On 17.02.2017 the key of download.opensuse.org had expired. The key valid perio had been automatically extended. You may experience issues with Debian/Ubuntu and UCS at the moment. Even if you obtain the key as described in opsi-getting-started, it can still occur that you receive the old key. Should that happend, we have stored the Release.key for our repositories on download.uib.de.
For Debian / Ubuntu / UCS please follow this procedure:
Import the key:
wget -O - http://download.uib.de/opsi4.0/Release.key | apt-key add -
apt-key list
Pub 1024D / 4DC87421 2010-07-23 [expires: 2019-04-27]
Uid home: uibmz OBS Project <home: uibmz@build.opensuse.org>
apt-key del 4DC87421
For RPM-based distributions, the key should be automatically updated. Still, in the case you experience issues with the mirrors. You can solve the problem on your distribution, following this steps:
Download the new key:
wget http://download.uib.de/opsi4.0/Release.key
rpm --import Release.key
Report of Weak-Keys under Ubuntu 16.04:
It is not possible for us to influence the hashing from outside. As mentioned before, we experiment with own build instances and our own repositories. Therefore it was decided not to re-create the current key. As soon as we have another type of solution for this, we'll report back to you. The warning about the key will continue to appear.
As always, kind regards,
Martin Scalese
