Updates in stable and testing
News and announcements
Dear opsi users,
updates have been released for opsi 4.1 in stable & testing.
News for stable:
  • Windows 10 based netboot packages: If a modified unattend.xml is used it will not be updated automatically. In such cases the unattend.xml from the 'custom' directory has to be manually compared to the unattend.xml.template from the opsi directory.
  • opsi-client-agent 4.1.0.0-32 handles WiFi MAC addresses differently then before.
  • The new Windows NT6 netboot packages in stable have a new property: 'install_local_bootimage'. This allows installing the bootimage locally to the first available UEFI partition of a system and start from there. The corresponding package opsi-boot-image-local still resides in 'testing'.
News for testing:
  • The extension opsi-vhd-reset has received extensive improvements based on feedback from live environments.
  • Support for Univention Corporate Client has been removed.
  • opsi-package-updater now is able to use a global proxy for all repositories which can be configured in opsi-package-updater.conf.
Updated packages in stable:
Server packages opsi 4.1:
  • python-opsi 4.1.1.67-1
  • opsi-script 4.12.1.5-1
Linux localboot packages:
  • opsi-linux-client-agent 4.1.0.18-1
  • opsi-configed 4.1.2.0.5-1
  • opsi-script-test 4.12.1.5-1
  • l-opsi-server-register-depot 4.1.0.2-1
Linux Netboot packages:
  • debian (4.1.0.2-1)
  • ucs44 4.1.0.1-1
Windows localboot packages:
  • opsi-wim-delete 4.1.0.1-1
  • opsi-winst 4.12.1.5-1
  • win10-sysprep-app-update-blocker 4.1.0.0-1
Windows netboot packages:
  • win NT6 4.1.0.1-3
opsi-local-image netboot packages:
  • opsi-local-image-prepare 4.1.0.0-15
opsi-local-image / opsi-vhd packages:
  • opsi-local-image-win10 4.1.0.0-15
  • opsi-local-image-win10-capture 4.1.0.0-15
  • opsi-local-image-win10-x64 4.1.0.0-15
  • opsi-local-image-win10-x64-capture 4.1.0.0-15
  • opsi-local-image-win7 4.1.0.0-15
  • opsi-local-image-win7-capture 4.1.0.0-15
  • opsi-local-image-win7-x64 4.1.0.0-15
  • opsi-local-image-win7-x64-capture 4.1.0.0-15
  • opsi-local-image-win81 4.1.0.0-15
  • opsi-local-image-win81-capture 4.1.0.0-15
  • opsi-local-image-win81-x64 4.1.0.0-15
  • opsi-local-image-win81-x64-capture 4.1.0.0-15
  • opsi-vhd-win10-x64 4.1.0.0-15
Updated packages in testing:
  • python-opsi 4.1.1.71-1
  • opsipxeconfd 4.1.1.14-2
  • opsi4ucs 4.1.1.9-2
  • opsi-utils 4.1.1.33-2
  • opsi-tftp-hpa 5.2.8-50
  • opsi-linux-bootimage 20190805-3
Linux netboot packages:
  • l-opsi-server-register-depot 4.1.0.2-2
opsi-local-image localboot packages:
  • opsi-vhd-control 4.1.0.0-11
  • opsi-vhd-auto-upgrade 4.1.0.0-6
  • opsi-local-image-win NT6 4.1.0.1-1
  • opsi-vhd-win10-x64 4.1.0.1-5
With kind regards
Niko Wenselowski
PS: Changelogs:
debian (4.1.0.2-1) stable; urgency=low
  * username can now be set
-- Mathias Radtke <m.radtke@uib.de> Mon, 01 Apr 2019 13:20:00
l-opsi-server-register-depot (4.1.0.2-2); stable; urgency=low
  * added new properties to control Configserver as Depotserver repo source
 -- Mathias Radtke <m.radtke@uib.de> Tue, 06 Aug 2019 10:20:00 +0200
l-opsi-server-register-depot (4.1.0.2-1); stable; urgency=low
  * new property added to select opsi server as repository
l-opsi-server-register-depot (4.1.0.1-2); stable; urgency=low
  * small fixes
 -- Bardo Wolf <b.wolf@uib.de> Tue, 07 May 2019 15:00:00 +0200
l-opsi-server-register-depot (4.1.0.1-1); stable; urgency=low
  * initial package creation
 -- Mathias Radtke <m.radtke@uib.de> Thu, 04 Apr 2019 15:00:00 +0200
opsi-linux-bootimage (20190805-3) testing; urgency=medium
  * corrected pre/postinst handling with new grub.cfg config file
 -- Mathias Radtke <m.radtke@uib.de>  Tue, 06 Aug 2019 08:55:43 +0200
