I think I managed to install opsi with no problems thanks to the good installation guide. However when I go to
[url]https://<opsi-server>:4447/configed.jnlp[/url] the file configed.jnlp gets downloaded and then nothing else happens.
Is java supposed to kick in and load this file? Does anyone else had this problem and found a solution?
A bit more information, opsi is installed on Centos 7, that has java version 1.8.
[root@opsi ~]# java -version
openjdk version "1.8.0_111"
OpenJDK Runtime Environment (build 1.8.0_111-b15)
OpenJDK 64-Bit Server VM (build 25.111-b15, mixed mode)
OpenJDK Runtime Environment (build 1.8.0_111-b16)
OpenJDK 64-Bit Server VM (build 25.111-b16, mixed mode)
Many thanks for your help
