After booting the bootimage from the network in uefi mode and after the first part of the windows 7 installation, the bios boot order for an UEFI harddisk always has the opsitempwinpe with a high priority.
So instead of setting the windows boot manager to the first device the opsitempwinpe partition is started again. (and this gives an error because the drive letters have changed, so it can't find the needed files).
Isn't it supposed to set the boot order to windows boot manager by itself?
uefi bootimage and bios boot order
- SisterOfMercy
Re: uefi bootimage and bios boot order
do you mean that the boot order ins't changed after running through the WinPE installation?
Cheers
Cheers
We have the product opsi-uefi-netboot to set the client to boot from the network first.
This should then boot the first harddisk if not image is presented through netboot iirc.
Kind regards
The tools can change the order which sometimes makes it harder to set up the clients correctly.SisterOfMercy hat geschrieben:Isn't it supposed to set the boot order to windows boot manager by itself?
Kind regards
- SisterOfMercy
Yes.m.radtke hat geschrieben:do you mean that the boot order ins't changed after running through the WinPE installation?
by default the boot order change to boot from the fresh windows partition is done in the setup.exe in the WINPE.
IN your case I would boot up the bootimage again. Then mount the partitions and checkl for logs why the boot order hasn't been changed in the WINPE.
Cheers
Cheers
- SisterOfMercy
Ah! I was looking at the scripts opsi was making for the PE setup, so no wonder I couldn't find it.