opsi-linux-bootimage (20190805-2) testing; urgency=medium
  * fixed "Arch dependent binaries in noarch package" error in RPM builds
 -- Mathias Radtke <m.radtke@uib.de>  Mon, 05 Aug 2019 13:28:36 +0200
opsi-linux-bootimage (20190805-1) testing; urgency=medium
  * kernel 5.2.6
  * removed setting serviceentry in default.menu in postinst
  * not deleting AMDGPU firmware binaries
 -- Mathias Radtke <m.radtke@uib.de>  Mon, 05 Aug 2019 10:55:50 +0200
opsi-linux-bootimage (20190724-2) testing; urgency=medium
  * added grub.cfg to debian pre/postinst files
 -- Mathias Radtke <m.radtke@uib.de>  Wed, 24 Jul 2019 14:16:30 +0200
opsi-linux-bootimage (20190724-1) testing; urgency=medium
  * small refactoring
  * setCompression replaces setDeflate
  * preinst checks for existing default.menu instead of pxelinux.cfg directory
  * added files to make secureboot work
 -- Mathias Radtke <m.radtke@uib.de>  Mon, 24 Jul 2019 12:39:49 +0200
python-opsi (4.1.1.71-1) stable; urgency=medium
  * OPSI.Util.Task.UpdatePackages.Config: Use RFC 2616 compatible user agent.
  * OPSI.Util.Task.UpdatePackages.Config: Make it possible to configure a
    global proxy in the general config that will be applied to all repos
    that do not use their own proxy.
  * OPSI.Util.Task.UpdatePackages: Lower the loglevel for the used proxy.
  * OPSI.Util.Task.UpdatePackages.Updater: Simplify notifier handling.
  * OPSI.Util: librsync functions now provide more information about used
    files in the log.
  * Added new module OPSI.Util.Task.ConfigureBootimage.
  * Backend.backend_getOptions now returns a copy instead of a reference.
    This leads to temporaryBackendOptions behaving as expected.
  * OPSI.Service.Worker.WorkerOpsiJsonRpc: If a client sends gzip and deflate
    in the 'Accept-Encoding' HTTP header we prefer gzip for the response.
  * 30_kiosk.conf: getKioskProductInfosForClient: added new parameter
    addConfigs for the new version of the Kiosk client.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 06 Aug 2019 17:47:54 +0200
python-opsi (4.1.1.70-1) stable; urgency=medium
  * OPSI.System.Posix: Add support for retrieving the currently used
    distribution through the "distro" module.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 10 Jul 2019 14:30:26 +0200
python-opsi (4.1.1.69-1) testing; urgency=medium
  * 20_easy.conf: Added new method: getClientsWithActionRequest.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 08 Jul 2019 13:59:45 +0200
python-opsi (4.1.1.68-2) testing; urgency=medium
  * 45_deprecated.conf: Fix deprecation warning for getClients_listOfHashes
    and getClientIds_list.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 28 Jun 2019 17:50:27 +0200
python-opsi (4.1.1.68-1) testing; urgency=medium
  * OPSI.Util.File.DHCPDConfFile: Small refactoring to improve parse time.
  * OPSI.Backend.DHCPD: Errors are now logged with their traceback.
  * OPSI.Util.File.DHCPDConfFile: Support parsing data structures consisting
    of a sequence of data types (a.k.a. record types).
  * OPSI.Backend.JSONRPC.JSONRPCBackend: Added support for 'gzip' compression.
    For a seamless integration the new option 'compress' has been added to the
    constructor. It accepts either the values 'deflate', 'gzip' or a boolean.
    In case the boolean is selected the compression to use will be chosen
    by the implementation.
    This also adds the new function setCompression to instances of the class.
    This method should be used instead of the now deprecated 'setDeflate'.
    If compression is used can be checked with isCompressionUsed.
  * Added 20_easy.conf with the following methods: getClients, getClientIDs,
    getClientsOnDepot and getClientsWithProducts.
