opsi and opsi4ucs 4.0.1 updates in stable and testing
News and announcements
ueluekmen
Beitrag von ueluekmen »
Dear opsi-users,
we have released following opsi-OS-packages in stable:
opsi4ucs and opsi4ucs-ldap-schema (4.0.1.8-1)
opsi-utils (4.0.1.15-1)
following opsi-OS-packages in testing:
opsipxeconfd (4.0.1.5-1)
opsi-linux-bootimage (20111114-1)
opsi-configed (4.0.1.17-2)
following opsi-packages in testing:
Windows NT6 products (4.0.1-9) (http://download.uib.de/opsi4.0/testing/)
The opsi-packages were built for the block-alignment issue with opsi-linux-bootimage.
You can turn this feature off per productProperty, default is now using block-alignment.
The new windows-packages have all the requirement to the newest opsi-linux-bootimage released as testing (20111114-1).
regards
E. Ueluekmen
Changelogs:
opsi4ucs (4.0.1.8-1) stable; urgency=low
* 99opsi4ucs.inst: Fix: UCS-Master can be opsi-depotserver and must not be opsi-configserver
* opsi4ucs postinst: Only run 99opsi4ucs.inst when installing package on UCS-Master or UCS-Backup
* opsi-setup: fix init-current-config for executing on OpsiDepotserver
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 21 Oct 2011 11:59:33 +0200
opsi4ucs (4.0.1.7-1) stable; urgency=low
* 99opsi4ucs.inst: Automatic configuration from depot-server for work over jsonrpc
* Added dispatch.conf.jsonrpc
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 14 Oct 2011 15:01:47 +0200
opsi4ucs (4.0.1.6-1) stable; urgency=low
* 99opsi4ucs.inst: Add isMasterDepot Attribute
-- Erol Ueluekmen <e.ueluekmen@uib.de> Sat, 24 Sep 2011 15:49:21 +0200
opsi4ucs (4.0.1.5-1) stable; urgency=low
* Added attribute opsiPcpatchPassword to schema and declared it as MAY in opsiConfigserver class
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 23 Sep 2011 15:49:21 +0200
opsi4ucs (4.0.1.4-1) stable; urgency=low
* cleanup-backend productOnClient fix
-- Erol <e.ueluekmen@uib.de> Fri, 09 Sep 2011 15:26:16 +0200
opsi4ucs (4.0.1.3-1) stable; urgency=low
* Remove attribute opsiPcpatchPassword to schema
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 09 Sep 2011 01:32:10 +0200
opsi4ucs (4.0.1.2-1) stable; urgency=low
* opsi-setup
- cleanup-backend fix: productOnClient and productOnDepot
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 08 Sep 2011 13:52:53 +0200
opsi4ucs (4.0.1.1-1) stable; urgency=low
* opsi-setup:
- add params --backend-config, --update-univention
-- Jan Schneider <j.schneider@uib.de> Tue, 06 Sep 2011 16:16:02 +0200
opsi4ucs (4.0.1-3) stable; urgency=low
* Add attribute opsiPcpatchPassword to schema
-- Jan Schneider <j.schneider@uib.de> Tue, 23 Aug 2011 13:52:44 +0200
opsi4ucs (4.0.1-2) stable; urgency=low
* opsi-setup: fix creation of db user
-- Jan Schneider <j.schneider@uib.de> Tue, 16 Aug 2011 10:35:36 +0200
opsi4ucs (4.0.1-1) stable; urgency=low
* opsi-setup
- --update-ldap fixes for univention
-- Jan Schneider <j.schneider@uib.de> Mon, 15 Aug 2011 14:17:39 +0200
opsi4ucs (4.0-7) stable; urgency=low
* Added objectClass opsiProductGroup in opsi4ucs-ldap-schema
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 07 Dec 2010 16:31:22 +0000
opsi-utils (4.0.1.15-1) stable; urgency=low
* package control-file: opsi-product-updater
- added conflicts, replaces and provides (deb)
* opsi-package-manager: fix for custom installing custom-packages:
- trying to convert custom-package-name to normal package-name
before syncing in opsi-repository on depot-server (option -d)
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 25 Oct 2011 16:48:39 +0200
opsi-linux-bootimage (20111114-1) stable; urgency=low
* kernel 3.1.1
* python-opsi 4.0.1.35-1: createPartitions: Added BlockAlignment support
-- Erol Ueluekmen <e.ueluekmen@uib.de> Mon, 14 Nov 2011 16:01:19 +0100
opsi-linux-bootimage (20111106-1) stable; urgency=low
* kernel 3.0.8
* python-opsi 4.0.1.33-1
-- Erol Ueluekmen <e.ueluekmen@uib.de> Sun, 06 Nov 2011 23:19:17 +0100
opsipxeconfd (4.0.1.5-1) stable; urgency=low
* Fix init-script
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 24 Nov 2011 14:08:54 +0100
opsi-configed (4.0.1.17-2) testing; urgency=low
* For all tabs, a reload context menu is provided
* New commandline option "gzip" for compressed data transfer (per default off)
-- Rupert Roeder <r.roeder@uib.de> Tue, 25 Oct 2011 14:38:32 +0200
opsi-configed (4.0.1.17-1) testing; urgency=low
* New logfile tab "userlogin" (logfile for scripts executed as user login scripts)
* Logfiles are now loaded only if selected
* Logfiles can be reloaded by context menu
* The reload button is splitted into a button for configuration data and a button for license data (for performance reasons)
-- Rupert Roeder <r.roeder@uib.de> Fri, 21 Oct 2011 16:38:32 +0200
