ich habe ein Problem mit dem Bootimage im UEFI-Modus.
Das Bild/Image bleibt nach dem Start der Soundkarte stehen.
Produktnummer HP: 4HN12EA#ABD
Die Ausgabe des Codes für lspci -vvv und lsmod wurde mit Ubuntu 18.04.2 (Desktop) erstellt.
lspci -vvv
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15d0
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 15d0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 15d1
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 15d1
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 27
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 15d3 (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Latency: 0
Interrupt: pin ? routed to IRQ 28
Bus: primary=00, secondary=01, subordinate=08, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: d0800000-d09fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:01.6 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 15d3 (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin ? routed to IRQ 29
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: d0700000-d07fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 15db (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 30
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: d0300000-d06fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000d01fffff
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 15dc (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 31
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: d0200000-d02fffff
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Hewlett-Packard Company FCH SMBus Controller
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Hewlett-Packard Company FCH LPC Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15e8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15e9
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15ea
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15eb
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15ec
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15ed
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15ee
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 15ef
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset USB 3.1 xHCI Controller (rev 02) (prog-if 30 [XHCI])
Subsystem: Hewlett-Packard Company 300 Series Chipset USB 3.1 xHCI Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 41
Region 0: Memory at d0920000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset SATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: Hewlett-Packard Company 300 Series Chipset SATA Controller
Interrupt: pin B routed to IRQ 60
Region 5: Memory at d0900000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at d0980000 [disabled] [size=512K]
Kernel driver in use: ahci
Kernel modules: ahci
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43b2 (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin C routed to IRQ 32
Bus: primary=01, secondary=02, subordinate=08, sec-latency=0
Memory behind bridge: d0800000-d08fffff
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 33
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: fff00000-000fffff
02:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 35
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 36
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
02:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 37
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
02:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 38
Bus: primary=02, secondary=07, subordinate=07, sec-latency=0
02:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 40
Bus: primary=02, secondary=08, subordinate=08, sec-latency=0
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0e)
Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Interrupt: pin A routed to IRQ 25
Region 0: I/O ports at 3300 [size=256]
Region 2: Memory at d0814000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at d0800000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
05:00.1 Serial controller: Realtek Semiconductor Co., Ltd. Device 816a (rev 0e) (prog-if 02 [16550])
Subsystem: Hewlett-Packard Company Device 8461
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 34
Region 0: I/O ports at 3200 [size=256]
Region 2: Memory at d0815000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at d0804000 (64-bit, non-prefetchable) [size=16K]
05:00.2 Serial controller: Realtek Semiconductor Co., Ltd. Device 816b (rev 0e) (prog-if 02 [16550])
Interrupt: pin C routed to IRQ 24
Region 0: I/O ports at 3100 [size=256]
Region 2: Memory at d0816000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at d0808000 (64-bit, non-prefetchable) [size=16K]
05:00.3 IPMI SMIC interface: Realtek Semiconductor Co., Ltd. Device 816c (rev 0e) (prog-if 01)
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin D routed to IRQ 255
Region 0: I/O ports at 3000 [disabled] [size=256]
Region 2: Memory at d0817000 (64-bit, non-prefetchable) [disabled] [size=4K]
Region 4: Memory at d080c000 (64-bit, non-prefetchable) [disabled] [size=16K]
Kernel modules: ipmi_si
