Package Deployment
Michelfdi
Package Deployment
Beitrag von Michelfdi »
My opsi server work with OS deploiement.
When I try to deploy package with Opsi config editor with "fire on demand" opsi-winst run but when they get back the list of package, opsi-winst close.
The script is ok I already try to install with opsi-winst and it's work.
I try to set up swondemand but when I try to connect on https://localhost:4441/swondemand doesn't work.
Thanks, to help me.
Re: Package Deployment
Could you please post the log (c:\tmp\instlog.txt)
Did you read ? :
http://download.uib.de/opsi_stable/doc/ ... -on-demand
regards
http://www.opsi.org
Michelfdi
here the instlog.txt
[1] [févr. 06 16:20:36:628] opsi-winst 4.11.3.3 started at 06/02/2013 15:05:13
[1] [févr. 06 16:20:36:633]
[1] [févr. 06 16:20:36:634] ============ Version 4.11.3.3 WIN32 script "Z:\notepadpp\CLIENT_DATA\setup.ins"
[1] [févr. 06 16:20:36:634]              start: 2013-02-06  16:20:36
[1] [févr. 06 16:20:36:635]              on client named    "DELL-380"
[1] [févr. 06 16:20:36:636]              loggedin user    "Administrateur"
[1] [févr. 06 16:20:36:637]              winst running as    "Administrateur"
[1] [févr. 06 16:20:36:637]              winst running with admin privileges
[1] [févr. 06 16:20:36:638]              winst running in standard script mode
[1] [févr. 06 16:20:36:639] [executing: "C:\Program Files\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"]
[1] [févr. 06 16:20:36:640] system infos:
[1] [févr. 06 16:20:36:642] 78-2B-CB-AB-C2-5B  -  PC hardware address
[1] [févr. 06 16:20:36:644] dell-380  -  IP name
[1] [févr. 06 16:20:36:646] 172.115.2.4  -  IP address
[1] [févr. 06 16:20:36:648] FRA  -  System default locale
[1] [févr. 06 16:20:36:650] MS Windowds 6.1 32 Bit
[1] [févr. 06 16:20:36:651]
[6] [févr. 06 16:20:36:652] Registry key [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion]  opened
[6] [févr. 06 16:20:36:654] Key closed
[6] [févr. 06 16:20:36:722] opsi-winst has version  4.11.3.3, required is : >= 4.10.8.6
[5] [févr. 06 16:20:36:723]
[5] [févr. 06 16:20:36:725] Set  $LogDir$ 		= "C:\tmp"
[6] [févr. 06 16:20:36:727]   The value of the variable "$LogDir$" is now: "C:\tmp"
[5] [févr. 06 16:20:36:728]
[5] [févr. 06 16:20:36:729] Set  $ProductId$       	= "notepad_plusplus"
[6] [févr. 06 16:20:36:731]   The value of the variable "$ProductId$" is now: "notepad_plusplus"
[5] [févr. 06 16:20:36:733]
[5] [févr. 06 16:20:36:734] Set  $MinimumSpace$    	= "30 MB"
[6] [févr. 06 16:20:36:737]   The value of the variable "$MinimumSpace$" is now: "30 MB"
[5] [févr. 06 16:20:36:738]
[5] [févr. 06 16:20:36:740] Set  $InstallDir$      	= "C:\Program Files\Notepad++"
[6] [févr. 06 16:20:36:743]   The value of the variable "$InstallDir$" is now: "C:\Program Files\Notepad++"
[5] [févr. 06 16:20:36:745]
[5] [févr. 06 16:20:36:747] Set  $SetupFile$		= "npp.6.2.3.Installer.exe"
[6] [févr. 06 16:20:36:749]   The value of the variable "$SetupFile$" is now: "npp.6.2.3.Installer.exe"
[5] [févr. 06 16:20:36:751]
[5] [févr. 06 16:20:36:753] Set  $LicenseRequired$ 	= "false"
[6] [févr. 06 16:20:36:756]   The value of the variable "$LicenseRequired$" is now: "false"
[5] [févr. 06 16:20:36:758]
[5] [févr. 06 16:20:36:760] Set  $LicensePool$     	= "p_" + $ProductId$
[6] [févr. 06 16:20:36:763]   The value of the variable "$LicensePool$" is now: "p_notepad_plusplus"
[5] [févr. 06 16:20:36:765]
[5] [févr. 06 16:20:36:767] If
[6] [févr. 06 16:20:36:769]     Free on Disk C:: 237 711 093 760 bytes  This is more than the required amount of 30 000 000 bytes
[5] [févr. 06 16:20:36:771]   HasMinimumSpace ("C:", $MinimumSpace$)   <<< result true
[5] [févr. 06 16:20:36:772]   not(HasMinimumSpace ("C:", $MinimumSpace$))   <<< result false
[5] [févr. 06 16:20:36:774] Then
[5] [févr. 06 16:20:36:776]
[5] [févr. 06 16:20:36:778] Else
[5] [févr. 06 16:20:36:779]   comment: Show product picture
[5] [févr. 06 16:20:36:782]
[5] [févr. 06 16:20:36:784]   If
[6] [févr. 06 16:20:36:785]       Starting query if file exist ...
