\\opsi\opsi_depot\opsi-client-agent\files\opsi\setup.opsiscript
around line 398 we can find this:
set $INST_vcredistx86_installed$ = "false"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}] DisplayVersion") = "9.0.30729.4148"
comment "vcredistx86 Version 9.0.30729.4148 is installed"
set $INST_vcredistx86_installed$ = "true"
if GetRegistryStringValue("[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF66E9F6-83E7-3A3E-AF14-8DE9A809A6A4}] DisplayVersion") = "9.0.21022"
comment "vcredistx86 Version 9.0.21022 is installed"
Shouldn't this be updated, and preferably the package itself with the newer version?
Yes, I know you keep the old versions for compability, but is this advice also given when there are security issues with the runtime? Don't know if this is the case with this exact runtime, but anyway.
