ich versuche schon seit Tagen opsi-wim-capture zum Laufen zu bekommen.
Allerdings bricht er stetig mit Fehlermeldung ab
Ich wäre euch für Hilfe sehr dankbar.
Meine Konfiguration:
DELL Optiplex 3050 (SSD als Festplatte)
Win10-x64 Propertys (Netboot-Produkt):
opsi-wim-capture Propertys:
Fehlermeldung im Log:
Hat Jemand eine Idee?(235) [5] [Mai 09 12:53:34:278] [opsi-wim-capture] comment: handle Rebootflag
(236) [5] [Mai 09 12:53:34:278] [opsi-wim-capture] Set $WinstRegKey$ = "HKLM\SOFTWARE\opsi.org\winst\opsi-wim-capture"
(237) [6] [Mai 09 12:53:34:278] [opsi-wim-capture] The value of the variable "$WinstRegKey$" is now: "HKLM\SOFTWARE\opsi.org\winst\opsi-wim-capture"
(238) [5] [Mai 09 12:53:34:279] [opsi-wim-capture] Set $nowstr$ = takeString(0,shellCall("k:\opsi-wim-capture\nowasdoublestr.exe"))
(239) [5] [Mai 09 12:53:34:279] [opsi-wim-capture] Executing "C:\WINDOWS\\cmd64.exe" /C "k:\opsi-wim-capture\nowasdoublestr.exe"
(240) [6] [Mai 09 12:53:35:586] [opsi-wim-capture] ExitCode 0
(241) [6] [Mai 09 12:53:35:586] [opsi-wim-capture] retrieving strings from shellCall [switch to loglevel 7 for debugging]
(242) [7] [Mai 09 12:53:35:586] [opsi-wim-capture] (string 0)42864.537
(243) [7] [Mai 09 12:53:35:586] [opsi-wim-capture]
(244) [6] [Mai 09 12:53:35:586] [opsi-wim-capture] The value of the variable "$nowstr$" is now: "42864.537"
(245) [5] [Mai 09 12:53:35:587] [opsi-wim-capture] Set $rebootnowstr$ = GetRegistryStringValue32("["+$WinstRegKey$+"] "+"RebootFlag")
(246) [7] [Mai 09 12:53:35:588] [opsi-wim-capture] Registry started readonly
(247) [7] [Mai 09 12:53:35:588] [opsi-wim-capture] Registry started with redirection (32 Bit)
(248) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] Info: Registry key [HKLM\SOFTWARE\opsi.org\winst\opsi-wim-capture] could not be opened by RegOpenKeyEx, Errorno 2 "Das System kann die angegebene Datei nicht finden.<"
(249) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] The value of the variable "$rebootnowstr$" is now: ""
(250) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] Set $RebootFlag$ = ""
(251) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] The value of the variable "$RebootFlag$" is now: ""
(252) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] If
(253) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] "" = $rebootnowstr$ <<< result true
(254) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] not ("" = $rebootnowstr$) <<< result false
(255) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] Then
(256) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] If
(257) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] Then
(258) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] If
(259) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] Then
(260) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] EndIf
(261) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] EndIf
(262) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] EndIf
(263) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] comment: get product properties ...
(264) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] Set $force_imagex$ = GetProductProperty("force_imagex","true")
(265) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] The value of the variable "$force_imagex$" is now: "True"
(266) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] Set $startcapture$ = GetProductProperty("startcapture","true")
(267) [6] [Mai 09 12:53:35:589] [opsi-wim-capture] The value of the variable "$startcapture$" is now: "True"
(268) [5] [Mai 09 12:53:35:589] [opsi-wim-capture] Set $always_backup_before_sysprep$ = GetProductProperty("always_backup_before_sysprep","true")
(269) [6] [Mai 09 12:53:35:590] [opsi-wim-capture] The value of the variable "$always_backup_before_sysprep$" is now: "True"
(270) [5] [Mai 09 12:53:35:590] [opsi-wim-capture] Set $abort_on_no_backup$ = GetProductProperty("abort_on_no_backup","true")
(271) [4] [Mai 09 12:53:35:590] [opsi-wim-capture] Property not existing in GetProductProperty - using default
(272) [6] [Mai 09 12:53:35:590] [opsi-wim-capture] The value of the variable "$abort_on_no_backup$" is now: "true"
(273) [5] [Mai 09 12:53:35:590] [opsi-wim-capture] Set $clonezilla_imagefile_org$ = GetProductProperty("clonezilla_imagefile","auto")
(274) [6] [Mai 09 12:53:35:590] [opsi-wim-capture] The value of the variable "$clonezilla_imagefile_org$" is now: "auto"
(275) [5] [Mai 09 12:53:35:590] [opsi-wim-capture] Set $target_product$ = getProductProperty("target_product","")
(276) [6] [Mai 09 12:53:35:590] [opsi-wim-capture] The value of the variable "$target_product$" is now: "win10-x64-captured"
(277) [5] [Mai 09 12:53:35:590] [opsi-wim-capture] Set $verify_clonezilla_images$ = getProductProperty("verify_clonezilla_images","never")
(278) [6] [Mai 09 12:53:35:590] [opsi-wim-capture] The value of the variable "$verify_clonezilla_images$" is now: "never"
(279) [5] [Mai 09 12:53:35:590] [opsi-wim-capture] Set $imagename$ = getProductProperty("imagename","capture")
