[7] [Feb 01 18:20:11] Command 'umount' found at: '/bin/umount' (Posix.py|710)
[6] [Feb 01 18:20:11] Executing: /bin/umount /dev/sda2 (Posix.py|769)
[6] [Feb 01 18:20:11] Using encoding 'ANSI_X3.4-1968' (Posix.py|802)
[7] [Feb 01 18:20:13] Exit code: 0 (Posix.py|853)
[5] [Feb 01 18:20:13] diskcounter is still 0 (setup.py|971)
[7] [Feb 01 18:20:13] Command 'sleep' found at: '/bin/sleep' (Posix.py|710)
[7] [Feb 01 18:20:13] Command 'shutdown' found at: '/sbin/shutdown' (Posix.py|710)
[6] [Feb 01 18:20:13] Executing: /bin/sleep 60; /sbin/shutdown -r now (Posix.py|769)
[7] [Feb 01 18:20:13] Command 'bash' found at: '/bin/bash' (Posix.py|710)
[6] [Feb 01 18:20:13] Executing: /bin/sleep 1 (Posix.py|769)
[7] [Feb 01 18:20:13] Command 'reboot' found at: '/sbin/reboot' (Posix.py|710)
[6] [Feb 01 18:20:13] Executing: /sbin/reboot -p (Posix.py|769)
[5] [Feb 01 18:20:13] Script execution successful (master.py|1466)
[7] [Feb 01 18:20:13] Executing jsonrpc method 'productOnClient_updateObjects' on host u'opsi.gcecad-service.nl' (JSONRPC.py|115)
[7] [Feb 01 18:20:13] Posting request... (JSONRPC.py|713)
[7] [Feb 01 18:20:13] Starting new HTTPS connection (0) to opsi.gcecad-service.nl:4447 (HTTP.py|645)
[7] [Feb 01 18:20:13] Connection established to: opsi.gcecad-service.nl (HTTP.py|647)
[7] [Feb 01 18:20:19] Closing connection: <httplib.HTTPSConnection instance at 0x7f4fdcb44d88> (HTTP.py|565)
[7] [Feb 01 18:20:19] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: deflate (JSONRPC.py|730)
[7] [Feb 01 18:20:19] Expecting deflated data from server (backwards compatible) (JSONRPC.py|738)
[6] [Feb 01 18:20:19] Received signal 1 (master.py|584)
[6] [Feb 01 18:20:19] Received signal 15 (master.py|584)
[5] [Feb 01 18:20:19] Need to terminate (master.py|586)
[6] [Feb 01 18:20:19] Executing: cat /var/tmp/opsi/sysconf.ini (Posix.py|769)