05:00.4 USB controller: Realtek Semiconductor Co., Ltd. Device 816d (rev 0e) (prog-if 20 [EHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin D routed to IRQ 39
Region 0: Memory at d0818000 (32-bit, non-prefetchable) [size=4K]
Region 2: Memory at d0810000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: ehci-pci
09:00.0 Non-Volatile memory controller: Device 1c5c:1327 (prog-if 02 [NVM Express])
Subsystem: Device 1c5c:0000
Latency: 0
Interrupt: pin A routed to IRQ 61
NUMA node: 0
Region 0: Memory at d0700000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
0a:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Vega [Radeon Vega 8 Mobile] (rev d3) (prog-if 00 [VGA controller])
Subsystem: Hewlett-Packard Company Vega [Radeon Vega 8 Mobile]
Latency: 0
Interrupt: pin A routed to IRQ 67
Region 0: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at d0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at 2000 [size=256]
Region 5: Memory at d0600000 (32-bit, non-prefetchable) [size=512K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
0a:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 15de
Subsystem: Hewlett-Packard Company Device 83e7
Latency: 0
Interrupt: pin B routed to IRQ 85
Region 0: Memory at d0688000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0a:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Device 15df
Interrupt: pin C routed to IRQ 255
Region 2: Memory at d0500000 (32-bit, non-prefetchable) [disabled] [size=1M]
Region 5: Memory at d068c000 (32-bit, non-prefetchable) [disabled] [size=8K]
0a:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15e0 (prog-if 30 [XHCI])
Interrupt: pin D routed to IRQ 42
Region 0: Memory at d0300000 (64-bit, non-prefetchable) [size=1M]
0a:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15e1 (prog-if 30 [XHCI])
Interrupt: pin A routed to IRQ 51
Region 0: Memory at d0400000 (64-bit, non-prefetchable) [size=1M]
0a:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Device 15e3
Latency: 0
Interrupt: pin C routed to IRQ 86
Region 0: Memory at d0680000 (32-bit, non-prefetchable) [size=32K]
0b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61) (prog-if 01 [AHCI 1.0])
Subsystem: Hewlett-Packard Company FCH SATA Controller [AHCI mode]
Interrupt: pin A routed to IRQ 64
Region 5: Memory at d0200000 (32-bit, non-prefetchable) [size=2K]
lsmod
Module Size Used by
edac_mce_amd 28672 0
kvm_amd 94208 0
ccp 86016 1 kvm_amd
snd_hda_codec_conexant 24576 1
kvm 626688 1 kvm_amd
snd_hda_codec_generic 73728 1 snd_hda_codec_conexant
snd_hda_codec_hdmi 49152 1
snd_hda_intel 40960 4
snd_hda_codec 126976 4 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel
irqbypass 16384 1 kvm
crct10dif_pclmul 16384 0
crc32_pclmul 16384 0
snd_hda_core 81920 5 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
ghash_clmulni_intel 16384 0
snd_hwdep 20480 1 snd_hda_codec
snd_pcm 98304 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
pcbc 16384 0
snd_seq_midi 16384 0
aesni_intel 200704 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 32768 1 snd_seq_midi
aes_x86_64 20480 1 aesni_intel
snd_seq 65536 2 snd_seq_midi,snd_seq_midi_event
crypto_simd 16384 1 aesni_intel
cryptd 24576 3 crypto_simd,ghash_clmulni_intel,aesni_intel
k10temp 16384 0
input_leds 16384 0
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
glue_helper 16384 1 aesni_intel
hp_wmi 16384 0
snd_timer 32768 2 snd_seq,snd_pcm
serio_raw 16384 0
sparse_keymap 16384 1 hp_wmi
wmi_bmof 16384 0
snd 81920 19 snd_hda_codec_generic,snd_seq,snd_hda_codec_conexant,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm,snd_rawmidi
ipmi_devintf 20480 0
ipmi_msghandler 102400 1 ipmi_devintf
soundcore 16384 1 snd
ucsi_acpi 16384 0
typec_ucsi 32768 1 ucsi_acpi
typec 32768 1 typec_ucsi
mac_hid 16384 0
sch_fq_codel 20480 2
parport_pc 36864 0
ppdev 20480 0
lp 20480 0
parport 49152 3 parport_pc,lp,ppdev
ip_tables 28672 0
x_tables 40960 1 ip_tables
autofs4 40960 2
overlay 94208 1
nls_iso8859_1 16384 1
dm_mirror 24576 0
dm_region_hash 20480 1 dm_mirror
dm_log 20480 2 dm_region_hash,dm_mirror
hid_generic 16384 0
usbhid 49152 0
uas 24576 0
hid 122880 2 usbhid,hid_generic
usb_storage 69632 2 uas
amdkfd 241664 1
amd_iommu_v2 20480 1 amdkfd
amdgpu 2924544 10
chash 16384 1 amdgpu
gpu_sched 24576 1 amdgpu
i2c_algo_bit 16384 1 amdgpu
ttm 110592 1 amdgpu
drm_kms_helper 172032 1 amdgpu
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
psmouse 151552 0
drm 458752 7 gpu_sched,drm_kms_helper,amdgpu,ttm
nvme 36864 0
i2c_piix4 24576 0
nvme_core 77824 1 nvme
ahci 40960 0
r8169 86016 0
mii 16384 1 r8169
libahci 32768 1 ahci
wmi 24576 2 hp_wmi,wmi_bmof
gpio_amdpt 16384 0
video 45056 0
gpio_generic 20480 1 gpio_amdpt
ii opsi-linux-bootimage 20181213-1 all opsi bootimage for netboot tasks.
ii opsi-server 4.1.1.6-1 all opsi server configuration package
ii opsi-tftpd-hpa 5.2.8-49 amd64 HPA's tftp server
ii opsi-utils 4.1.1.27-1 all utilites for working with opsi.
ii opsi-windows-support 4.1.1-5 all Install utilities useful for deploying Windows with opsi.
ii opsiconfd 4.1.1.16-2 all opsi configuration service
ii opsipxeconfd 4.1.1.14-1 all opsi pxe configuration daemon
ii python-opsi 4.1.1.58-1 all opsi python library
Das Fehlerbild tritt nicht bei der HP Serie derzeit auf.
VG Lars