(280) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] The value of the variable "$imagename$" is now: "capture"
(281) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] If
(282) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] lower($clonezilla_imagefile_org$) = "auto" <<< result true
(283) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] $clonezilla_imagefile_org$ = "" <<< result false
(284) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] ($clonezilla_imagefile_org$ = "") <<< result false
(285) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] (lower($clonezilla_imagefile_org$) = "auto") or ($clonezilla_imagefile_org$ = "") <<< result true
(286) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] Then
(287) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] Set $clonezilla_imagefile$ = "lke-002.test"+$target_product$+"_"+$imagename$
(288) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] The value of the variable "$clonezilla_imagefile$" is now: "lke-002.test_win10-x64-captured_capture"
(289) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] Else
(290) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] If
(291) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] Then
(292) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] Else
(293) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] EndIf
(294) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] EndIf
(295) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] If
(296) [5] [Mai 09 12:53:35:591] [opsi-wim-capture] runningOnUefi <<< result false
(297) [6] [Mai 09 12:53:35:591] [opsi-wim-capture] Then
(298) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] Else
(299) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] Set $useGpt$ = "false"
(300) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] The value of the variable "$useGpt$" is now: "false"
(301) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] EndIf
(302) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] If
(303) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] $always_backup_before_sysprep$ ="true" <<< result true
(304) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] ($always_backup_before_sysprep$ ="true" ) <<< result true
(305) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] Then
(306) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] If
(307) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] $RebootFlag$ = "1" <<< result false
(308) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] not ($RebootFlag$ = "1") <<< result true
(309) [6] [Mai 09 12:53:35:592] [opsi-wim-capture] Then
(310) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] comment: Part before first Reboot
(311) [5] [Mai 09 12:53:35:592] [opsi-wim-capture] message Check for WinPE Partition ....
(312) [5] [Mai 09 12:53:35:594] [opsi-wim-capture] Set $diskpartscript$ = "c:\opsi.org\tmp\check_winpe.txt"
(313) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] The value of the variable "$diskpartscript$" is now: "c:\opsi.org\tmp\check_winpe.txt"
(314) [5] [Mai 09 12:53:35:594] [opsi-wim-capture] Set $diskpartlist$ = emptylist($diskpartlist$)
(315) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from $diskpartlist$ [switch to loglevel 7 for debugging]
(316) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(317) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from emptylist [switch to loglevel 7 for debugging]
(318) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(319) [5] [Mai 09 12:53:35:594] [opsi-wim-capture] Set $diskpartlist$ = addtolist($diskpartlist$,"select disk 0")
(320) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from $diskpartlist$ [switch to loglevel 7 for debugging]
(321) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(322) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from addtolist [switch to loglevel 7 for debugging]
(323) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 0)select disk 0
(324) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(325) [5] [Mai 09 12:53:35:594] [opsi-wim-capture] Set $diskpartlist$ = addtolist($diskpartlist$,"list partition")
(326) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from $diskpartlist$ [switch to loglevel 7 for debugging]
(327) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 0)select disk 0
(328) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(329) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from addtolist [switch to loglevel 7 for debugging]
(330) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 0)select disk 0
(331) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 1)list partition
(332) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(333) [5] [Mai 09 12:53:35:594] [opsi-wim-capture] Set $diskpartlist$ = addtolist($diskpartlist$,"exit")
(334) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from $diskpartlist$ [switch to loglevel 7 for debugging]
(335) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 0)select disk 0
(336) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 1)list partition
