[OPSI4.0.6][WINST] Set_Mozilla_Pref with variable doesn't work ?
nicolaslebrun
Beitrag von nicolaslebrun »
Hello,
We're working at the moment on profiling Firefox...
We have the following line in our code
[PatchTextFile_Set_Mozilla_pref_Pref_chaque_demarrage]
; Page de demarrage par defaut
Set_Mozilla_Pref ("user_pref","browser.startup.homepage", "$WebStartPage$" )
but the variable is not interpreted...
We tried
Set_Mozilla_Pref ("user_pref","browser.startup.homepage", $WebStartPage$ )
and
Set_Mozilla_Pref ("user_pref","browser.startup.homepage", '"'+$WebStartPage$+'"' )
but it's worst...
An y idea to pass a variable to a section PatchTextFile ?
Thks,
Regards,
Nico
holgerv
Re: [OPSI4.0.6][WINST] Set_Mozilla_Pref with variable doesn't work ?
Beitrag von holgerv »
Hi!
Your use of the variable seems to be correct: https://download.uib.de/opsi4.0/doc/htm ... n-sections
Maybe you didn't define (DefVar) or set (Set) the variable correctly?
nicolaslebrun
Hi Holgerv,
Thanks for your reply, but the variable is correctly set...
It's a productproperty we define this way
DefVar $WebStartPage$
Set $WebStartPage$ = GetProductProperty("WebStartPage","https://netocentre.fr/")
For debug, if we make
Pause $WebStartPage$
It's good.
I'm really wondering if it is possible to pass a variable to a PatchTextFile section... :-(
Regards,
Nico
Please post / check the complete script and log
regards,
OPSICONF 2024
https://opsi.org/en/opsiconf/
Basisworkshop Mainz :
17. - 20. 06. 2024
nicolaslebrun
Hi Bardo
Here it is !
(15289)   [5] [nov. 26 11:09:25:418] [opsi-firefox]   getValue("installationstate", getProductMap) = "installed"   <<< result true
(15290)   [5] [nov. 26 11:09:25:418] [opsi-firefox]   not(getValue("installationstate", getProductMap) = "installed")   <<< result false
(15291)   [6] [nov. 26 11:09:25:418] [opsi-firefox] Then
(15292)   [6] [nov. 26 11:09:25:418] [opsi-firefox] EndIf
(15293)   [6] [nov. 26 11:09:25:418] [opsi-firefox] If
(15294)   [5] [nov. 26 11:09:25:461] [opsi-firefox]   scriptWasExecutedBefore   <<< result true
(15295)   [6] [nov. 26 11:09:25:461] [opsi-firefox] Then
(15296)   [5] [nov. 26 11:09:25:461] [opsi-firefox]   comment: Execution des taches a chaque login
(15297)   [5] [nov. 26 11:09:25:461] [opsi-firefox]   message Execution des taches a chaque login
(15298)   [5] [nov. 26 11:09:25:464] [opsi-firefox]
(15299)   [5] [nov. 26 11:09:25:464] [opsi-firefox]   Execution of PatchTextFile_Set_Mozilla_pref_Pref_chaque_demarrage
(15300)   [6] [nov. 26 11:09:25:464] [opsi-firefox]
(15301)   [6] [nov. 26 11:09:25:464] [opsi-firefox]   Patching: C:\Users\gip.prof\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js
(15302)   [5] [nov. 26 11:09:25:464] [opsi-firefox]         FILE C:\Users\gip.prof\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js
(15303)   [6] [nov. 26 11:09:25:466] [opsi-firefox]     Item Pointer set to Top (before first line)
(15304)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     Item no. 0 is starting with 'user_pref("browser.startup.homepage"'
(15305)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     Item Pointer set to 0
(15306)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     Deleted item no. 0: user_pref("browser.startup.homepage", "$WebStartPage$" );
(15307)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     No item found starting with 'user_pref("browser.startup.homepage"'
(15308)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     Item Pointer set to Top (before first line)
(15309)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     Inserted item 'user_pref("browser.startup.homepage", "$WebStartPage$" );' at position 0
(15310)   [6] [nov. 26 11:09:25:467] [opsi-firefox]     C:\Users\gip.prof\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js saved back with 8 Bit system encoding
(15311)   [6] [nov. 26 11:09:25:468] [opsi-firefox] Else
(15312)   [6] [nov. 26 11:09:25:468] [opsi-firefox] EndIf
(15313)   [1] [nov. 26 11:09:25:468] [opsi-firefox] ___________________
(15314)   [1] [nov. 26 11:09:25:468] [opsi-firefox] script finished
(15315)   [1] [nov. 26 11:09:25:468] [opsi-firefox] 0 errors
(15316)   [1] [nov. 26 11:09:25:468] [opsi-firefox] 0 warnings
(15317)   [1] [nov. 26 11:09:25:468] [opsi-firefox]
(15318)   [1] [nov. 26 11:09:25:468] [opsi-firefox] Executed login script for : opsi-firefox Version: 42.0.0.5780-88
(15319)   [1] [nov. 26 11:09:25:468] [opsi-firefox]
And the useful parts of code
PatchTextFile_Set_Mozilla_pref_Pref_chaque_demarrage "%UserProfileDir%\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js"
An idea ?