  * API: Deprecated the methods backend_searchIdents, getClients_listOfHashes
    To replace their commonly used functionality use the methods getClients,
    getClientIDs, getClientsOnDepot and getClientsWithProducts respectively.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 28 Jun 2019 15:57:19 +0200
python-opsi (4.1.1.67-1) stable; urgency=medium
  * OPSI.Backend.File.FileBackend: raise an error when executing getData.
  * OPSI.System.Posix: Cache the service names of DHCPD and Samba after lookup.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 29 May 2019 16:52:29 +0200
ucs44 (4.1.0.1-2) testing; urgency=low
  * corrected upgrade version in temporary rc.local
-- Mathias Radtke <m.ratdke@uib.de> Thu Jun 06 2019 10:00:00 +0200
ucs44 (4.1.0.1-1) testing; urgency=low
  * forked from ucs43
-- Mathias Radtke <m.radtke@uib.de> Mon Apr 01 14:50:00 2018 +0200
opsi-client-agent (4.1.0.0-32) stable; urgency=low
  * opsi-script 4.12.1.5
  * setup412: new local funstion oca_is_my_mac_cable($INST_MAC$)
  * setup412: oca_write_configuration()(): do only write back cable ethernet MAC
-- Detlef Oertel <d.oertel@uib.de>  Wed, 12 Jun 2019:15:00:00 +0200
opsi-client-agent (4.1.0.0-31) stable; urgency=low
  * opsi-script 4.12.1.4
  * setup412: oca_read_configuration(): no loop on services if depends_on_service is empty
-- Detlef Oertel <d.oertel@uib.de>  Fri, 26 Apr 2019:15:00:00 +0200
opsi-client-agent (4.1.0.0-30) stable; urgency=low
  * Cleanup in OPSI/postinst.
-- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 29 May 2019 17:03:25 +0200
opsi-winst/opsi-script (4.12.1.5) experimental; urgency=low
  * osdefinedfunctions: delLocalVar : fix removing loopvar after empty loop
-- Detlef Oertel <d.oertel@uib.de>  Thu, 06 Jun 2019:15:00:00 +0200
opsi-winst/opsi-script (4.12.1.4-1) experimental; urgency=low
  * osfunc: more logging around gettemppath
  * osparser: enabled getHWBiosInfoMap again
-- Detlef Oertel <d.oertel@uib.de>  Mon, 03 Jun 2019:15:00:00 +0200
opsi-winst/opsi-script (4.12.1.3-1) stable; urgency=low
  * fixes in library file: uib_exitcode.opsiscript: in isInstallshieldExitcodeFatal, isAdvancedMsiExitcodeFatal
  * update to 4.12.1.3:
      * shellInAnIcon: on loglevel 9: reread teporary files and do not delete
      * oslog: logdatei property usedloglevel (this is real used log level with force_min_loglevel)
-- Detlef Oertel <d.oertel@uib.de>  Tue, 14 May 2019:15:00:00 +0200
opsi-script-test (4.12.1.5-1) stable; urgency=low
  * fix removing of loopvar from empty loop
-- detlef oertel <d.oertel@uib.de>  Thu,  06 Jun 2019 15:00:00 +0200
opsi-script-test (4.12.1.4-1) stable; urgency=low
  * comments on wmi test
  * fix test getHWBiosInfoMap
-- detlef oertel <d.oertel@uib.de>  Mon,  03 Jun 2019 15:00:00 +0200
opsi-wim-delete (4.1.0.1-1) stable; urgency=low
  * Adds possibility to delete multiple images
 -- Mathias Radtke <m.radtke@uib.de>  Wed, 03 Apr 2019 12:00:00 +0200
opsi-wim-delete (4.0.7.1-1) stable; urgency=low
  * derivated from opsi-wim-info (4.0.7.2-1)
  * derivated from opsi-capture
 -- detlef oertel <d.oertel@uib.de>  Thu, 09 Feb 2017 15:00:00 +0000
win10-sysprep-app-update-blocker (4.1.0.0-1) stable; urgency=medium
  * Changed name of product from opsi-wim-capture-helper to win10-sysprep-app-update-blocker
-- d.oertel <d.oertel@uib.de> Di, 21 May 2019 16:39:50 +0200
opsi-wim-capture-helper (4.1.0.0-1) stable; urgency=medium
  * initial by opsi-setup-detector
  * This stops apps from updating and windows store from auto installing apps.
