Unable to install 1903
Re: Unable to install 1903
Strange after your command the package is downloaded but on install the same error
I use 64bit windows do i need to change the command?
- SisterOfMercy
Can you repeat the command but with more verbosity? Replace -v with -vvv and copy the output here.
Looks like its up to date. Here is the last output.
Testing if download/installation of package 'win10_4.1.0.0-16.opsi' is needed Product 'win10' is installed Available product version is '4.1.0.0-16', installed product version is '4.1.0.0-16' Unfulfilled condition: Version(product=u'4.1.0.0', package=u'16') > Version(product=u'4.1.0.0', package=u'16') win10_4.1.0.0-16.opsi - installation not required: installed version '4.1.0.0-16' of product 'win10' is up to date Testing if download/installation of package 'win10-x64_4.1.0.0-16.opsi' is needed Product 'win10-x64' is installed Available product version is '4.1.0.0-16', installed product version is '4.1.0.0-16' Unfulfilled condition: Version(product=u'4.1.0.0', package=u'16') > Version(product=u'4.1.0.0', package=u'16') win10-x64_4.1.0.0-16.opsi - installation not required: installed version '4.1.0.0-16' of product 'win10-x64' is up to date No new packages downloaded Calling backend_exit() on backend <BackendExtender()> Calling backend_exit() on backend <HostControlBackend(resolveHostAddress=True, maxConnections=50)> Calling backend_exit() on backend <DepotserverBackend()> Calling backend_exit() on backend <ExtendedConfigDataBackend(configDataBackend=<BackendDispatcher(dispatchConfigFile=u'/etc/opsi/backendManager/dispatch.conf', context=<BackendManager()>)>)> Calling backend_exit() on backend <BackendDispatcher(dispatchConfigFile=u'/etc/opsi/backendManager/dispatch.conf', context=<BackendManager()>)>
i reuploaded the current experimental win10 and win10-x64 packages to experimental
If you still have the error related to the unattend.xml, please check if the template and the used unattend.xml are the same. IOf not you need to remove the specific line from your modified unattend.xml
cheers
mathias
cheers
mathias
No we have an other error wright at the start
Name isWifi is not defined
you need an updated opsi-linux-bootimage for this to work aswell.
the bootimage is now available in stable and should avoid these issues
Regards
Regards
Hi indeed i yust updated my opsi boot image however i still have the first issue
windows could not apply unattend settings during pass [specialise]
Am i the only one with this problem?
Do you use a modified unattend.xml in your Installation? If so, then you have to adapt the changes we made to male your modified unattend.xml to work