Thanks,
Regards,
Nico
Hi Nico,
the script is doing what is scripted, patching
but perhaps not doing what you want do...
I dont know where your prefs.js should be.
Maybe an alternative is
- have a deeper look in the opsi.-winst-manuals and opsi extension User Profile Management
- working with a
mozilla.cfg
see http://kb.mozillazine.org/Locking_preferences
- test our Update subscription for the opsi standard packets ...
regards,
bardo wolf
OPSICONF 2024
17. - 20. 06. 2024
nicolaslebrun
Thanks for your reply, Bardo...
May be the way we wan't to manage Firefox profile is not the best one, and i'll see if we can do it another way...
But i disagree with
It does patch the file prefs.js...
But it patches it with the NAME of the variable instead of the VALUE of the variable.
The patched prefs.js file contains
but I want
user_pref("browser.startup.homepage", "https://netocentre.fr" );
as the value of $WebStartPage$ is "https://netocentre.fr"
What am I missing ?
Regards
Nico
mmh,
works for me:
comment "Actions section"
[ProfileActions]
Registry loadunicodetextfile("%SCRIPTPATH%\opsi.org.reg") /regedit /32bit
[4] [Dez 03 14:20:32:389] [test1] Property not existing in GetProductProperty - using default
[6] [Dez 03 14:20:32:389] [test1]   The value of the variable "$WebStartPage$" is now: "https://netocentre.fr/"
[5] [Dez 03 14:20:32:389] [test1]
[5] [Dez 03 14:20:32:389] [test1] Execution of PatchTextFile_Set_Mozilla_pref_Pref_chaque_demarrage
[6] [Dez 03 14:20:32:389] [test1] Patching: C:\Users\wolf\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js
[5] [Dez 03 14:20:32:389] [test1]       FILE C:\Users\wolf\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\prefs.js
[6] [Dez 03 14:20:32:390] [test1]       Info: This file does not exist and will be created
[4] [Dez 03 14:20:32:392] [test1]       Warning: Directory C:\Users\wolf\AppData\Roaming\Mozilla\Firefox\Profiles\Defaut\ did not exist und was created
[6] [Dez 03 14:20:32:392] [test1]   Item Pointer set to Top (before first line)
[6] [Dez 03 14:20:32:393] [test1]   No item found starting with 'user_pref("browser.startup.homepage"'
[6] [Dez 03 14:20:32:393] [test1]   Added item 'user_pref("browser.startup.homepage", "https://netocentre.fr/" );'
and File
exists now
type prefs.js
hope, that helps,
regards,
bardo wolf
OPSICONF 2024
17. - 20. 06. 2024
nicolaslebrun
So, there is a mistake in my code.
I'll double check and come back...
Thanks for the help, Bardo
Regards,
Nico
Don't forget that the browser.startup.homepage needs a different syntax:
defaultPref("browser.startup.homepage", "data:text/plain,browser.startup.homepage=http://www.dilbert.com");
This is a snippet from a firefox prefs.js file, so for OPSI, and your case it will be like this:
user_pref("browser.startup.homepage", "data:text/plain,browser.startup.homepage=https://netocentre.fr" );
Reference: https://mike.kaply.com/2012/08/29/setti ... utoconfig/