[5] [févr. 06 16:20:36:788]     FileExists("Z:\notepadpp\CLIENT_DATA\delsub.ins")   <<< result true
[5] [févr. 06 16:20:36:789]   Then
[5] [févr. 06 16:20:36:791]     comment: Start uninstall sub section
[6] [févr. 06 16:20:36:796]
[6] [févr. 06 16:20:36:797]     ~~~~~~~ Start Sub ~~~~~~~  Sub "Z:\notepadpp\CLIENT_DATA\delsub.ins"
[5] [févr. 06 16:20:36:800]
[5] [févr. 06 16:20:36:801]     Set  $UninstallProgram$ = $InstallDir$ + "\uninstall.exe"
[6] [févr. 06 16:20:36:802]       The value of the variable "$UninstallProgram$" is now: "C:\Program Files\Notepad++\uninstall.exe"
[5] [févr. 06 16:20:36:804]     message Uninstalling notepad_plusplus ...
[5] [févr. 06 16:20:36:805]
[5] [févr. 06 16:20:36:806]     If
[6] [févr. 06 16:20:36:808]         Starting query if file exist ...
[5] [févr. 06 16:20:36:809]         "C:\Program Files\Notepad++\uninstall.exe": File Error 3 (Le chemin d’accès spécifié est introuvable.<)
[5] [févr. 06 16:20:36:810]       FileExists($UninstallProgram$)   <<< result false
[5] [févr. 06 16:20:36:811]     Then
[5] [févr. 06 16:20:36:813]     EndIf
[6] [févr. 06 16:20:36:814]     Section ending since next line is starting with "["
[6] [févr. 06 16:20:36:816]
[6] [févr. 06 16:20:36:817]     ~~~~~~~ End Sub   ~~~~~~~  Sub "Z:\notepadpp\CLIENT_DATA\delsub.ins"
[6] [févr. 06 16:20:36:818]
[5] [févr. 06 16:20:36:819]   EndIf
[5] [févr. 06 16:20:36:822]   message Installing notepad_plusplus ...
