Problem with opsi-makeproductfile
I've an error message when I try to make the installation package with the command opsi-makeproductfile.
I've already put the script and the .exe file in the CLIENT_DATA folder.
When I launch the command I've this error message:
****@OPSI:/home/opsiproducts/teamviewer$ opsi-makeproductfile
Vérrouillage du paquet
critical: Traceback:
critical: line 386 in '<module>' in file '/usr/bin/opsi-makeproductfile'
critical: line 235 in 'main' in file '/usr/bin/opsi-makeproductfile'
critical: line 109 in 'lockPackage' in file '/usr/bin/opsi-makeproductfile'
critical: line 672 in 'getProduct' in file '/usr/lib/pymodules/python2.7/OPSI/Util/File/Opsi/__init__.py'
critical: line 444 in 'parse' in file '/usr/lib/pymodules/python2.7/OPSI/Util/File/Opsi/__init__.py'
critical: line 292 in 'forceProductVersion' in file '/usr/lib/pymodules/python2.7/OPSI/Types.py'
critical: ==>>> Bad product version: ''
ERROR: Bad product version: ''
I hope anyone could help me.
Best regards
Best regards
Re: Problem with opsi-makeproductfile
Hello nirale33,
please check your control-file - OPSI/control
In the section [Product] you need to set a version - i.e. 1.0.
After that try running opsi-makeproductfile again.
Kind regards
N. Wenselowski
Kind regards
N. Wenselowski
Thx for your reply.
I did not set a version, with just "Version : 1.0" it works perfectly.
My package is now create.
I'll try deploying now.
Thx again
Best regards
Thx again
Best regards
I have now completed all the manipulations of the creation until the package is installed on the server.
But I can't find any option on the interface for installing the package on the posts.
My package is in /home/opsiproducts.
I need to copy the package *.Opsi in another directory to be displayed in the interface?
after packaging the files you need to deploy the package with:
Best regards
Thomas
opsi-package-manager -i /home/opsiproducts/your-product.opsi
Thomas
Thx for your reply.
But now, when I want setup it, swsetup start whan I reboot the computer but my software make a "failled(setup)".
Is there a log file somewhere?
You can find the logs in the tab "Log Files" and then in the tab instlog. You may need to refresh the configed before you can see the recent log.
Best regards,
Thomas
Best regards,
Thomas
- SisterOfMercy
Well.. deploying.. isn't this the procedure to install the package in the opsi repository? Deploying comes after that, right?othiman hat geschrieben:after packaging the files you need to deploy the package with:Code: Alles auswählen
Hello,
yes: first you need to install the produkt on your depot and after that you can deploy it to a client.
If something failes the logfiles - as mentioned above - should give you a hint where to look.
Kind regards
NW
Kind regards
NW
Hi, ppl
I m trying to create a package for google chrome (wiki/userspace:google_chrome) without success. I m having the error above:
"opsi-package-manager -i googlechrome_1.0-1.opsi
Errors occured:
Failure while processing Install of package(s) /home/opsiproducts/googlechrome/googlechrome_1.0-1.opsi on depot 'gfnlinuxubu.domain.local':
[Errno 1] _ssl.c:499: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol"
[Edit]
I changed the port for OPSI server, from 4447 to 4477. Maybe i didnt use the best mode to change that config and opsi-package-manager is using the default port 4447 to do some thing. I run opsi-package-manager with the --log-file option and the line above show my point"
[7] [Jun 06 16:32:51] Starting new HTTPS connection (0) to gfnlinuxubu.domain.local:4447 (HTTP.py|582
so how can i fix all this?
[/Edit]
i dont know where to look to solve. Could you help me.
Thanks!
Errors occured:
[Edit]
[/Edit]
Thanks!
