Updated packages for opsi 4.0.7
Beitragvon n.wenselowski » 25 Aug 2017, 13:15
Dear opsi users,
there are updated packages for opsi 4.0.7 in stable.
The packages support the following new distributions:
  • Debian 9
  • openSUSE Leap 42.3
  • SUSE Linux Enterprise Server (SLES) 12 SP2
  • Univention Corporate Server (UCS) 4.2
The opsi apps in the UCS app center have been updated to include current packages.
Installations on the Slave role are now supported through the app center.
The opsi app for UCS 4.2 leaves the preview status.
The new app versions will be available shortly in the UCS app center.
Support for the following distributions ends because they are end-of-life:
  • openSUSE Leap 42.1
  • Ubuntu 12.04 "Precise Pangolin"
  • Univention Corporate Server (UCS) 3.x
  • Univention Corporate Server (UCS) 4.0
We recommend for these distributions to update to a distribution that is still supported.
The package digitec-opsi-listener will not be available through the repositories as it is not maintained anymore.
We recommend switching to the extension opsi-directory-connector which is maintained by uib.
Localboot packages:
  • l-opsi-server 4.0.7.2-3
  • opsi-linux-client-agent 4.0.7.7-2
  • opsi-setup-detector 4.0.6.132-2
Netboot packages:
  • debian 4.0.7.2-3
  • debian8 4.0.7.2-3
  • debian9 4.0.7.2-3
  • opensusel42-3 4.0.7.2-2
  • ubuntu 4.0.7.2-2
  • ubuntu14-04 4.0.7.2-3
  • ubuntu16-04 4.0.7.2-3
  • ucs41 4.0.7.2-2
  • ucs42 4.0.7.2-2
Server packages:
  • opsi-atftpd 0.7.dfsg-7
  • opsi-depotserver 4.0.7.3-1
  • opsi-directory-connector 17-7
  • opsi-linux-bootimage 20170720-1
  • opsi-nagios-plugins 4.0.7.3-1
  • opsi-utils 4.0.7.17-2
  • opsi4ucs 4.0.7.5-1
  • opsiconfd 4.0.7.13-1
  • opsipxeconfd 4.0.7.8-3
  • python-opsi 4.0.7.45-3
With kind regards
Niko Wenselowski
PS: Changelogs:
opsipxeconfd (4.0.7.8-3) stable; urgency=medium
  * Always using the version from the changelog.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 31 Jul 2017 10:24:38 +0200
opsipxeconfd (4.0.7.8-2) stable; urgency=medium
  * systemd: always restart once the service exits.
  * systemd: Dependency to smbd is now soft.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 18 Jul 2017 13:47:23 +0200
opsi-utils (4.0.7.17-2) stable; urgency=medium
  * Updated Spanish and Russian translations.
  * Added Dutch translation.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 07 Aug 2017 13:50:25 +0200
opsi-utils (4.0.7.17-1) stable; urgency=medium
  * opsi-product-updater: Depot connections will use a specific user agent.
  * opsi-package-manager: Setting the default config will be done later
    to avoid problems displaying the help if DNS is broken.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 26 Jul 2017 12:10:34 +0200
python-opsi (4.0.7.45-3) stable; urgency=medium
  * openSuse 42.3: We depend on python-setuptools because python-cryptography
    requires it during runtime but the package from the openSuse repos
    misses that requirement.
    See https://bugzilla.opensuse.org/show_bug.cgi?id=1052927
 -- Niko Wenselowski <n.wenselowski@uib.de>  Wed, 09 Aug 2017 10:35:06 +0200
python-opsi (4.0.7.45-2) stable; urgency=medium
  * Updated Spanish and Russian translation.
  * Updated Russian hwaudit translation.
  * Added Dutch hwaudit translation.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 07 Aug 2017 14:17:14 +0200
python-opsi (4.0.7.45-1) stable; urgency=medium
  * 10_opsi.conf: setProductActionRequestWithDependencies will relay a call
    with actionRequest = 'none' to setProductActionRequest.
  * OPSI.Backend.Backend.ConfigDataBackend: improved log truncation when
    processing unicode characters that use more than one byte.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Thu, 27 Jul 2017 14:02:39 +0200
python-opsi (4.0.7.44-1) experimental; urgency=medium
  * OPSI.Util.Task.Certificate: replaced gendh with dhparam
  * OPSI.Util.Task.Rights: Default access rights for workbench set to 664.
