currently investigating opsi. Have one windows 7 test client that already existed in the opsi config editor. Hardware information, software information is empty. How can I force an update on the client from the config editor to get this data?
Thanks,
Arie De Derde.
call HW scan manually
Re: call HW scan manually
you just have to set action request for the product hwaudit resp. swaudit to setup and restart or initiate a "on_demand"-event (e.g. via the context menu in the product table)
Enjoy
Rupert
Enjoy
Rupert
Hi Rupert,
I have been scanning the manual on how to set this, but I can't find it. Can you please tell me where and how to set this?
Thanks in advance,
Arie.
Thanks in advance,
Arie.
have you deployed the opsi-client-agent? If not, please check the first steps in opsi-getting-started manual.
Hi Arie,
Kind regards
It can be found in the getting started here.ariedederde hat geschrieben:I have been scanning the manual on how to set this, but I can't find it. Can you please tell me where and how to set this?
Kind regards