[5] [févr. 06 16:20:36:824]
[5] [févr. 06 16:20:36:825]   If
[5] [févr. 06 16:20:36:827]     $LicenseRequired$ = "true"   <<< result false
[5] [févr. 06 16:20:36:828]   Then
[5] [févr. 06 16:20:36:829]   EndIf
[5] [févr. 06 16:20:36:832]   comment: Start setup program
[5] [févr. 06 16:20:36:834]
[5] [févr. 06 16:20:36:835]   Execution of Winbatch_install
[6] [févr. 06 16:20:36:838]     Call ""Z:\notepadpp\CLIENT_DATA\setup\npp.6.2.3.Installer.exe" /S"
[6] [févr. 06 16:20:36:839]        Waiting until the called process is finished
[6] [févr. 06 16:20:36:842]     Start process as invoker: Administrateur
[6] [févr. 06 16:20:40:890]     ExitCode 0    Executed process ""Z:\notepadpp\CLIENT_DATA\setup\npp.6.2.3.Installer.exe" /S"
[6] [févr. 06 16:20:40:893]
[6] [févr. 06 16:20:40:894]   ~~~~~~~ Start Sub ~~~~~~~  Sub_check_exitcode
[5] [févr. 06 16:20:40:898]   comment: Test for installation success via exit code
[5] [févr. 06 16:20:40:899]
[5] [févr. 06 16:20:40:901]   Set  $ExitCode$ = getLastExitCode
[6] [févr. 06 16:20:40:903]     The value of the variable "$ExitCode$" is now: "0"
[5] [févr. 06 16:20:40:905]
[5] [févr. 06 16:20:40:907]   If
[5] [févr. 06 16:20:40:909]     $ExitCode$ = "0"   <<< result true
[5] [févr. 06 16:20:40:910]     ($ExitCode$ = "0")   <<< result true
[5] [févr. 06 16:20:40:912]   Then
[5] [févr. 06 16:20:40:913]     comment: Looks good: setup program gives exitcode zero
[5] [févr. 06 16:20:40:914]
[5] [févr. 06 16:20:40:915]   Else
[5] [févr. 06 16:20:40:917]
[5] [févr. 06 16:20:40:918]     If
[5] [févr. 06 16:20:40:919]     Then
[5] [févr. 06 16:20:40:921]
[5] [févr. 06 16:20:40:922]     Else
[5] [févr. 06 16:20:40:923]
[5] [févr. 06 16:20:40:924]       If
[5] [févr. 06 16:20:40:925]       Then
[5] [févr. 06 16:20:40:927]
[5] [févr. 06 16:20:40:928]       Else
[5] [févr. 06 16:20:40:929]
[5] [févr. 06 16:20:40:930]         If
[5] [févr. 06 16:20:40:932]         Then
[5] [févr. 06 16:20:40:933]
[5] [févr. 06 16:20:40:934]         Else
[5] [févr. 06 16:20:40:935]         EndIf
[5] [févr. 06 16:20:40:937]       EndIf
[5] [févr. 06 16:20:40:938]     EndIf
[5] [févr. 06 16:20:40:939]   EndIf
[6] [févr. 06 16:20:40:940]
[6] [févr. 06 16:20:40:941]   ~~~~~~~ End Sub   ~~~~~~~  Sub_check_exitcode
[6] [févr. 06 16:20:40:942]
[5] [févr. 06 16:20:40:943] EndIf
[1] [févr. 06 16:20:40:948] ___________________
[1] [févr. 06 16:20:40:949] script finished
[1] [févr. 06 16:20:40:950] 0 errors
[1] [févr. 06 16:20:40:951] 0 warnings
[1] [févr. 06 16:20:40:952]
[1] [févr. 06 16:20:40:953]
[6] [févr. 06 16:20:40:954] Delete "c:\opsi.org\tmp\_winstbat_*"
[6] [févr. 06 16:20:40:956]   Search "c:\opsi.org\tmp\"
évr. 06 16:20:04:250]
[5] [févr. 06 16:20:04:251]   Else
[5] [févr. 06 16:20:04:252]     comment: Setup program gives a exitcode unequal zero: -1
[5] [févr. 06 16:20:04:253]
[5] [févr. 06 16:20:04:254]     If
[5] [févr. 06 16:20:04:256]       $ExitCode$ = "1605"   <<< result false
[5] [févr. 06 16:20:04:257]       ($ExitCode$ = "1605")   <<< result false
[5] [févr. 06 16:20:04:258]     Then
[5] [févr. 06 16:20:04:259]
[5] [févr. 06 16:20:04:261]     Else
[5] [févr. 06 16:20:04:262]
[5] [févr. 06 16:20:04:263]       If
[5] [févr. 06 16:20:04:264]         $ExitCode$ = "1641"   <<< result false
[5] [févr. 06 16:20:04:266]         ($ExitCode$ = "1641")   <<< result false
[5] [févr. 06 16:20:04:267]       Then
[5] [févr. 06 16:20:04:268]
