When I boot my computer on PXE, my Opsi Linux Boot image don't recover the Configuration Server (opsiconfd) automatically (client IP, netmask, domain client, gateway and dns server are getting back automatically).
How can I do that without fill it ?
Thanks.
opsiconfd at pxe boot
Re: opsiconfd at pxe boot
do you use the pxe menu to start the bootimage (instead of setting a netboot product to setup)
you should read this:
http://download.uib.de/opsi4.0/doc/html ... e-dhclient
Does this help ?
regards
Does this help ?
regards
http://www.opsi.org
http://www.opsi.org
Yes I just boot on Pxe Menu. Ok that's why it's not filled in ! Thanks a lot !
