Hi all,
when I want to make an image of my post with ntfs_write_image, I get an error u '/ etc / ssh / ssh_host_rsa_key.pub
Is that it causes someone?? a problem with ssh or key cert ??
FYI, I did not use the VM version, I just installed completely on a Debian.
Thank you.
Error SSH
Re: Error SSH
Please try:
and try to again to write the image.
regards
e. ueluekmen
Please try:
opsi-setup --set-rights
regards
e. ueluekmen
Re: Error SSH
Hi and thank you,
but it does not work.
I already tried but I tried again all the same.
Phil.
Phil.
Re: Error SSH
are the sshd running? Can you open connection to ssh-server?
Please post the full errormessage.
You can try to set the pcpatch-Password again:
opsi-setup -d task setPcpatchPassword
Re: Error SSH
I have no service sshd works.
the error that appears is "u '/ etc / ssh / ssh_host_rsa_key.pub" and nothing else on the screen.
I can not take the hand ssh with putty.
I thought ssh is installed at the same time that opsi.
the command "opsi-setup -d task setPcpatchPassword" doesn't work.
against by this command "opsi-admin -d task setPcpatchPassword" works but it does not change.
Thanks, Phil.
Thanks, Phil.
Re: Error SSH
Please try:
my fault, sorry... my fingers are sometimes faster then my brainarthie hat geschrieben:the command "opsi-setup -d task setPcpatchPassword" doesn't work.
Thats not a direct dependency for opsi, because opsi don't use this service generally. But normally the first thing you will bring to fly on a linux-system is sshdarthie hat geschrieben:I can not take the hand ssh with putty.
Please try:
apt-get install openssh-server
