create driver links
create driver links
A new opsi server has a problem with creating the correct driver links for hdaudio devices.
# ./show_drivers.py hostname.blah.nl
Additional drivers for integration byAudit found for vendor: 'Supermicro' model : 'Super Server (Default string)'  Check if drivers are available.
Additional drivers for integration byAudit-Baseboard found for vendor: 'Supermicro' model : 'X11SCQ' Check if drivers are available. .
PCI-Devices
   [8086:3EC2]  Intel Corporation : 8th Gen Core Processor Host Bridge/DRAM Registers
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel Chipset 10.1.18010.8141/Coffeelake
   [8086:3E98]  Intel Corporation : UHD Graphics 630 (Desktop 9 Series)
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel Graphics 26.20.100.7212/Graphics
   [8086:1911]  Intel Corporation : Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel Chipset 10.1.18010.8141/Skylake
   [8086:A379]  Intel Corporation : Cannon Lake PCH Thermal Controller
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel Chipset 10.1.18010.8141/CannonLake-H
   [8086:A36D]  Intel Corporation : Cannon Lake PCH USB 3.1 xHCI Host Controller
      No driver - device directory '/var/lib/opsi/depot/win10-x64/drivers/pciids/8086/A36D' not found
   [8086:A36F]  Intel Corporation : Cannon Lake PCH Shared SRAM
      No driver - device directory '/var/lib/opsi/depot/win10-x64/drivers/pciids/8086/A36F' not found
   [8086:A352]  Intel Corporation : Cannon Lake PCH SATA AHCI Controller
      No driver - device directory '/var/lib/opsi/depot/win10-x64/drivers/pciids/8086/A352' not found
   [8086:A340]  Intel Corporation : Cannon Lake PCH PCI Express Root Port #17
   [8086:A32C]  Intel Corporation : Cannon Lake PCH PCI Express Root Port #21
   [8086:F1A6]  Intel Corporation : SSD Pro 7600p/760p/E 6100p Series
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel NVMe 4.3.0.1006
   [8086:A330]  Intel Corporation : Cannon Lake PCH PCI Express Root Port #9
   [8086:A332]  Intel Corporation : Cannon Lake PCH PCI Express Root Port #11
   [8086:1533]  Intel Corporation : I210 Gigabit Network Connection
      /var/lib/opsi/depot/win10-x64/drivers/drivers/preferred/Intel LAN 24.2/PRO1000/Winx64/NDIS65
   [8086:A306]  Intel Corporation : Q370 Chipset LPC/eSPI Controller
   [8086:A348]  Intel Corporation : Cannon Lake PCH cAVS
   [8086:A323]  Intel Corporation : Cannon Lake PCH SMBus Controller
   [8086:A324]  Intel Corporation : Cannon Lake PCH SPI Controller
   [8086:15BB]  Intel Corporation : Ethernet Connection (7) I219-LM
USB-Devices
   No devices installed
HD-Audio-Devices
   [10EC:0888]  Realtek ALC888-VD
      No driver - vendor directory '/var/lib/opsi/depot/win10-x64/drivers/hdaudioids/10EC' not found
   [8086:280B]  Intel Kabylake HDMI
      No driver - vendor directory '/var/lib/opsi/depot/win10-x64/drivers/hdaudioids/8086' not found
Package used:
win10-x64 4.1.0.1-3
This realtek driver is copied from an older opsi server which does create the hdaudioids directory/symbolic links.