[5] [févr. 06 16:20:04:269]       Else
[5] [févr. 06 16:20:04:270]
[5] [févr. 06 16:20:04:272]         If
[5] [févr. 06 16:20:04:273]           $ExitCode$ = "3010"   <<< result false
[5] [févr. 06 16:20:04:274]           ($ExitCode$ = "3010")   <<< result false
[5] [févr. 06 16:20:04:275]         Then
[5] [févr. 06 16:20:04:277]
[5] [févr. 06 16:20:04:278]         Else
[3] [févr. 06 16:20:04:279]           Error: Fatal: Setup program gives an unknown exitcode unequal zero: -1
[5] [févr. 06 16:20:04:285]           Error level set to fatal
[5] [févr. 06 16:20:04:287]           Process aborted
[6] [févr. 06 16:20:04:288]
[6] [févr. 06 16:20:04:289]   ~~~~~~~ End Sub   ~~~~~~~  Sub_check_exitcode
[6] [févr. 06 16:20:04:290]
[5] [févr. 06 16:20:04:291]   Process aborted
[1] [févr. 06 16:20:04:295] ___________________
[1] [févr. 06 16:20:04:297] script finished
[1] [févr. 06 16:20:04:298] 2 errors
[1] [févr. 06 16:20:04:299] 11 warnings
[1] [févr. 06 16:20:04:300]
[1] [févr. 06 16:20:04:301]
[6] [févr. 06 16:20:04:302] Delete "c:\opsi.org\tmp\_winstbat_*"
[6] [févr. 06 16:20:04:304]   Search "c:\opsi.org\tmp\"
_architecture$ = "both") or ($INST_architecture$ = "64 only")   <<< result true
[5] [févr. 06 15:35:39:968]       (($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only"))   <<< result true
[5] [févr. 06 15:35:39:969]       ($INST_SystemType$ = "64 Bit System") and (($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only"))   <<< result false
[5] [févr. 06 15:35:39:970]     Then
[5] [févr. 06 15:35:39:972]
[5] [févr. 06 15:35:39:973]       If
[5] [févr. 06 15:35:39:974]       Then
[5] [févr. 06 15:35:39:976]       EndIf
[5] [févr. 06 15:35:39:977]
[5] [févr. 06 15:35:39:978]       If
[5] [févr. 06 15:35:39:979]       Then
[5] [févr. 06 15:35:39:981]       EndIf
[5] [févr. 06 15:35:39:982]     EndIf
[5] [févr. 06 15:35:39:983]     comment: Delete program shortcuts
[5] [févr. 06 15:35:39:985]
[5] [févr. 06 15:35:39:986]     Execution of LinkFolder_uninstall
[6] [févr. 06 15:35:39:987]       Base folder is the COMMON PROGRAMS folder
[6] [févr. 06 15:35:39:989]       Opened "Internet" in the COMMON PROGRAMS folder
[6] [févr. 06 15:35:39:990]         Info: Link "Mozilla Firefox" does not exist
[6] [févr. 06 15:35:39:991]       Folder "Mozilla Firefox" in the COMMON PROGRAMS folder does not exist, nothing to delete
[6] [févr. 06 15:35:39:993]     Section ending since next line is starting with "["
[6] [févr. 06 15:35:39:994]
[6] [févr. 06 15:35:39:995]     ~~~~~~~ End Sub   ~~~~~~~  Sub "Z:\firefox\CLIENT_DATA\delsub.ins"
[6] [févr. 06 15:35:39:996]
[5] [févr. 06 15:35:39:997]   EndIf
[5] [févr. 06 15:35:39:999]
[5] [févr. 06 15:35:40:000]   If
[5] [févr. 06 15:35:40:001]     $LicenseRequired$ = "true"   <<< result false
[5] [févr. 06 15:35:40:002]   Then
[5] [févr. 06 15:35:40:003]   EndIf
[5] [févr. 06 15:35:40:012]   comment: installing
[5] [févr. 06 15:35:40:014]
[5] [févr. 06 15:35:40:015]   If
[5] [févr. 06 15:35:40:016]     $INST_SystemType$ = "x86 System"   <<< result true
[5] [févr. 06 15:35:40:017]     $INST_architecture$ = "system specific"   <<< result true
[5] [févr. 06 15:35:40:018]     ($INST_architecture$ = "system specific")   <<< result true
[5] [févr. 06 15:35:40:019]     ($INST_SystemType$ = "x86 System") and ($INST_architecture$ = "system specific")   <<< result true
[5] [févr. 06 15:35:40:021]     $INST_architecture$ = "both"   <<< result false
