I try to install "See Electrical Expert" on Windows 7 64 bits : if I am connected with an adminstrative account user and run (via a command line or a batch) :
msiexec /i See_Electrical_Expert_V3R7.msi /passive /log C:\tmp\seeins.txt
But if I do the same thing via OPSI, the installation stop with an error 1720 and this comment in the log file :
MSI (s) (44:F8) [17:08:04:908]: Produit : See Electrical Expert V3R7 -- Erreur 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action CAResolvePathVBScript script error -2147024894, WshShell.RegRead: Impossible d'ouvrir la clé de Registre "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Personal" pour la lecture. Line 3, Column 1,
Could you please suggest something ?
Best regards.
