As written in „Getting started“ manual, I get GPG errors on "Debian 9":
W: GPG error: http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release: The following signatures were invalid: 2371C96FC045365D00729A19520B97144DC87421
W: The repository 'http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
does not work for me..One can bypass this message by using the aptitude parameter --allow-unauthenticated. This parameter has to be used every time aptitude is called. For a permanent solution we recommend to disable the GPG check. This can be done by creating a file 99opsi in the directory /etc/apt/apt.conf.d/ with the following content:
APT::Get::AllowUnauthenticated "true";
Adding options [allow-insecure=yes allow-downgrade-to-insecure=yes] to opsi.list:
deb [allow-insecure=yes allow-downgrade-to-insecure=yes] http://download.opensuse.org/repositori ... Debian_9.0 ./
helps..
What's is the „correct“ way to overcome this issue?
I have tried importing http://download.opensuse.org/repositori ... elease.key into gpg, then exporting to
/usr/share/keyrings/uibmz-archive-keyring.gpg
gpg --export 2371C96FC045365D00729A19520B97144DC87421 > /usr/share/keyrings/uibmz-archive-keyring.gpg
deb [signed-by=/usr/share/keyrings/uibmz-archive-keyring.gpg] http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./
E: The repository 'http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40/Debian_9.0 ./ Release' is not signed.
# gpg /usr/share/keyrings/uibmz-archive-keyring.gpg
pub dsa1024 2010-07-23 [SC] [expires: 2019-04-27]
uid home:uibmz OBS Project <home:uibmz@build.opensuse.org>
# gpg --verify Release.gpg Release
gpg: Signature made Fri 25 Aug 2017 10:14:23 AM EEST
gpg: using DSA key 520B97144DC87421
gpg: Good signature from "home:uibmz OBS Project <home:uibmz@build.opensuse.org>" [ultimate]
