seit ein paar Tagen habe ich auf einigen Rechnern (nicht auf allen) ein Problem mit dem Paket swaudit.
Die Installation läuft durch, anscheinend ohne Fehler auf dem Client, wird aber als FAILED im Config Editor angezeigt.
Ende vom INSTALL-LOG:
(14697) [5] [Sep 02 14:57:48:390] [swaudit] Execution of OpsiServiceHashList_auditSoftware_createObjects
(14698) [3] [Sep 02 14:57:50:703] [swaudit] Error: retrieveJSONObject --- opsi service problem ----> unexpected Result from webservice in retrieveJSONObject, number of lines: 0-> retrieveJSONObject:1: Stream read error
(14699) [3] [Sep 02 14:57:50:703] [swaudit] Exception in CreateAndProcessScript: Handling AktionslisteList index (0) out of bounds
(14700) [1] [Sep 02 14:57:50:703] [swaudit] ___________________
(14701) [1] [Sep 02 14:57:50:703] [swaudit] script finished
(14702) [1] [Sep 02 14:57:50:718] [swaudit] 0 errors
(14703) [1] [Sep 02 14:57:50:718] [swaudit] 2323 warnings
(14704) [1] [Sep 02 14:57:50:718] [swaudit]
(14705) [1] [Sep 02 14:57:50:718] [swaudit] installed product: swaudit Version: 4.0.6-2
(14706) [1] [Sep 02 14:57:50:718] [swaudit]
(14707) [5] [Sep 02 14:57:50:718] [swaudit] We do not look for a update script, because the setup script is failed
(14708) [5] [Sep 02 14:57:51:218] -------- submitted part of log file ends here, see the rest of log file on client ----------
(3995) [2] [Sep 02 14:50:08] Traceback: (Logger.py|753)
(3996) [2] [Sep 02 14:50:08] File "/usr/lib/python2.7/dist-packages/OPSI/Service/Worker.py", line 292, in _errback
(3997) failure.raiseException()
(3998) (Logger.py|753)
(3999) [2] [Sep 02 14:50:08] File "<string>", line 2, in raiseException
(4000) (Logger.py|753)
(4001) [2] [Sep 02 14:50:08] ==>>> Opsi bad rpc error: Failed to decode rpc: Invalid control character at: line 1 column 46063 (char 46062) (Worker.py|298)
(4002) [2] [Sep 02 14:50:08] Traceback: (Logger.py|753)
(4003) [2] [Sep 02 14:50:08] File "/usr/lib/python2.7/dist-packages/OPSI/Service/Worker.py", line 292, in _errback
(4004) failure.raiseException()
(4005) (Logger.py|753)
(4006) [2] [Sep 02 14:50:08] File "<string>", line 2, in raiseException
(4007) (Logger.py|753)
(4008) [2] [Sep 02 14:50:08] ==>>> Opsi bad rpc error: Failed to decode rpc: Invalid control character at: line 1 column 46063 (char 46062) (Worker.py|298)
ii opsi-atftpd 0.7.dfsg-6 amd64 advanced TFTP server - opsi version with pcre, fifo and max-blksize patches
ii opsi-configed 4.0.7.1.3-1 all OPSI config editor
ii opsi-depotserver 4.0.6.7-2 all opsi depotserver configuration package
ii opsi-linux-bootimage 20160706-1 amd64 opsi bootimage for netboot tasks.
ii opsi-utils 4.0.7.5-1 all utilites for working with opsi.
ii opsiconfd 4.0.7.4-1 all opsi configuration service
ii opsipxeconfd 4.0.7.1-1 all opsi pxe configuration daemon
ii python-opsi 4.0.7.17-1 all opsi python library
Über eine kleine Hilfe was ich noch testen oder tun kann bin ich sehr dankbar.
Vielen Dank
Alfred
