OPSI 4.3 July Release
News and announcements
fkalweit
Beitrag von fkalweit »
Dear opsi community,
we are pleased to announce the official release of the latest version of opsi today.
Important notes:
  • The new opsiconfd no longer accepts the `run-as-user` option in the configuration file and requires newer versions of MariaDB or MySQL.
  • The Python package `opsicommon` has now also been replaced by the new package `opsi` in `opsi-python`, as already done for opsi-cli in the last release.
  • With the new opsi-script, the window of the executing interpreter is no longer just minimized but completely hidden for ExecWith sections and the powershellcall functions.
opsiconfd
The new audit log records authentications, logouts, expired sessions, terminal actions, and product action requests, among other events. It is available via the API and the admin interface. In addition, new filtering, sorting, and configuration options, including the retention period, are now available. The new feature is available now in OPSI Enterprise and OPSI Cloud.
The admin interface has received a redesigned look with an improved header, loading indicators, localized date display, and optimized sorting and filtering.
The maximum number of sessions per IP is now set to `100` by default. Exceptions configured via `max-sessions-excludes` now also support network addresses and domain names.
Keep-alive connections now have a configurable timeout. The default value has been increased from 5 to 30 seconds.
Internal service URLs for Redis, MySQL, and Grafana can now be generated automatically from Docker-like environment variables.
The minimum database requirements have been raised. opsiconfd now requires MariaDB version `10.2` or later, or MySQL version `5.7.8` or later.
The `run-as-user` option is no longer allowed in the configuration file. This setting may now only be set via a command-line parameter or an environment variable.
In addition, the new version includes a number of bug fixes.
opsi-utils
As already done for opsi-cli in the last release, the Python package `opsicommon` has now also been replaced by the new package `opsi` in `opsi-python`.
Scripts that use opsi-python will probably need to be adapted.
The opsi-utils also include the new version of opsi-cli.
opsi-client-agents
Product Cache Soft and Hard Limits
  • Changed product cache size handling from a single fixed limit to separate soft and hard limits.
  • Added `productcachetarget_size`, which defines the preferred cache size. The cache service tries to clean up old, unneeded products to stay near this value.
  • `productcachemax_size` is still treated as the hard limit. The product cache may temporarily grow beyond the target size when needed, but not beyond this maximum.
  • Updated the default product cache target to 10 GB and the hard maximum to 100 GB.
  • Increased the minimum required free disk space for product caching to 10 GB for Windows and 5 GB for Linux and macOS.
  • If a network error occurs while caching a product, the operation is retried up to two times.
opsi-WebGUI
The 4.3.48 release is a major milestone for the opsi-WebGUI. The application has been extensively reworked and modernized, including a complete update of its underlying architecture. This results in a faster, smoother, and more responsive user experience, with significant improvements to usability and accessibility, including enhanced keyboard navigation and better screen reader support.
This release brings a new Dashboard, improved data tables with better filtering and bulk actions, enhancements to groups, improved diagnostics, safer handling of unsaved changes, smarter navigation, and numerous performance, stability, and security improvements.
opsi-configed
  • In tables and lists you can switch to the search bar with CTRL+F
  • You can move clients to other depots with drag & drop
opsi-linux-bootimage
The new opsi-linux-bootimage is based on Ubuntu 26.04 with Linux kernel 7.1.0 and therefore provides improved support for current hardware.
ubuntu26-04
With this release, we are publishing a netboot package for ubuntu26-04. Additionally, the netboot package "ubuntu" and the localboot package "l-debuntu-upgrade" now support ubuntu26-04. In the ubuntu26-04 package, the ProductProperty "desktop_package" has been removed — please use the localboot package "l-desktop" instead.
opsi-cli
Issues in the areas of plugin permissions and session caching have been fixed. Additionally, "client-action set-action-request --where-outdated" is now more efficient and the behavior of "package fetch --properties=keep" has been corrected.
uib Package Subscriptions
As you may know, uib offers update subscriptions for Microsoft patches, standard products, and various individual packages (abo-plus) (see https://opsi.org/en/services/update-subscriptions/). Presumably in Q3 2026, we will restructure the associated repositories for these update subscriptions in order to improve software package delivery performance. In the course of this, it will be necessary to adjust the configuration of the opsi-package-updater. We will send all customers a corresponding configuration file along with instructions prior to the changeover.
Packages for opsi 4.3 stable:
== OPSI_PACKAGE == == SERVER_PACKAGE == == TOOL ==
Your team at uib
nicolaslebrun
Re: OPSI 4.3 July Release
Beitrag von nicolaslebrun »
Hello,
I have a problem with new opsi-client-agent.
It looks like it can't mount the depot anymore.
[code]
[5] [2026-08-04 15:31:10.527] [event processing on_demand ] Mounting depot share smb://opsi0373737a.lyc-maquette-ballan.ac-orleans-tours.fr/opsi_depot (EventProcessing.py:381)
[3] [2026-08-04 15:31:10.546] [event processing on_demand ] Failed to mount depot share: (1312, 'NetUseAdd', 'Une ouverture de session spécifiée n’existe pas. Elle est peut-être déjà terminée.') (EventProcessing.py:452)
[3] [2026-08-04 15:31:10.560] [event processing on_demand ] Failed to process product action requests: (1312, 'NetUseAdd', 'Une ouverture de session spécifiée n’existe pas. Elle est peut-être déjà terminée.') (EventProcessing.py:1021)
File "opsiclientd\EventProcessing.py", line 983, in processProductActionRequests
File "opsiclientd\EventProcessing.py", line 1119, in runActions
File "opsiclientd\EventProcessing.py", line 461, in mountDepotShare
File "opsiclientd\EventProcessing.py", line 441, in mountDepotShare
File "opsi\system\network\_network.py", line 358, in mount_network_share
File "opsi\system\network\_windows.py", line 188, in mount_cifs_share
pywintypes.error: (1312, 'NetUseAdd', 'Une ouverture de session spécifiée n’existe pas. Elle est peut-être déjà terminée.')
[5] [2026-08-04 15:31:13.575] [event processing on_demand ] Shutdown request in Registry: 0 (opsiclientd.py:141)
[/code]
My mistake ?
Regards
Nico
nicolaslebrun
I can confirm that, on the same computer, if I revert to version 4.3.19.11-1 of opsi-client-agent, I have no connexion issue anymore.
Regards,
Nico
Hi Nico,
this might be caused by a recent change to the mounting mechanism of opsiclientd.
Could you please send us an opsiclientd.log file from the version of opsi-client-agent that works, as well as one from the version where the error occurs?
You can send the logs via email to support@uib.de.
Thank you in advance!
Best regards,
Jan
Hi Nico,
would you please test if opsi-client-agent 4.3.23.1-1 fixes the issue?
https://opsipackages.43.opsi.org/experi ... 3.1-1.opsi
Thank you!
Best regards,
Jan
nicolaslebrun
Hallo Jan,
Just tested, no issue anymore with 4.3.23.1 version
Thanks a lot !!!
Regards
Nico
Hi Nico,
thanks for the feedback!
We will release the fixed version soon.
Best regards,
This service release fixes an issue in the opsi-client-agent that caused mounting the depot share to fail in some Windows environments. It also improves the opsi-cli RPC filter handling and updates its python-opsi dependency to fix an SSO login issue on Linux. Additionally, OPSI-WebGUI improves permission handling, restricted depot access, live updates, and updates dependencies to address security vulnerabilities.
== TOOL == == OPSI_PACKAGE == == SERVER_PACKAGE == Your team at uib