I currently can not check which package is on the older server, but create_driver_links.py was only changed by three characters.
old (going on memory):
def setRights():
	uid = -1
	if (os.geteuid() == 0):
		uid = pwd.getpwnam(DEFAULT_CLIENT_DATA_USER)[2]
	gid = grp.getgrnam(DEFAULT_CLIENT_DATA_GROUP)[2]
	for path in findFiles(prefix=DST_DIR, directory=DST_DIR, returnLinks=False):
		logger.info(u"Setting owner of '%s' to '%s:%s'" % (path, uid, gid))
		try:
			os.chown(path, uid, gid)
		except Exception as e:
			logger.warning(u"Failed to change owner of '%s' to '%s:%s': %s" % (path, uid, gid, e))
		try:
			if os.path.islink(path):
				continue
			elif os.path.isdir(path):
				logger.debug(u"Setting rights on directory '%s'" % path)
				os.chmod(path, 02770)
			elif os.path.isfile(path):
				logger.debug(u"Setting rights on file '%s'" % path)
				os.chmod(path, (os.stat(path)[0] | 0660) & 0770)
			logger.warning(u"Failed to set access rights of '%s' : %s" % (path, e))
new:
def setRights():
	uid = -1
		try:
		try:
				continue
				os.chmod(path, 0o2770)
				os.chmod(path, (os.stat(path)[0] | 0o660) & 0o770)
This change doesn't look like something that matters to this issue. Does it import other python stuff that has changed?
This is what I find when changing the verbosity:
old (working):
File 'drivers/preferred/Intel Graphics 26.20.100.6709/Graphics/DisplayAudio/10.26/IntcDAud.inf' locked after 0 millis
   - Getting strings
   - Getting devices
      - Device sections: NTAMD64, 2, Intel, 6
   - Parsing device section: Intel
   - Parsing device section: Intel.NTAMD64.6.2
      - Processing device string: HDAUDIO\FUNC_01&VEN_8086&DEV_2809&SUBSYS_80860101
         - Device type is HDAUDIO
         - Found HDAUDIO device: 8086:2809
new:
File 'drivers/preferred/Intel Graphics 26.20.100.7212/Graphics/DisplayAudio/10.26/IntcDAud.inf' locked after 0 millis
   - Getting strings
   - Getting devices
         - Device type is PCI
         - Found PCI device: 8086:2809
Re: create driver links
It seems the regex does not match.
https://github.com/opsi-org/python-opsi ... _init__.py
somewhere around line 666 ;)
class InfFile(ConfigFile):
	sectionRegex = re.compile('\[\s*([^\]]+)\s*\]')
	pciDeviceRegex = re.compile('VEN_([\da-fA-F]+)&DEV_([\da-fA-F]+)', re.IGNORECASE)
	hdaudioDeviceRegex = re.compile('HDAUDIO\\\.*VEN_([\da-fA-F]+)&DEV_([\da-fA-F]+)', re.IGNORECASE)
	usbDeviceRegex = re.compile('USB.*VID_([\da-fA-F]+)&PID_([\da-fA-F]+)', re.IGNORECASE)
	acpiDeviceRegex = re.compile('ACPI\\\(\S+)_-_(\S+)', re.IGNORECASE)
	varRegex = re.compile('\%([^\%]+)\%')
	classRegex = re.compile('class\s*=')
I used this tester:
https://regex101.com/
shows matches in:
[AzaliaManufacturerID.NTamd64.6.0]
"Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0233&SUBSYS_10CF1506
"Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0233&SUBSYS_10CF1507
"Realtek High Definition Audio" = IntcAzAudModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_10CF2000
does not show these matches.
Also, the code looks like it should detect ACPI devices, but it never does.
HDAUDIO\\.*VEN_([\da-fA-F]+)&DEV_([\da-fA-F]+)
also matches, with one backslash less.
