Dear opsi-users,
hereby we release the cofunded extension opsi Nagios Connector as testing.
Therefore this opsi modul can be evaluated from now on.
The opsi Nagios Connector is a substantial extension of the opsi web service that allows to connect the opsi managed windows clients and the opsi server to Nagios/Icinga
monitoring services.
For detailed information look at the opsi-manual-nagios-connector-en.pdf that is also located in testing:
http://download.uib.de/opsi4.0/testing/
If you want to use the opsi Nagios Connector you need an activation file.
For evaluation please contact info@uib.de for a temporary file.
The following opsi packages are released as testing:
opsi packages:
jedit (4.5-3)
swaudit (4.0-14)
opsi-adminutils (4.0.1.24-1)
hwaudit (4.0.4-3)
OS packages:
opsiconfd (4.0.1.11-1)
python-opsi (4.0.1.39-1)
opsi-utils (4.0.1.17-1)
opsi-depotserver (4.0.1.12-1)
Please notice that it may take some time until all OS packages are available on all repository mirrors.
With kind regards,
Birgit Hubal
Changelogs:
swaudit (4.0-14) testing; urgency=low
* workaround for bug#354 (set version to '' if zero) deleted becaus it is fixed
-- detlef oertel <d.oertel@uib.de> Tue, 26 Apr 2012 16:00:00 +0100
swaudit (4.0-13) testing; urgency=low
* set version to '' if zero - workaround for bug#354
-- detlef oertel <d.oertel@uib.de> Tue, 15 Mar 2012 16:00:00 +0100
swaudit (4.0-12) testing; urgency=low
* new property: usekeyfinder to switch off keyfinder call
-- detlef oertel <d.oertel@uib.de> Tue, 29 Nov 2011 16:00:00 +0100
opsi-adminutils (4.0.1.24-1) stable; urgency=low
* try to fix [ 2012031610000012 ] opsi-adminutils webstart funktioniert nicht.
* postinst check if newer configed.jar swingx.jar on server
* winscp 4.3.7
* property javaweb installer or local configed
* swingx.jar
* configed.jar 4.0.1.24
* language selection
* replace %ProgramfilesDir% by %Programfiles32Dir%
- Bardo Wolf <b.wolf@uib.de> 16 Mar 2012
opsi-adminutils (4.0.1.12-4) stable; urgency=low
* corrected linkfolder for opsi-configed
- Rupert Röder <r.roeder@uib.de> 07 Mar 2012
opsi-adminutils (4.0.1.12-3) stable; urgency=low
* putty 0.62
* winscp 4.3.5
- Susanne Ehlers <s.ehlers@uib.de> 13 Dec 2011
opsi-adminutils (4.0.1.12-2) stable; urgency=low
* JXv3.1 replaced by jxplorer-3.2.2-windows-installer.exe
- Bardo Wolf <b.wolf@uib.de> 17 Oct 2011
hwaudit (4.0.4-3) stable; urgency=low
* get timeout from property
* Ticketid 2012021510000025
-- Bardo Wolf <b.wolf@uib.de> 23 Feb 2012
hwaudit (4.0.4-2) stable; urgency=low
opsiconfd (4.0.1.11-1) testing; urgency=low
* first release of opsi-nagios-connector
-- Erol Ueluekmen <e.ueluekmen@uib.de> Sun, 28 Feb 2012 23:37:46 +0100
opsiconfd (4.0.1.10-1) stable; urgency=low
* Require rrdtool-python instead of python-rrdtool on rhel centos and fedora
* opsi message bus
* Create message bus socket dir in init script
* Fix pid file handling
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 19 Jan 2012 14:12:42 +0200
python-opsi (4.0.1.39-1) testing; urgency=low
* opsi-makeproductfile: switch to tar format if source files take
then 2GB of diskusage, to prevent a override of cpio sizelimit.
* 20_legacy.conf: method getProductDependencies_listOfHashes fix.
* fix loosing membership in productGroups when upgrading opsi-packages
* setProductActionRequestWithDepedencies:
Raising exeption if required packages are not available.
* fix setVersion for auditSoftware and auditSoftwareOnClient
software Version 0 will be produce '0' and not ''
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 17 Apr 2012 16:51:08 +0200
python-opsi (4.0.1.38-1) testing; urgency=low
* HostControl-Backend: added hostControl_execute
* 10_opsi.conf: added setProductActionRequestWithDependencies
* Object.py: OpsiDepotserver new default: isMasterDepot=True
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 15 Feb 2012 13:42:37 +0100
python-opsi (4.0.1.37-1) stable; urgency=low
* fix hybi10Decode
-- Jan Schneider <j.schneider@uib.de> Tue, 17 Jan 2012 13:40:01 +0100
opsi-utils (4.0.1.17-1) testing; urgency=low
* opsi-product-updater.conf: added tempdir in general section to
configure the tempdirectory for package installation.
* opsi-product-updater: registering proxy for https source.
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 15 Feb 2012 11:37:32 +0100
opsi-depotserver (4.0.1.12-1) testing; urgency=low
* opsi-setup: fix reading problems with sudoers-file and smb.conf
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 16 Feb 2012 00:48:41 +0100
