Uefi installation clients
ckruijntjens
Re: Uefi installation clients
Beitrag von ckruijntjens »
the opsi boot image.
When a client is known in the opsi admin tool that it needs windows10 it should install without questions. (select windows images and stuff) at least for normal pxe boot this does work. (yust press f12 and the rest is automatic)
with uefi boot it loads up the opsi boot image and then i need to give in the laptop name and imae name and stuff. (i did select in the tool that this is an uefi client) also i select to install the image.
by default die bootimage reads those infos from the dhclient.leses file, which is automatically generated when the DHCP request got processed.
Check whats inside the file in
/var/lib/dhcp/dhclient.leases
Cheers
ckruijntjens
hi,
I must say that my dhcp server is on an other machine. i see the file i will try tonight and see if something gets written to the file.
The dhclient.leases file exists on the client.
ckruijntjens
Ho Thomas
How can this be on the client? I am installing a client true opsi. Then this file should be written after installation?
ckruijntjens
Some more info,
When i create a normal client i see that a file is being created in "/tftpboot/linux/pxelinux.cfg" with the mac adres. If i create a new client with eufi enabled i dont see a mac file being created?
could this be the problem?
ckruijntjens
Hi All,
I feel so stupid. the uefi license was expired. with the new license it works again.
sorry all
