Hello,
I want to use different productgroups for different installations. However when i select a productgroup it automaticly goes back to the last used group.
Also selected setup is not allways the same.
Where can i find some documentation over the use of groups?
With regards,
Kees....
Creating a productgroup (SOLVED)
Zuletzt geändert von loggenk am 06 Feb 2017, 12:13, insgesamt 1-mal geändert.
Re: Creating a productgroup
Hi Kees,
sounds like you want to create presets of software that can be assigned to clients.
In order to achieve this, you would create a dummy product, e.g. 00-std-workstations, which has an empty setup script.
Define dependencies, and at the very moment you set this product to 'setup' your dependencies will be resolved and also set to 'setup'.
Be aware of different kinds of dependencies. see http://download.uib.de/opsi4.0/doc/html ... 2981478576
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
