Unable to install 1903
Hi all,
I have an issue. Windows 1803 and 1809 went on with no issues. However, when trying to install 1903 it installs but then says getting ready and then comes up with the error - windows could not apply unattend settings during pass [specialise]. The preview build worked fine but the final build is not completing. I do the install on a fresh machine then create a winpe on the same machine and put these files on the w10 depot share just like previous installs.
Anyone that knows the cause would be really appreciated.
- SisterOfMercy
Re: Unable to install 1903
Look at this topic: viewtopic.php?f=7&t=11112
update your netboot product for win10:
opsi-package-updater --repo uib_windows_experimental --use-inactive-repo -v update win10-x64 win10
I have the following error
You have searched for a product, which was not found in configured repository: 'win10
- SisterOfMercy
'win10 is not a product indeed. Please share the entire command you used.ckruijntjens hat geschrieben:You have searched for a product, which was not found in configured repository: 'win10
This is the command
- SisterOfMercy
I would have thought you would have inadvertently added a '-character.
But now I see it, win10 package is not in experimental, it has been moved to testing. Still, do you actually _use_ 32 bit windows?
opsi-package-updater --repo uib_windows_testing --use-inactive-repo -v update win10-x64 win10
This is something that shouldn't happen. Well there will be an update in experimental this week either way.SisterOfMercy hat geschrieben:I would have thought you would have inadvertently added a '-character.
Cheers
mathias
Is there an other way to get the wright image?
I dont want to wait a week for this?
- SisterOfMercy
Get it from testing, use the command in my previous reply.ckruijntjens hat geschrieben:Is there an other way to get the wright image?