[5] [févr. 06 15:35:40:022]     $INST_architecture$ = "32 only"   <<< result false
[5] [févr. 06 15:35:40:023]     ($INST_architecture$ = "32 only")   <<< result false
[5] [févr. 06 15:35:40:024]     ($INST_architecture$ = "both") or ($INST_architecture$ = "32 only")   <<< result false
[5] [févr. 06 15:35:40:025]     (($INST_SystemType$ = "x86 System") and ($INST_architecture$ = "system specific")) or ($INST_architecture$ = "both") or ($INST_architecture$ = "32 only")   <<< result true
[5] [févr. 06 15:35:40:026]   Then
[5] [févr. 06 15:35:40:036]     message Installing firefox 32 Bit...
[5] [févr. 06 15:35:40:045]     comment: Start setup program
[5] [févr. 06 15:35:40:046]
[5] [févr. 06 15:35:40:047]     Execution of Winbatch_install_32
[6] [févr. 06 15:35:40:051]       Call ""Z:\firefox\CLIENT_DATA\files\Firefox Setup 17.0.2esr.exe" -ms -ira"
[6] [févr. 06 15:35:40:052]          Waiting until the called process is finished
[6] [févr. 06 15:35:40:055]       Start process as invoker: Administrateur
[6] [févr. 06 15:35:47:097]       ExitCode 0    Executed process ""Z:\firefox\CLIENT_DATA\files\Firefox Setup 17.0.2esr.exe" -ms -ira"
[6] [févr. 06 15:35:47:100]
[6] [févr. 06 15:35:47:101]     ~~~~~~~ Start Sub ~~~~~~~  Sub_check_exitcode
[5] [févr. 06 15:35:47:104]     comment: Test for installation success via exit code
[5] [févr. 06 15:35:47:106]
[5] [févr. 06 15:35:47:107]     Set  $ExitCode$ = getLastExitCode
[6] [févr. 06 15:35:47:109]       The value of the variable "$ExitCode$" is now: "0"
[5] [févr. 06 15:35:47:111]
[5] [févr. 06 15:35:47:112]     If
[5] [févr. 06 15:35:47:114]       $ExitCode$ = "0"   <<< result true
[5] [févr. 06 15:35:47:116]       ($ExitCode$ = "0")   <<< result true
[5] [févr. 06 15:35:47:117]     Then
[5] [févr. 06 15:35:47:119]       comment: Looks good: setup program gives exitcode zero
[5] [févr. 06 15:35:47:120]
[5] [févr. 06 15:35:47:121]     Else
[5] [févr. 06 15:35:47:122]
[5] [févr. 06 15:35:47:123]       If
[5] [févr. 06 15:35:47:125]       Then
[5] [févr. 06 15:35:47:126]
[5] [févr. 06 15:35:47:127]       Else
[5] [févr. 06 15:35:47:128]
[5] [févr. 06 15:35:47:129]         If
[5] [févr. 06 15:35:47:130]         Then
[5] [févr. 06 15:35:47:131]
[5] [févr. 06 15:35:47:132]         Else
[5] [févr. 06 15:35:47:133]
[5] [févr. 06 15:35:47:134]           If
[5] [févr. 06 15:35:47:135]           Then
[5] [févr. 06 15:35:47:137]
[5] [févr. 06 15:35:47:138]           Else
[5] [févr. 06 15:35:47:139]           EndIf
[5] [févr. 06 15:35:47:140]         EndIf
[5] [févr. 06 15:35:47:141]       EndIf
[5] [févr. 06 15:35:47:142]     EndIf
[6] [févr. 06 15:35:47:143]
[6] [févr. 06 15:35:47:144]     ~~~~~~~ End Sub   ~~~~~~~  Sub_check_exitcode
[6] [févr. 06 15:35:47:145]
[5] [févr. 06 15:35:47:147]     comment: Copy files
[5] [févr. 06 15:35:47:148]
[5] [févr. 06 15:35:47:149]     Execution of Files_install_32
[6] [févr. 06 15:35:47:151]       Copying  C:\Users\Public\Desktop\Mozilla Firefox.lnk -----> C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Internet
[5] [févr. 06 15:35:47:152]         1 File(s) found
[6] [févr. 06 15:35:47:155]         Source C:\Users\Public\Desktop\Mozilla Firefox.lnk
[6] [févr. 06 15:35:47:156]           Info: Target C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Internet\Mozilla Firefox.lnk exists and shall be overwritten
