opsiconfd startet nach update nicht mehr
Moin.
Nach update auf Version 4.0.2.1-1.1 startet opsiconfd nicht mehr:
[root@opsimaster log]# service opsiconfd start
Starting opsi config service..Traceback (most recent call last):
File "/usr/bin/opsiconfd", line 12, in ?
from opsiconfd.opsiconfd import main
File "/usr/lib/python2.4/site-packages/opsiconfd/opsiconfd.py", line 83, in ?
from omb import MessageBusService, OpsiconfdHTTPFactory, OpsiconfdHTTPChannel
File "/usr/lib/python2.4/site-packages/opsiconfd/omb.py", line 35, in ?
import hashlib, base64, random
ImportError: No module named hashlib
.......... (failed).
System ist ein CentOS 5.7, das bisher recht schmerzfrei mit OPSI harmonierte.
Installierte Updates zwischen 'Geht' und 'Geht nicht mehr':
Jun 12 11:27:45 Updated: python-opsi-4.0.2.1-1.1.noarch
Jun 12 11:27:48 Updated: opsi-utils-4.0.2.1-1.1.noarch
Jun 12 11:27:53 Updated: opsipxeconfd-4.0.2.1-1.1.noarch
Jun 12 11:28:12 Updated: xulrunner-10.0.5-1.el5_8.i386
Jun 12 11:28:26 Updated: firefox-10.0.5-1.el5.centos.i386
Jun 12 11:29:05 Installed: kernel-2.6.18-308.8.1.el5.i686
Jun 12 11:29:13 Updated: tzdata-2012c-1.el5.i386
Jun 12 11:29:17 Updated: tzdata-java-2012c-1.el5.i386
Jun 12 11:29:21 Updated: openssl-0.9.8e-22.el5_8.4.i686
Jun 12 11:29:24 Updated: 1:openoffice.org-ure-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:06 Updated: 1:openoffice.org-core-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:07 Updated: 30:bind-libs-9.3.6-20.P1.el5_8.1.i386
Jun 12 11:30:11 Updated: 1:net-snmp-libs-5.3.2.2-17.el5_8.1.i386
Jun 12 11:30:15 Updated: 1:openoffice.org-calc-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:17 Updated: postgresql-libs-8.1.23-4.el5_8.i386
Jun 12 11:30:20 Updated: 1:net-snmp-5.3.2.2-17.el5_8.1.i386
Jun 12 11:30:21 Updated: 30:bind-utils-9.3.6-20.P1.el5_8.1.i386
Jun 12 11:30:22 Updated: 1:openoffice.org-draw-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:23 Updated: 1:openoffice.org-math-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:24 Updated: 1:openoffice.org-graphicfilter-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:27 Updated: 1:openoffice.org-writer-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:29 Updated: 1:openoffice.org-impress-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:33 Updated: httpd-2.2.3-65.el5.centos.i386
Jun 12 11:30:36 Updated: binutils-2.17.50.0.6-20.el5_8.3.i386
Jun 12 11:30:38 Updated: 2:tar-1.15.1-32.el5_8.i386
Jun 12 11:30:51 Updated: opsiconfd-4.0.2.1-1.1.i386
Jun 12 11:30:53 Updated: 1:openoffice.org-xsltfilter-3.1.1-19.10.el5_8.3.i386
Jun 12 11:30:59 Updated: opsi-depotserver-4.0.2.1-1.1.noarch
Wenn jemand eine hilfreiche Idee hat....
Re: opsiconfd startet nach update nicht mehr
schonmal die üblichen Befehle wie
opsi-setup --init-current-config ausprobiert?
sorry ist ein bug in den CentOS Paketen- fix ist in arbeit ...
gruß
gruß
http://www.opsi.org
http://www.opsi.org
Danke für die Rückmeldung.
War schon drauf und dran die Maschine neu zu installieren....
Gruß aus Mainz nach Mainz
hab mal wieder ein update vom opsi gemacht und nu hab ich ebenfalls obenbeschriebenes Problem.
Gibt es schon eine Lösung?
Björn
Björn
Centos 6
Opsi 4.0.4
Opsi 4.0.4
Guten Morgen,
sorry ich will nicht nerven aber ist schon etwas bekannt, was wir CentOS user machen können, damit Opsi wieder läuft?
Björn
Björn
Centos 6
Opsi 4.0.4
Opsi 4.0.4
soweit ich das sehe,
ist das Problem in den Paketen gefixed, welche derzeit in den experimental repositories liegen:
http://download.opensuse.org/repositori ... noarch.rpm
Selbige werden wohl in den nächsten Tagen Ihren Weg über testing nach stable nehmen.
gruss
gruss
http://www.opsi.org
http://www.opsi.org
hab das experimental installiert, folgende Meldungen wurden ausgegeben:
allerdings läuft der opsicond wieder und ich kann die Leute wieder mit Software versorgen.
Vielen Dank.
schonmal ein schönes WE.
Björn
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Updating : opsiconfd 1/16
/var/tmp/rpm-tmp.8192: line 1: fg: no job control
Error in PREUN scriptlet in rpm package o
Cleanup : opsiconfd 2/16
error: %preun(opsiconfd-4.0-15.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0-15.7.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.1-1.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.2-2.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.3-1.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.3-1.2.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.3-1.5.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.0.3-1.6.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-6.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-7.1.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-8.4.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-8.6.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-8.7.noarch) scriptlet failed, exit status 1
error: %preun(opsiconfd-4.0.1-8.8.noarch) scriptlet failed, exit status 1
Vielen Dank.
Björn
Centos 6
Opsi 4.0.4
Opsi 4.0.4
gibt es schon die Stable Version von dem BugFix?
Gruß und schönes WE
Björn
Gruß und schönes WE
Björn
Centos 6
Opsi 4.0.4
Opsi 4.0.4
