Can anyone tell me if its possible that an Opsi tasks run after the user is logged in?
I need to set something on excisting systems. So that it will be in the current user hive. I know activesetup is possible, but that only runs when you create a new user.
With regards,
Kees...
(SOLVED) Run Opsi tasks when user is logged in
Zuletzt geändert von loggenk am 12 Feb 2016, 07:48, insgesamt 1-mal geändert.
Re: Run Opsi tasks when user is logged in
could you be a little bit more specific about what login and what environment?
Kind regards
Kind regards
Hi Niko,
Sorry.
Okay, its a Windows 7 64-bits. But we also have Windows 10 systems
I need to setup something for all users on the system.
Activesetup only works when creating a new user.
But on the system are at least 4 excisting users.
How can i, lets say change background, for all users on the system.
With regards,
Kees...
Sorry.
With regards,
Kees...
File System or Registry?loggenk hat geschrieben:I need to setup something for all users on the system.
see "AllNtUserProfiles" in https://download.uib.de/opsi4.0/doc/htm ... inst-files
https://download.uib.de/opsi4.0/doc/htm ... -allntuser
That's wrong.loggenk hat geschrieben:Activesetup only works when creating a new user.
https://helgeklein.com/blog/2010/04/act ... explained/
wiki/userspace:active_setup_example
Re: (SOLVED) Run Opsi tasks when user is logged in
Thanks for your reaction.
Forgot about /allusers.. Works great.
I take a look at the User Profile Management
Greetings,
Kees...
Greetings,
Kees...
- SisterOfMercy
Dude... really?loggenk hat geschrieben:Forgot about /allusers.. Works great.
