[SOLVED]database server separate from app server
denmarknian
Beitrag von denmarknian »
Hi, anyone using opsi with separate physical DB server? Where should i configure it? Thanks in advance
Zuletzt geändert von denmarknian am 11 Dez 2016, 06:24, insgesamt 1-mal geändert.
Re: database server separate from app server
Did you even try to read the manual?
opsi-setup --configure-mysql
denmarknian
Sorry my bad. Thanks anyway
denmarknian
[closed]Re: database server separate from app server
We can close this. thank you.