(337) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(338) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] retrieving strings from addtolist [switch to loglevel 7 for debugging]
(339) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 0)select disk 0
(340) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 1)list partition
(341) [7] [Mai 09 12:53:35:594] [opsi-wim-capture] (string 2)exit
(342) [7] [Mai 09 12:53:35:594] [opsi-wim-capture]
(343) [6] [Mai 09 12:53:35:594] [opsi-wim-capture] If
(344) [6] [Mai 09 12:53:35:595] [opsi-wim-capture] retrieving strings from $diskpartlist$ [switch to loglevel 7 for debugging]
(345) [7] [Mai 09 12:53:35:595] [opsi-wim-capture] (string 0)select disk 0
(346) [7] [Mai 09 12:53:35:595] [opsi-wim-capture] (string 1)list partition
(347) [7] [Mai 09 12:53:35:595] [opsi-wim-capture] (string 2)exit
(348) [7] [Mai 09 12:53:35:595] [opsi-wim-capture]
(349) [7] [Mai 09 12:53:35:595] [opsi-wim-capture] Save to file with encoding: system
(350) [6] [Mai 09 12:53:35:596] [opsi-wim-capture] c:\opsi.org\tmp\check_winpe.txt saved back with encoding: system
(351) [5] [Mai 09 12:53:35:596] [opsi-wim-capture] saveTextFile($diskpartlist$, $diskpartscript$) <<< result true
(352) [5] [Mai 09 12:53:35:596] [opsi-wim-capture] not (saveTextFile($diskpartlist$, $diskpartscript$)) <<< result false
(353) [6] [Mai 09 12:53:35:596] [opsi-wim-capture] Then
(354) [6] [Mai 09 12:53:35:596] [opsi-wim-capture] EndIf
(355) [5] [Mai 09 12:53:35:596] [opsi-wim-capture] Set $resultlist$ = GetOutStreamFromSection("ShellInAnIcon_diskpart winst /sysnative")
(356) [5] [Mai 09 12:53:35:597] [opsi-wim-capture]
(357) [5] [Mai 09 12:53:35:597] [opsi-wim-capture] ShellInAnIcon_diskpart
(358) [7] [Mai 09 12:53:35:597] [opsi-wim-capture] Save to file with encoding: system
(359) [6] [Mai 09 12:53:35:598] [opsi-wim-capture] c:\opsi.org\tmp\_opsiscript_Yj61Mb12.cmd saved back with encoding: system
(360) [6] [Mai 09 12:53:35:598] [opsi-wim-capture] Executing "C:\WINDOWS\\cmd64.exe" /C c:\opsi.org\tmp\_opsiscript_Yj61Mb12.cmd
(361) [6] [Mai 09 12:53:36:805] [opsi-wim-capture] ExitCode 0
(362) [6] [Mai 09 12:53:36:805] [opsi-wim-capture]
(363) [6] [Mai 09 12:53:36:805] [opsi-wim-capture] output:
(364) [6] [Mai 09 12:53:36:805] [opsi-wim-capture] --------------
(365) [6] [Mai 09 12:53:36:805] [opsi-wim-capture]
(366) [6] [Mai 09 12:53:36:805] [opsi-wim-capture] C:\WINDOWS\system32>diskpart /s "c:\opsi.org\tmp\check_winpe.txt"
(367) [6] [Mai 09 12:53:36:805] [opsi-wim-capture]
(368) [6] [Mai 09 12:53:36:805] [opsi-wim-capture] Microsoft DiskPart-Version 10.0.15063.0
(369) [6] [Mai 09 12:53:36:805] [opsi-wim-capture]
(370) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Copyright (C) Microsoft Corporation.
(371) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Auf Computer: LKE-002
(372) [6] [Mai 09 12:53:36:806] [opsi-wim-capture]
(373) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Datenträger 0 ist jetzt der gewählte Datenträger.
(374) [6] [Mai 09 12:53:36:806] [opsi-wim-capture]
(375) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Partition ### Typ Größe Offset
(376) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] ------------- ---------------- ------- -------
(377) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Partition 1 Primär 233 GB 1024 KB
(378) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Partition 2 Wiederherstellun 450 MB 233 GB
(379) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Partition 3 OEM 4000 MB 234 GB
(380) [6] [Mai 09 12:53:36:806] [opsi-wim-capture]
(381) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] Datenträgerpartitionierung wird beendet...
(382) [6] [Mai 09 12:53:36:806] [opsi-wim-capture]
(383) [6] [Mai 09 12:53:36:806] [opsi-wim-capture] C:\WINDOWS\system32>exit 0
(384) [6] [Mai 09 12:53:36:806] [opsi-wim-capture]
(385) [7] [Mai 09 12:53:36:807] [opsi-wim-capture] The file: c:\opsi.org\tmp\_opsiscript_Yj61Mb12.cmd has been deleted
(386) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] Delete "c:\opsi.org\tmp\_opsiscript_*"
(387) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] Search "c:\opsi.org\tmp\"
(388) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] Search "c:\opsi.org\tmp\_opsiscript_*"
(389) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] File "c:\opsi.org\tmp\_opsiscript_Nq24Fl59.cmd"
(390) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] The file is 1 day(s) old, no deletion
(391) [6] [Mai 09 12:53:36:807] [opsi-wim-capture] retrieving strings from GetOutStreamFromSection [switch to loglevel 7 for debugging]
(392) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 0)
(393) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 1)C:\WINDOWS\system32>diskpart /s "c:\opsi.org\tmp\check_winpe.txt"
(394) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 2)
(395) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 3)Microsoft DiskPart-Version 10.0.15063.0
(396) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 4)
(397) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 5)Copyright (C) Microsoft Corporation.