Information about this system:
# uname -a
Linux opsi-home 3.10.0-1062.1.2.el7.x86_64 #1 SMP Mon Sep 30 14:19:46 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
# cat /etc/redhat-release
CentOS Linux release 7.7.1908 (Core)
# yum list installed | grep -i pyth
MySQL-python.x86_64                     1.2.5-1.el7                    @base
audit-libs-python.x86_64                2.8.5-4.el7                    @base
dbus-python.x86_64                      1.1.1-9.el7                    @anaconda
libselinux-python.x86_64                2.5-14.1.el7                   @base
libsemanage-python.x86_64               2.5-14.el7                     @base
libxml2-python.x86_64                   2.9.1-6.el7_2.3                @base
newt-python.x86_64                      0.52.15-4.el7                  @anaconda
policycoreutils-python.x86_64           2.5-33.el7                     @base
python.x86_64                           2.7.5-86.el7                   @anaconda
python-GnuPGInterface.noarch            0.3.2-11.el7                   @epel7
python-IPy.noarch                       0.75-6.el7                     @base
python-Twisted.x86_64                   12.0.0-2.6                     @opsi4
python-backports.x86_64                 1.0-8.el7                      @base
python-backports-ssl_match_hostname.noarch
python-cffi.x86_64                      1.6.0-5.el7                    @base
python-chardet.noarch                   2.2.1-3.el7                    @base
python-configobj.noarch                 4.7.2-7.el7                    @anaconda
python-decorator.noarch                 3.4.0-3.el7                    @anaconda
python-enum34.noarch                    1.0.4-1.el7                    @base
python-fasteners.noarch                 0.9.0-2.el7                    @epel7
python-gobject-base.x86_64              3.22.0-1.el7_4.1               @anaconda
python-httplib2.noarch                  0.9.2-1.el7                    @extras
python-idna.noarch                      2.4-1.el7                      @base
python-iniparse.noarch                  0.4-9.el7                      @anaconda
python-ipaddress.noarch                 1.0.16-2.el7                   @base
python-ldaptor.x86_64                   0.0.43-3.7                     @opsi4
python-libs.x86_64                      2.7.5-86.el7                   @anaconda
python-linux-procfs.noarch              0.4.11-4.el7                   @anaconda
python-lockfile.noarch                  1:0.9.1-4.el7.centos           @extras
python-magic.noarch                     5.11-35.el7                    @base
python-opsi.noarch                      4.1.1.72-1.2                   @opsi4
python-pam.x86_64                       0.5.0-1.6                      @opsi4
python-paramiko.noarch                  2.1.1-9.el7                    @base
python-perf.x86_64                      3.10.0-1062.1.2.el7            @updates
python-ply.noarch                       3.4-11.el7                     @base
python-pycparser.noarch                 2.14-1.el7                     @base
python-pycurl.x86_64                    7.19.0-19.el7                  @anaconda
python-pyudev.noarch                    0.15-9.el7                     @anaconda
python-requests.noarch                  2.6.0-5.el7                    @base
python-schedutils.x86_64                0.4-6.el7                      @anaconda
python-setuptools.noarch                0.9.8-7.el7                    @base
python-six.noarch                       1.9.0-2.el7                    @base
python-slip.noarch                      0.4.0-4.el7                    @base
python-slip-dbus.noarch                 0.4.0-4.el7                    @base
python-sqlalchemy.x86_64                0.9.8-2.el7                    @base
python-urlgrabber.noarch                3.10-9.el7                     @anaconda
python-urllib3.noarch                   1.10.2-7.el7                   @base
python-zope-interface.x86_64            4.0.5-4.el7                    @base
python2-PyDrive.noarch                  1.3.1-3.el7                    @epel7
python2-boto.noarch                     2.45.0-3.el7                   @epel7
python2-crypto.x86_64                   2.6.1-16.el7                   @epel7
python2-cryptography.x86_64             1.7.2-2.el7                    @base
python2-gflags.noarch                   2.0-5.el7                      @epel7