 -- Mathias Radtke <m.radtke@uib.de>  Tue, 25 Jul 2017 14:28:31 +0200
python-opsi (4.0.7.43-2) stable; urgency=medium
  * Debian packaging: Depending on net-tools for ifconfig.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 25 Jul 2017 09:19:10 +0200
python-opsi (4.0.7.43-1) stable; urgency=medium
  * opsihwaudit.conf: Memory clock speed is now handled as a bigint.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 17 Jul 2017 17:35:54 +0200
opsiconfd (4.0.7.13-1) experimental; urgency=medium
  * gendh is obsolete: replaced with dhparam
 -- Mathias Radtke <m.radtke@uib.de>  Tue, 25 Jul 2017 15:56:14 +0200
opsiconfd (4.0.7.12-1) stable; urgency=medium
  * opsi-nagios-connector: checkShortProductStatus added reference version for check in output.
 -- Erol Ueluekmen <e.ueluekmen@uib.de>  Mon, 24 Jul 2017 13:34:42 +0200
opsiconfd (4.0.7.11-5) stable; urgency=medium
 -- Niko Wenselowski <n.wenselowski@uib.de>  Tue, 18 Jul 2017 13:33:39 +0200
opsiconfd (4.0.7.11-4) stable; urgency=medium
  * systemd: Fix typo in service regarding the restart.
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 17 Jul 2017 21:46:07 +0200
opsiconfd (4.0.7.11-3) stable; urgency=medium
 -- Niko Wenselowski <n.wenselowski@uib.de>  Mon, 17 Jul 2017 12:16:09 +0200
opsi-linux-bootimage (20170720-1) testing; urgency=medium
  * serial driver is now modular
 -- Mathias Radtke <m.radtke@uib.de>  Wed, 19 Jul 2017 15:49:02 +0200
opsi-linux-bootimage (20170714-1) experimental; urgency=medium
  * kernel 4.12.1
  * disabled ipmi_watchdog driver
 -- Mathias Radtke <m.radtke@uib.de>  Thu, 13 Jul 2017 15:24:19 +0200
opsi-linux-bootimage (20170713-2) experimental; urgency=medium
  * version bump die to typo in debian/changelog
 -- Mathias Radtke <m.radtke@uib.de>  Thu, 13 Jul 2017 14:38:04 +0200
opsi-linux-bootimage (20170713-1) experimental; urgency=medium
  * disabled watchdog driver
  * added intel_pmc driver
  * added tpm_crb driver
 -- Mathias Radtke <m.radtke@uib.de>  Tue, 11 Jul 2017 14:38:04 +0200
opensusel42-3 (4.0.7.2-2) testing; urgency=medium
  * initial creation
  * UEFI compatible installation
-- Mathias Radtke <m.radtke@uib.de> Mon Apr 03 2017 14:50:00 +0200
debian (4.0.7.2-3) testing; urgency=low
  * corrected NVME + UEFI behaviour
-- Mathias Radtke <m.radtke@uib.de> Wed Jul 19 2017 15:35:00 +0200
debian8 (4.0.7.2-3) testing; urgency=low
  * corrected proxy behaviour
debian9 (4.0.7.2-3) testing; urgency=low
ubuntu (4.0.7.2-2) testing; urgency=low
ubuntu14-04 (4.0.7.2-2) stable; urgency=low
ubuntu16-04 (4.0.7.2-3) testing; urgency=low
ucs41 (4.0.7.2-2) testing; urgency=low
  * corrected NVME behaviour
ucs42 (4.0.7.2-2) testing; urgency=low
  * corrected NVME
ucs42 (4.0.7.2-1) experimental; urgency=low
  * postinst: sudo command may fail -> echo to inform user
  * forked from ucs41
-- Mathias Radtke <m.radtke@uib.de> Thu Mar 16 15:15:00 +0100
l-opsi-server 4.0.7.2-3; testing; urgency=low
  * added debian9 compatability
  * Removed debian6 compatability
  * added OpenSUSE Leap42.3 compatability
-- Mathias Radtke <m.radtke@uib.de> Tue, 25 Jul 2017 07:37:00 +0200
l-opsi-server 4.0.7.2-2; experimental; urgency=low
  * UCS4.2: not installing digitec-listener( not avail.)
-- Mathias Radtke <m.radtke@uib.de> Tue, 11 Jun 2017 15:43:00 +0200
l-opsi-server 4.0.7.2-1; experimental; urgency=low
  * added support for UCS4.2
-- Mathias Radtke <m.radtke@uib.de> Tue, 07 Jun 2017 08:53:00 +0100