(398) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 6)Auf Computer: LKE-002
(399) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 7)
(400) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 8)Datenträger 0 ist jetzt der gewählte Datenträger.
(401) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 9)
(402) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 10) Partition ### Typ Größe Offset
(403) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 11) ------------- ---------------- ------- -------
(404) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 12) Partition 1 Primär 233 GB 1024 KB
(405) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 13) Partition 2 Wiederherstellun 450 MB 233 GB
(406) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 14) Partition 3 OEM 4000 MB 234 GB
(407) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 15)
(408) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 16)Datenträgerpartitionierung wird beendet...
(409) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 17)
(410) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 18)C:\WINDOWS\system32>exit 0
(411) [7] [Mai 09 12:53:36:808] [opsi-wim-capture]
(412) [5] [Mai 09 12:53:36:808] [opsi-wim-capture] Set $exitcode$ = getLastExitcode
(413) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] The value of the variable "$exitcode$" is now: "0"
(414) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] If
(415) [5] [Mai 09 12:53:36:808] [opsi-wim-capture] $exitcode$ = "0" <<< result true
(416) [5] [Mai 09 12:53:36:808] [opsi-wim-capture] not ($exitcode$ = "0") <<< result false
(417) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] Then
(418) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] EndIf
(419) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] If
(420) [6] [Mai 09 12:53:36:808] [opsi-wim-capture] retrieving strings from $resultlist$ [switch to loglevel 7 for debugging]
(421) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 0)
(422) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 1)C:\WINDOWS\system32>diskpart /s "c:\opsi.org\tmp\check_winpe.txt"
(423) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 2)
(424) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 3)Microsoft DiskPart-Version 10.0.15063.0
(425) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 4)
(426) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 5)Copyright (C) Microsoft Corporation.
(427) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 6)Auf Computer: LKE-002
(428) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 7)
(429) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 8)Datenträger 0 ist jetzt der gewählte Datenträger.
(430) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 9)
(431) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 10) Partition ### Typ Größe Offset
(432) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 11) ------------- ---------------- ------- -------
(433) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 12) Partition 1 Primär 233 GB 1024 KB
(434) [7] [Mai 09 12:53:36:808] [opsi-wim-capture] (string 13) Partition 2 Wiederherstellun 450 MB 233 GB
(435) [7] [Mai 09 12:53:36:809] [opsi-wim-capture] (string 14) Partition 3 OEM 4000 MB 234 GB
(436) [7] [Mai 09 12:53:36:809] [opsi-wim-capture] (string 15)
(437) [7] [Mai 09 12:53:36:809] [opsi-wim-capture] (string 16)Datenträgerpartitionierung wird beendet...
(438) [7] [Mai 09 12:53:36:809] [opsi-wim-capture] (string 17)
(439) [7] [Mai 09 12:53:36:809] [opsi-wim-capture] (string 18)C:\WINDOWS\system32>exit 0
(440) [7] [Mai 09 12:53:36:809] [opsi-wim-capture]
(441) [5] [Mai 09 12:53:36:809] [opsi-wim-capture] "" = takeFirstStringContaining($resultlist$, "Partition 2 OEM") <<< result true
(442) [6] [Mai 09 12:53:36:809] [opsi-wim-capture] Then
(443) [3] [Mai 09 12:53:36:809] [opsi-wim-capture] Error: No WinPE Partition found as expected. Install Windows with Property: preserve_winpe_partition=true
(444) [2] [Mai 09 12:53:36:809] [opsi-wim-capture] Error level set to fatal
(445) [5] [Mai 09 12:53:36:809] [opsi-wim-capture] Process aborted
(446) [1] [Mai 09 12:53:36:809] [opsi-wim-capture] ___________________
(447) [1] [Mai 09 12:53:36:809] [opsi-wim-capture] script finished: success
(448) [1] [Mai 09 12:53:36:809] [opsi-wim-capture] 1 error
(449) [1] [Mai 09 12:53:36:809] [opsi-wim-capture] 1 warning
Liebe Grüße