  * ; https://blogs.technet.microsoft.com/mniehaus/2018/04/17/cleaning-up-apps-to-keep-windows-10-sysprep-happy/
  * ; in comment from PeteBC
-- d.oertel <d.oertel@uib.de> Di, 16 Apr 2019 16:39:50 +0200
opsi-linux-client-agent (4.1.0.18-1) stable; urgency=medium
  * update opsi-script to 4.12.1.5
  * shebang fix
  * moved linux-client-agent start entry
    from /etc/opsi-script/opsi-script.conf
    to /etc/opsi-client-agent/opsi-client-agent.conf
  * ShellInAnIcon_configure_opsiclientd_ports_univention
      moved to end of sub_opsiclientd_install
      killed share access before
-- d.oertel <d.oertel@uib.de> Tue, 04 Jun 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.17-1) stable; urgency=medium
  * update opsi-script to 4.12.1.3
-- d.oertel <d.oertel@uib.de> Tue, 14 May 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.16-1) stable; urgency=medium
  * update opsi-script to 4.12.1.2
-- d.oertel <d.oertel@uib.de> Thu, 02 May 2019 15:00:00 + 0100
opsi-linux-client-agent (4.1.0.15-1) experimental; urgency=medium
  * Updated opsiclientd binaries.
 -- Niko Wenselowski <n.wenselowski@uib.de> Tue, 09 Apr 2019 17:19:39 +0100
opsi-linux-client-agent (4.1.0.14-1) experimental; urgency=medium
 -- Niko Wenselowski <n.wenselowski@uib.de> Tue, 09 Apr 2019 11:13:10 +0100
opsi-linux-client-agent (4.1.0.13-1) stable; urgency=medium
  * Added support for UCS 4.4
-- Mathias Radtke <m.radtke@uib.de> Tue, 02 Apr 2019 14:25:00 +0200
opsi-linux-client-agent (4.1.0.12-1) stable; urgency=medium
  * added dependency to desktop-file-utils
  * update opsi-deploy-client-agent (nw)
-- d.oertel <d.oertel@uib.de> Mon, 21 Jan 2019 15:00:00 + 0100
opsi-vhd-auto-upgrade (4.1.0.0-6) stable; urgency=low
  * set $upgradeproducts$ in property exclude_from_meta_data_restore in opsi-vhd-control
-- detlef oertel <d.oertel@uib.de>  Tue, 30 Feb 2019 15:00:00 +0200
opsi-vhd-auto-upgrade (4.1.0.0-5) stable; urgency=low
  * remove empty strings from $upgradeproducts$
  * new property: products_to_exclude: Which opsi product(s) should be excluded from upgrade ?
-- detlef oertel <d.oertel@uib.de>  Thu, 25 Feb 2019 15:00:00 +0200
opsi-vhd-auto-upgrade (4.1.0.0-4) stable; urgency=low
  * syntax fix
-- detlef oertel <d.oertel@uib.de>  Wed, 24 Feb 2019 15:00:00 +0200
opsi-vhd-auto-upgrade (4.1.0.0-3) stable; urgency=low
  * new property: products_to_install: Which opsi product(s) should be installed via upgrade ?
opsi-vhd-auto-upgrade (4.1.0.0-2) stable; urgency=low
  * own changelog file
-- detlef oertel <d.oertel@uib.de>  Mon, 05 Feb 2018 15:00:00 +0200
win-vhd-control (4.1.0.0-11) stable; urgency=low
  * exclude some products from backup
  * new property force_initial: Which opsi product(s) should be excluded from meta data restore ?
