We are having some problems with OPSI since last update.
One of the problems is that when we try to install a product on a client we get this in our error log:
Exception in StartProcess_cp: Failed to execute "P:\pdfcreator\PDFCreator-1_7_3_setup.exe" /SP /VERYSILENT /NORESTART /LOADINF="P:\pdfcreator\pdf.inf" : 5
Another problem is when we try to install a netboot product - when we get to the "startnet.cmd" then we get an "Access is denied" error.
I looked at this post: viewtopic.php?f=7&t=6620
which seems to be the same problem - I havent gotten an answer yet though :-/
I hope you have an idea as to what causes these problems.
If you need info on what version of OPSI we are using then you need to tell me how I can find the version-number, as it is not me who installs the server.
Regards,
Soren
