any tip how to costumize the Software on demand
Any tip how to customize the Software on demand page. Thank you.
Re: any tip how to costumize the Software on demand
Customize to corporate identity
The look of the software-on-demand module can be customized to the companies corporate identity. Therefore the
file opsiclientd.css has to be customized. It lies under:
c:\program files\opsi.org\opsi-client-agent\opsiclientd\static_html
It can be edited and then reloaded. The changes have to be copied to the server to remain with new opsi-client-agent
installations. Copy the CSS-file and perhaps a file with the companies logo to the server directory:
/var/lib/opsi/depot/opsi-client-agent/files/opsi/dist/opsiclientd/static_html
To avoid errors, we recommend to set rights after changing the configuration.
the new sod-client can also be configured.
Please refer to the corresponding chapter in the manual for more information on what and how it can be changed.
Kind regards
Kind regards
Thanks a lot Niko
Hi, is it possible to categorize the software posted in software-on-demand? or possibly add a search box and search button ? Can't find it in the manual.
for categorisation you can use multiple product groups.
A search box isn't currently available.
Kind regards
Kind regards
Hi rmtevesjr ,
you could include a keyword with the description of your software packages ; the fields 'description' and 'advice' of are being searched when entering keywords into the box, too.
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
The OPSI Client Kiosk solved the software category since it displays the product group included in the software on demand. I want to change the front page/main screen of the OPSI Client KIOSK. I was able to change the images for notifier but the home screen didn't changed.
if you have just changed the images on the depot you need to re-deploy.
For better help we need more infos about what you did.
Kind regards
Kind regards
Hi Niko,
I changed the images in the folder opsi-client-agent on the server but if I install the agent the images didn't take effect. I think it's getting the image somewhere else. Do I need to recompile the opsi-client-kiosk? Thanks
On figure 12.1 in the release notes, I want to change the #1 and the OPSI logo at the lower left of the new KIOSK GUI. Thank you.
https://download.uib.de/opsi4.0/doc/htm ... notes.html