python2-google-api-client.noarch        1.6.3-1.el7                    @epel7
python2-keyring.noarch                  5.0-4.el7                      @epel7
python2-oauth2client.noarch             4.0.0-2.el7                    @epel7
python2-pyasn1.noarch                   0.1.9-7.el7                    @base
python2-pyasn1-modules.noarch           0.1.9-7.el7                    @base
python2-rsa.noarch                      3.4.1-1.el7                    @epel7
python2-uritemplate.noarch              3.0.0-1.el7                    @epel7
rpm-python.x86_64                       4.11.3-40.el7                  @anaconda
systemd-python.x86_64                   219-67.el7_7.1                 @updates
# yum list installed | grep -i opsi
libwim15.x86_64                         1.9.2-1.8                      @opsi4
opsi-linux-bootimage.noarch             20190805-3.2                   @opsi4
opsi-linux-support.noarch               4.1.1-3.2                      @opsi4
opsi-server.noarch                      4.1.1.8-1.2                    @opsi4
opsi-tftp-hpa-server.x86_64             5.2.8-50.2                     @opsi4
opsi-utils.noarch                       4.1.1.33-2.2                   @opsi4
opsi-windows-support.noarch             4.1.1-8.4                      @opsi4
opsiconfd.noarch                        4.1.1.18-4.4                   @opsi4
opsipxeconfd.noarch                     4.1.1.14-2.2                   @opsi4
wimlib.x86_64                           1.9.2-1.8                      @opsi4
winexe.x86_64                           4.8.0.0-23.4                   @opsi4
zsync.x86_64                            0.6.2-2.6                      @opsi4
Hi SisterOfMercy,
thanks for reporting and the investigation you already did!
The problem is probably this change where the regex patterns have been changed so that they won't produce errors with Python 3.
I think hdaudioDeviceRegex should have also been changed to remove one backslash - this isn't done in the change.
I'll create a fixed version for this and will let you know once this can be tested.
Sorry for the problems!
Kind regards
Hi SisterOfMercy,
n.wenselowski hat geschrieben:I think hdaudioDeviceRegex should have also been changed to remove one backslash - this isn't done in the change.
Please test with python-opsi 4.1.1.83. This is currently building in experimental.
Kind regards
n.wenselowski hat geschrieben:Please test with python-opsi 4.1.1.83. This is currently building in experimental.
Sorry for responding a bit late. It seems to work with the hdaudio devices, thanks!
Is it an option to change line 678 from the same file?
	acpiDeviceRegex = re.compile(r'ACPI\\(\S+)_-_(\S+)', re.IGNORECASE)
	should become:
	acpiDeviceRegex = re.compile(r'ACPI\\(\S+)', re.IGNORECASE)
Because this still does not match any ACPI devices I know of:
[HP.ntamd64]
%DeviceDesc% = HPAccelerometerDriverInstall.ntamd64, ACPI\HPQ6007
Hi SisterOfMercy,
the change seems trivial but we sould loose the second match. This is usually used to get the vendor of an device.
I have to say I don't know too much about how likely it is to encouter a vendor here at all or if there is a space I should have a look at.
Do you have any more information on that?
Cheers
n.wenselowski hat geschrieben:the change seems trivial but we sould loose the second match. This is usually used to get the vendor of an device.
I have some more information, but not exactly what you want.
https://docs.microsoft.com/en-us/window ... ls-section
https://docs.microsoft.com/en-us/window ... rdware-ids
https://docs.microsoft.com/en-us/window ... er-formats
The last link does not say anything about ACPI devices or bus drivers, and I can't find much else from microsoft about it.
However, we can look at drivers we know, what kind of strings do we see?
ACPI\HPQ6007
ACPI\LEN0268
ACPI\ATK0110
ACPI\IFX0102
ACPI\INTL0000
ACPI\INT343D
ACPI\IBM0068
ACPI\IBM0055
ACPI\VFSI6101
ACPI\PNP0A03
ACPI\PNP0A08
ACPI\INTC1234
ACPI\VEN_8086&DEV_0F08
ACPI\VEN_8086&DEV_0F09
I did not expect to find these last two! Intel chipset driver 10.0.27, win7only.inf
However, the majority does not use that scheme.
Also look at this other topic: viewtopic.php?f=11&t=11089
This has the complication of the devices like *TOS1900, which uses a generic identifier:
https://docs.microsoft.com/en-us/window ... dentifiers
