shade hat geschrieben:This is weird, I tried another PC that installed just fine with OPSI (just with some drivers missing in Windows) before I began to integrate drivers.
Now it have the same problem, so I tried removing ALL driverpack from OPSI to get back to square 1 - but the problem did not go away, now all our test computers can't install OS via OPSI.
EDIT:
After a pause, I tried to pull the power on the test clients (not power button) and waited a few minutes, and then I tried again - now the client does REQUEST IP and it works.
I just don't understand where it went wrong, has a driver been "sick" and why does the power need to be pulled for it to work again
WIndows PE and drivers are very mysterious
I Think the best way is to use the byAudit feature (look in the release notes of the latest opsi version)
You should move tested drivers to preffered directory.
The newest version of the show_driver will show you if there are more than one driver for this hardware.
exlude the driver and try an other driver.
be careful: don't mix x86 and x64 drivers !