[6] [févr. 06 15:35:47:158]           C:\Users\Public\Desktop\Mozilla Firefox.lnk copied to C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Internet\
[5] [févr. 06 15:35:47:159]         1 File(s) treated
[6] [févr. 06 15:35:47:160]       Copying  C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Mozilla Firefox\Mozilla Firefox.lnk -----> C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Internet
[5] [févr. 06 15:35:47:162]         0 File(s) found
[6] [févr. 06 15:35:47:165]         No (non-directory) file with mask  C:\ProgramData\Microsoft\Windows\Start Menu\Programme\Mozilla Firefox\Mozilla Firefox.lnk  found
[5] [févr. 06 15:35:47:166]         0 File(s) treated
[5] [févr. 06 15:35:47:168]     comment: Patch Registry
[5] [févr. 06 15:35:47:169]
[5] [févr. 06 15:35:47:171]     Warning: The section "Registry_install" (called in line 76 of the calling section) does not exist or is empty
[5] [févr. 06 15:35:47:172]
[4] [févr. 06 15:35:47:173]     Warning: Section  "Registry_install"  does not exist or is empty
[5] [févr. 06 15:35:47:175]     comment: Create shortcuts
[5] [févr. 06 15:35:47:176]
[5] [févr. 06 15:35:47:177]     Execution of LinkFolder_install
[6] [févr. 06 15:35:47:178]       Base folder is the COMMON PROGRAMS folder
[6] [févr. 06 15:35:47:180]       Folder "Mozilla Firefox" in the COMMON PROGRAMS folder does not exist, nothing to delete
[6] [févr. 06 15:35:47:181]       Base folder is the COMMON PROGRAMS folder
[6] [févr. 06 15:35:47:182]       Opened "" in the COMMON PROGRAMS folder
[6] [févr. 06 15:35:47:183]         Link "Mozilla Firefox" deleted
[6] [févr. 06 15:35:47:185]         Base folder is the COMMON DESKTOPDIRECTORY folder
[6] [févr. 06 15:35:47:186]       Opened "" in the COMMON DESKTOPDIRECTORY folder
[6] [févr. 06 15:35:47:187]         Link "Mozilla Firefox" deleted
[5] [févr. 06 15:35:47:189]   EndIf
[5] [févr. 06 15:35:47:190]
[5] [févr. 06 15:35:47:191]   If
[5] [févr. 06 15:35:47:192]     $INST_SystemType$ = "64 Bit System"   <<< result false
[5] [févr. 06 15:35:47:193]     $INST_architecture$ = "system specific"   <<< result true
[5] [févr. 06 15:35:47:194]     $INST_architecture$ = "both"   <<< result false
[5] [févr. 06 15:35:47:196]     $INST_architecture$ = "64 only"   <<< result false
[5] [févr. 06 15:35:47:197]     ($INST_architecture$ = "64 only")   <<< result false
[5] [févr. 06 15:35:47:198]     ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only")   <<< result false
[5] [févr. 06 15:35:47:199]     ($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only")   <<< result true
[5] [févr. 06 15:35:47:200]     (($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only"))   <<< result true
[5] [févr. 06 15:35:47:201]     ($INST_SystemType$ = "64 Bit System") and (($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only"))   <<< result false
[5] [févr. 06 15:35:47:202]   Then
[5] [févr. 06 15:35:47:204]   EndIf
[5] [févr. 06 15:35:47:205] EndIf
[1] [févr. 06 15:35:47:208] ___________________
[1] [févr. 06 15:35:47:209] script finished
[1] [févr. 06 15:35:47:210] 0 errors
[1] [févr. 06 15:35:47:211] 3 warnings
[1] [févr. 06 15:35:47:212]
[1] [févr. 06 15:35:47:213]
[6] [févr. 06 15:35:47:214] Delete "c:\opsi.org\tmp\_winstbat_*"
[6] [févr. 06 15:35:47:215]   Search "c:\opsi.org\tmp\"
When I deploy with opsi config editor the package with "Fire on demand" Opsi agent run on my client but when this windows appear :
Opsi client said "Action manager is stop."
