Opsi Winst not installed on client
Zakyl
Beitrag von Zakyl »
Hello,
Some OPSI clients doesn't have the "opsi-winst" product installed (opsi-client-agent is installed), and I can't put the action to "setup" for this clients. I don't know why and how is it happened.
Is it a problem for the software deployment ? If yes, how can I do to deploy it again ? Did I need to deploy the "opsi-client-agent" again ?
Thanks for your answer ! ;)
ueluekmen
Re: Opsi Winst not installed on client
Beitrag von ueluekmen »
opsi-winst has no setup-switch. That's a feature not a bug. The opsi-client-agent will upgrade or downgrade the opsi-winst automatically, when a productAction Task for a product is set for the client.
Upgrade the winst on server. Set swaudit for example on setup for this client. Reboot the client and you will see in the instlog.txt, that the opsi-winst are upgraded before the installation of the product has start.
Zakyl
Beitrag von Zakyl »
Thanks for this explanations
I tried the opsi-product-updater command but it seems I have all packages up to date (no entry after the execution of the command), did I need to wait an update ? ^^
Edit : I have opsi-winst 4.11.3.6
bmsoft
Beitrag von bmsoft »
I reread your original post. Is anything not working on the client? Can you deploy software in general and to this client?
ueluekmen
can you deploy software? Please set a actionRequest for the client and check the instlog.txt on the top which opsi-winst Version are used for software deploy.
Zakyl
Beitrag von Zakyl »
The deployment is ok, but "opsi-winst" product is still not on "installed" status
instlog.txt
[1] [mai 28 16:06:27:930] opsi-winst 4.11.3.6 started at >>28/05/2013 16:06:26
[1] [mai 28 16:06:27:930] startmessage opsi-winst created at CentralForm.FormCreate: 28/05/2013 16:06:26
ueluekmen
Have you reloaded your configed completely? (Refresh button on left top not reload task over the contextmenu)
Zakyl
Beitrag von Zakyl »
I just did it, nothing happened, same configuration for opsi-winst
ueluekmen
Then you have to check the opsiclientd.log on C:\tmp on Client or clientconnect log in configed. Have a look to upgrade process from opsi-winst (Actionprocessor).
Zakyl
Beitrag von Zakyl »
I didn't find in the documentation the "Actionprocessor" process, can you explain to me please ?
I didn't see something wrong in log files ..
Only in the Opsiconfd logfile (in /configed) there is an error, but this is for all my clients (Clients which have winst and some they don't have)
[4] [May 15 11:02:14] Failed to read opsi modules file '/etc/opsi/modules': [Errno 2] No such file or directory: u'/etc/opsi/modules' (Backend.py|371)
