ich habe bei manchen Rechnern ein Deploy Problem.
Was sagt der Fehler aus?
Das Client Betriebssystem ist Windows 7 Prof 64 Bit.
root@opsi:/var/lib/opsi/depot/opsi-client-agent# ./opsi-deploy-client-agent -v -v -u "domain.intra\admin" PC01
[info] * BackendManager is creating BackendDispatcher
[info] Backend context was set to <OPSI.Backend.BackendManager.BackendManager instance at 0xb67256cc>
[info] Loading dispatch config file '/etc/opsi/backendManager/dispatch.conf'
[info] Loading backend config '/etc/opsi/backends/file.conf'
[info] Backend context was set to <OPSI.Backend.BackendManager.BackendDispatcher instance at 0xb68b274c>
[info] Loading backend config '/etc/opsi/backends/mysql.conf'
[info] Creating ConnectionPool instance
[warning] Failed to read opsi modules file '/etc/opsi/modules': [Errno 2] No such file or directory: u'/etc/opsi/modules'
[notice] Disabling mysql backend and license management module: no customer in modules file
[info] Loading backend config '/etc/opsi/backends/opsipxeconfd.conf'
[info] * BackendManager is creating ExtendedConfigDataBackend
[info] Setting context to backend <OPSI.Backend.Backend.ExtendedConfigDataBackend instance at 0xb5fc84cc>
[notice] Starting deployment to host 'pc01.domain.intra'
[notice] Querying for ip address of host 'pc01.domain.intra'
[info] Getting host 'pc01.domain.intra' by name
[notice] Got ip address '192.168.1.222' from syscall
[notice] Pinging host 192.168.1.222 ...
[info] Executing: ping -q -c2 192.168.1.222
[info] Using encoding 'UTF-8'
[notice] Host 192.168.1.222 is up
[notice] Getting hardware ethernet address of host 'pc01.domain.intra'
[notice] Found hardware ethernet address '00:aa:bb:cc:dd:ee'
[notice] Testing winexe
[info] Executing: ./winexe -U 'domain.intra\admin%*** confidential ***' //pc01 'cmd.exe /C "del /s /q c:\tmp\opsi-client-agent_inst && rmdir /s /q c:\tmp\opsi-client-agent_inst || echo not found"'
[info] Winexe failure 'Command './winexe -U 'domain.intra\admin%*** confidential ***' //pc01 'cmd.exe /C "del /s /q c:\tmp\opsi-client-agent_inst && rmdir /s /q c:\tmp\opsi-client-agent_inst || echo not found"'' failed (1):
dos charset 'CP850' unavailable - using ASCII
ERROR: Failed to open connection - NT_STATUS_UNEXPECTED_NETWORK_ERROR', retrying
[error] Deployment to 'pc01.domain.intra' failed: Failed to execute command on host 'pc01': winexe error: Command './winexe -U 'domain.intra\admin%*** confidential ***' //pc01 'cmd.exe /C "del /s /q c:\tmp\opsi-client-agent_inst && rmdir /s /q c:\tmp\opsi-client-agent_inst || echo not found"'' failed (1):
PS: Hat sich erledigt. Hab den Client Rebootet, danach kam der Fehler nicht mehr.
- Cerberus
