during the installation of win10-x64 netboot product (version 4.0.6.2-2) there is this error when "setup.py" is running to copy the "winpe" files :
Repository error : Failed to get file info dor '/mnt/opsi/win10-x64/winpe//boot/Fonts/meiryo_boot.ttf': file not found
A similar installation with another server works without problem : the opsi packages are the same, all the files in the "win10-x64" directory are the same (synchronised with "rsync").
The only difference between the two server is the Ubuntu version : 12.04 (which works) vs 14.04
What am I doing wrong ?
Regards.
Error during win10-x64 installation - SOLVED
Zuletzt geändert von bourhis am 28 Jan 2016, 14:46, insgesamt 1-mal geändert.
Re: Error during win10-x64 installation
try opsi-setup --set-rights
correct ownership of files is critical in several cases
HTH
ngbr
HTH
ngbr
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
I do "opsi-setup --set-rights ." : no change...
Regards.
Regards.
you could track it down. you can log on to the client machine running the bootimage with root / linux123 .
verify the path and file availability of your mentioned file. seems like for some reason it is not available from the client.
the depot seems to be successfully mounted.
there is a logfile in /tmp, you could post that here.
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
The last lines of the log file :
<code>
[6] [janv. 27 09:41:41] Transfered 44.84 kByte in 0.00 minutes, average speed was 7278.68 kByte/s (Repository.py|418)
[7] [janv. 27 09:41:41] Length of binary data to download: 46468 bytes (Repository.py|742)
[7] [janv. 27 09:41:41] Transfer in from <open file u'/mnt/opsi/win10-x64/winpe//boot/Fonts/wgl4_boot.ttf', mode 'rb' at 0xb4f2f8b8> to <open file u'/mnt/hd/boot/Fonts/wgl4_boot.ttf', mode 'wb' at 0xb4f2fd30>, dynamic bandwidth False, max bandwidth 0 (Repository.py|366)
[7] [janv. 27 09:41:41] Filesize is: 46468 (Repository.py|377)
[6] [janv. 27 09:41:41] Transfered 45.38 kByte in 0.00 minutes, average speed was 7268.78 kByte/s (Repository.py|418)
[2] [janv. 27 09:41:42] Traceback: (Logger.py|765)
[2] [janv. 27 09:41:42] line 1461 in '<module>' in file '/usr/local/bin/master.py' (Logger.py|765)
[2] [janv. 27 09:41:42] line 725 in '<module>' in file '/tmp/setup.py' (Logger.py|765)
[2] [janv. 27 09:41:42] line 614 in 'copy' in file '/usr/lib/python2.7/dist-packages/OPSI/Util/Repository.py' (Logger.py|765)
[2] [janv. 27 09:41:42] ==>>> Repository error: Failed to get file info for '/mnt/opsi/win10-x64/winpe//boot/Fonts/meiryo_boot.ttf': File not found (master.py|1509)
[7] [janv. 27 09:41:42] Backend: <JSONRPCBackend(host=u'172.18.60.67', deflate=False)> (master.py|1512)
[7] [janv. 27 09:41:42] ProductId: win10-x64 (master.py|1513)
[7] [janv. 27 09:41:42] ClientId: iutgestb110.iutb.univ-brest.fr (master.py|1514)
[7] [janv. 27 09:41:42] ProductOnClient: <ProductOnClient(clientId=u'iutgestb110.iutb.univ-brest.fr', productId=u'win10-x64', installationStatus=u'unknown', actionRequest=u'none')> (master.py|1515)
[6] [janv. 27 09:41:42] Updating productOnClient: {'actionProgress': u'', 'actionResult': u'failed', 'clientId': u'iutgestb110.iutb.univ-brest.fr', 'modificationTime': None, 'actionRequest': u'none', 'targetConfiguration': None, 'productVersion': None, 'productType': u'NetbootProduct', 'type': u'ProductOnClient', 'lastAction': None, 'packageVersion': None, 'actionSequence': None, 'installationStatus': u'unknown', 'productId': u'win10-x64'} (master.py|1526)
[7] [janv. 27 09:41:42] Executing jsonrpc method 'productOnClient_updateObjects' on host 172.18.60.67 (JSONRPC.py|115)
[7] [janv. 27 09:41:42] Posting request... (JSONRPC.py|706)
[7] [janv. 27 09:41:42] Starting new HTTPS connection (0) to 172.18.60.67:4447 (HTTP.py|587)
[7] [janv. 27 09:41:42] Connection established to: 172.18.60.67 (HTTP.py|600)
[7] [janv. 27 09:41:42] Failed to get peer cert: 'NoneType' object has no attribute 'getpeercert' (HTTP.py|191)
[7] [janv. 27 09:41:42] Closing connection: <httplib.HTTPSConnection instance at 0xb4ef418c> (HTTP.py|530)
[7] [janv. 27 09:41:42] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: deflate (JSONRPC.py|723)
[7] [janv. 27 09:41:42] Expecting deflated data from server (backwards compatible) (JSONRPC.py|731)
[5] [janv. 27 09:41:42] Writing log to service (master.py|1536)
</code>
It strange : in the directory /mnt/opsi/win10-x64/winpe/boot/Fonts/ I see only 6 files, but if mount this share on my PC I can see all the files !
Regards.
<code>
</code>
Regards.
Hi bourhis,
indeed, strange !
could you pls post the output of
ls -l /var/lib/opsi/depot/win10-x64
I believe you, don't worry, but I can bother other people only if I can show sth
indeed, strange !
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
excuse me I mean output of
ls -l /var/lib/opsi/depot/win10-x64/winpe/fonts
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
total 13072
-rw-rw---- 1 opsiconfd pcpatch 3694080 juin 17 2015 chs_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 3876772 juin 17 2015 cht_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 1984228 juin 17 2015 jpn_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 2371360 juin 17 2015 kor_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 168212 juin 17 2015 malgun_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 165764 juin 17 2015 malgunn_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 134508 juin 17 2015 meiryo_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 132888 juin 17 2015 meiryon_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 154896 juin 17 2015 msjh_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 152892 juin 17 2015 msjhn_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 146228 juin 17 2015 msyh_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 142124 juin 17 2015 msyhn_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 36020 juin 17 2015 segmono_boot.ttf
-rw-rw---- 1 opsiconfd pcpatch 77088 juin 17 2015 segoen_slboot.ttf
-rw-rw---- 1 opsiconfd pcpatch 77404 juin 17 2015 segoe_slboot.ttf
-rw-rw---- 1 opsiconfd pcpatch 47452 juin 17 2015 wgl4_boot.ttf
N.B. : in my other server there is also these 2 directory without any problem... but it's not exactly the same version of "samba" (due to 2 different version of Ubuntu).
"fonts" seem not useful : perhaps I have made a mistake when I have generated the new winpe with the Windows 10 ADK ?
Regards.
hi Bourhis,
glad things are working
actually, its hard to make errors when creating the winpe there.
the new Samba might be more sensitive.
However, we'll provide more comfortable means to create winpe soon
have a nice day!
have a nice day!
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