-- detlef oertel <d.oertel@uib.de>  Tue, 30 Juli 2019 15:00:00 +0000
win-vhd-control (4.1.0.0-10) stable; urgency=low
  * clean fix for local stored bootimage
  * new property force_initial: If true: Ignore existing meta data files and make a new one
-- detlef oertel <d.oertel@uib.de>  Mon, 22 Juli 2019 15:00:00 +0000
win-vhd-control (4.1.0.0-9) stable; urgency=low
  * quickfix for local stored bootimage
-- detlef oertel <d.oertel@uib.de>  Fri, 19 Juli 2019 15:00:00 +0000
win-vhd-control (4.1.0.0-8) stable; urgency=low
  * new property: setup_after_restore ; default: windomain
-- detlef oertel <d.oertel@uib.de>  Wed, 10 Juli 2019 15:00:00 +0000
win-vhd-control (4.1.0.0-7) stable; urgency=low
  * fix in setup: opsiservicecall_setProductProperty_generic use %opsiserviceUser%
win-vhd-control (4.1.0.0-6) stable; urgency=low
  * require opsi-script 4.12.1
  * add 'bcdedit /copy {default} /d snapshot' and dosinanIcon_bcd_new_vhd
  * do not use compact vdisk
-- detlef oertel <d.oertel@uib.de>  Mon, 01 Juli 2019 15:00:00 +0000
opsi-local-image-prepare (4.1.0.0-15) stable; urgency=low
  * multi_disk_mode: possible to use first disk and ignore any other disk
 -- Mathias Radtke <m.radtke@uib.de> Tue 11 Jun 2019 15:30:00 +0200
opsi-local-image-prepare (4.1.0.0-14) stable; urgency=low
  * wrapped seting Netboot as nextBoot device in try/catch block
 -- Mathias Radtke <m.radtke@uib.de> Tue, 22 2019 08:00:00 +0200
windows (4.1.0.1-5) testing; urgency=low
  * nt6.py: patcha_in: if vhdmode: windows_partition_number=1
  * nt6.py: use nt6.opsiscript also if winpenetworkmode=false
  * nt6.opsiscript: add support for winpenetworkmode=false
-- Detlef Oertel <d.oertel@uib.de> Thu Jul 04 2019 15:00:00 +0200
windows (4.1.0.1-4) testing; urgency=low
  * nt6.py: display content of diskpartvhd.txt
  * nt6.py: fix calculation of partitions at vhdmode
-- Detlef Oertel <d.oertel@uib.de> Mon Jul 01 2019 15:00:00 +0200
windows (4.1.0.1-3) testing; urgency=low
  * nt6.py: fix for: multi_disk_mode= '0_ignore_anything_else'
-- Detlef Oertel <d.oertel@uib.de> Wed Jun 19 09:05:24 2019 +0200
windows (4.1.0.1-2) stable; urgency=low
  * version bump to match other windows netboot products
windows (4.1.0.1-1) stable; urgency=low
  * new property added: install_local_bootimage
  * wifi.xml added
  * nt6.py: patches wifi.xml in postins.d to autoconnect to WiFi
  * postinst.cmd: copies wifi.xml to postins.d directory
  * only tested on Windows 10
  * nt6.py fixed check on installfiles_dir setup.exe
-- Mathias Radtke <m.radtke@uib.de> Wed, 29 May 2019 10:15:00 +0200
opsipxeconfd (4.1.1.14-2) stable; urgency=medium
  * deb: Remove adjustment for Univention Corporate Client (UCC) tftp root.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 05 Jul 2019 14:47:03 +0200
opsi4ucs (4.1.1.9-2) stable; urgency=medium
  * Join script: removed unused reference to UCC tftp directory.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Fri, 05 Jul 2019 14:42:16 +0200
opsi-utils (4.1.1.33-2) stable; urgency=medium
  * opsi-package-updater: It is now possible to configure a global proxy in
    opsi-package-updater.conf. It can be overriden per repo.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 07 Aug 2019 14:18:06 +0200
opsi-utils (4.1.1.33-1) stable; urgency=medium
  * opsi-package-manager: Delta file creation uses the configured temp dir.
  * opsi-package-manager: Use functionality from python-opsi for creating a
    librsync delta file.
  * Use an RFC 2616 compatible User-Agent in opsi-admin, opsi-convert and
    opsi-package-manager.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 22 Jul 2019 10:04:28 +0200
opsi-tftpd-hpa (5.8.2-50) testing; urgency=low
  * UCS: TFTPROOT is now '/tftpboot/' instead of '/var/lib/univention-client-boot/'
 -- Mathias Radtke <m.radtke@uib.de> Tue, 6 Aug 2019 08:20:00 +0200
opsi-configed 4.1.2.0.4
Changelogs
* bugfix in UserRoles, (not) allowed clients did not reappear
* new option "ignore ping answer" for opsi-deploy-client-agent call
* new option "use sudo" for opsi-deploy-client-agent call
* removed opsi 3 value for installation_status in the search function
nicolaslebrun
Re: Updates in stable and testing
Beitrag von nicolaslebrun »
Hi !
Am i missing something, but i can't find on http://download.uib.de/opsi_stable/prod ... localboot/ neither opsi-client-agent 4.1.0.0-32 nor opsi-winst 4.12.1.5-1 ?
Greetings,
Nico
Hi Nico,
I'm sorry for any inconvinience that might have happened because of this.
The package is now present, please try updating again :)
Kind regards
