
m.radtke hat geschrieben:
Hi Mathias,
menuentry 'TEST Surface Pro 7' {
	set gfxpayload=keep
	linux (pxe)/linux/install-x64 initrd=miniroot-x64.bz2 video=vesa:ywrap,mtrr vga=791 --no-log console=tty1 console=ttyS0 acpi=off noapic verbose
	initrd (pxe)/linux/miniroot-x64.bz2
no changes at all. Immediately after pressing enter on that entry the screen goes black with a white cursor (frozen)
Even after several minutes no change.
pleased remoce acpi=off and noapic and try again
Regards
dark alex
same... :roll: :|
dark alex
Oh! After some more minutes suddenly a wild text appeared...
Hi Alex
does anything happen afterwards? How long did this stay in this state?
Did you check if the machine is responding to a ping?; if ping is not blocked in your network.
Regards
