Add registry value
Whoops!
Add registry value
Beitrag von Whoops! »
Ich brauche mal kurz nen kleinen Denkanstoß beim Hinzufügen von eigenen Registry Key. Im log steht, dass der Modus auf readonly steht. Wie hierzu die Option zum schreiben in die Registry?
[7] [Okt 17 13:46:09:445] Registry started readonly
[7] [Okt 17 13:46:09:449] Registry started without redirection (64 Bit)
[6] [Okt 17 13:46:09:453] Registry key [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion]  opened
[6] [Okt 17 13:46:09:457] Key closed
[5] [Okt 17 13:46:09:524] Execution of: Registry_hkcu_programs /64bit
[5] [Okt 17 13:46:09:527]
[7] [Okt 17 13:46:09:531]   Registry started without redirection (64 Bit)
[7] [Okt 17 13:46:09:535]   Key is: HKEY_CURRENT_USER\Software\7-Zip\Options
[6] [Okt 17 13:46:09:539]   Registry key [HKEY_CURRENT_USER\Software\7-Zip\Options]  opened
[6] [Okt 17 13:46:09:543]       Variable "MenuIcons"  is keeping its value "1"
[7] [Okt 17 13:46:09:547]       Key is: HKEY_CURRENT_USER\Software\7-Zip\FM
[6] [Okt 17 13:46:09:552]       Key closed
[6] [Okt 17 13:46:09:556]       Registry key [HKEY_CURRENT_USER\Software\7-Zip\FM]  opened
[6] [Okt 17 13:46:09:559]       Variable "ShowDots"  is keeping its value "1"
[7] [Okt 17 13:46:09:564]       Key is: HKEY_CURRENT_USER\Software
[6] [Okt 17 13:46:09:568]       Key closed
[6] [Okt 17 13:46:09:572]       Registry key [HKEY_CURRENT_USER\Software]  opened
[6] [Okt 17 13:46:09:578]   Variable "shsasdsj"  is keeping its value "1"
[6] [Okt 17 13:46:09:580]   Variable "ok"  is keeping its value "ok"
[6] [Okt 17 13:46:09:585]   Key closed
[5] [Okt 17 13:46:09:596] message Hinzuf....gen der Registry Eintr....ge...
[1] [Okt 17 13:46:09:610] ___________________
[1] [Okt 17 13:46:09:614] script finished: success
[1] [Okt 17 13:46:09:620] 0 errors
[1] [Okt 17 13:46:09:624] 0 warnings
Message "Hinzufügen der Registry Einträge..."
[Registry_hkcu_programs]
openkey [HKEY_CURRENT_USER\Software\7-Zip\Options]
set "MenuIcons" = REG_DWORD:0001
openkey [HKEY_CURRENT_USER\Software\7-Zip\FM]
set "ShowDots" = REG_DWORD:0001
openkey [HKEY_CURRENT_USER\Software]
set "shsasdsj" = REG_DWORD:0001
set "ok" = "ok"
Re: Add registry value
You have seemed to forget the /AllNTUserDats switch.