Yes I already read the manual, on my opsi config editor I already change Swondemand.
Thanks all for your help.
Michelfdi
Sorry for double post but I can't post my log files,
I think there are a problem with my client opsi agent and no with opsi winst.
[6] [Feb 07 16:56:48] [ control server                ] Worker <ocdlib.ControlServer.WorkerOpsiclientdJsonRpc instance at 0x03F10A08> started processing   (Worker.pyo|244)
[5] [Feb 07 16:56:48] [ control server                ] New session created   (Session.pyo|179)
[5] [Feb 07 16:56:48] [ control server                ] Authorization request from dell-380.sdc.fdi@172.115.1.40 (application: unknown)   (ControlServer.pyo|144)
[5] [Feb 07 16:56:48] [ event config sync_completed{cache_ready}] -----> Executing: fireEvent(u'on_demand')   (JsonRpc.pyo|123)
[5] [Feb 07 16:56:48] [ opsiclientd                   ] Firing event 'on_demand'   (ControlServer.pyo|498)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Testing preconditions of configs: [<EventConfig: on_demand>, <EventConfig: on_demand{user_logged_in}>]   (Events.pyo|399)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Preconditions {} for event config 'on_demand' fulfilled   (Events.pyo|403)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Preconditions {u'user_logged_in': True} for event config 'on_demand{user_logged_in}' fulfilled   (Events.pyo|403)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Firing event '<ocdlib.Events.CustomEvent object at 0x0401A970>'   (Events.pyo|439)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Event info:   (Events.pyo|440)
[6] [Feb 07 16:56:48] [ event generator on_demand     ] Starting FireEventThread for listeners: [<OpsiclientdNT61(Thread-1, started daemon 1696)>]   (Events.pyo|463)
[6] [Feb 07 16:56:48] [ event generator on_demand{user_logged_in}] Calling processEvent on listener <OpsiclientdNT61(Thread-1, started daemon 1696)>   (Events.pyo|458)
[6] [Feb 07 16:56:48] [ event config sync_completed{cache_ready}] Got result   (JsonRpc.pyo|131)
[5] [Feb 07 16:56:48] [ opsiclientd                   ] Processing event <ocdlib.Events.CustomEvent object at 0x0401A970>   (Opsiclientd.pyo|386)
[6] [Feb 07 16:56:48] [ event processing on_demand{user_logged_in}] Searching pids of process name winlogon.exe (session id: 1)   (Windows.pyo|1215)
[6] [Feb 07 16:56:48] [ event processing on_demand{user_logged_in}] Found process winlogon.exe with matching name (pid 532, session 1)   (Windows.pyo|1237)
[6] [Feb 07 16:56:48] [ event processing on_demand{user_logged_in}] Session id set to 1   (EventProcessing.pyo|175)
[5] [Feb 07 16:56:48] [ event processing on_demand{user_logged_in}] ============= EventProcessingThread for occurrcence of event 'on_demand{user_logged_in}' started =============   (EventProcessing.pyo|1073)
[5] [Feb 07 16:56:48] [ opsiclientd                   ] Block login now set to 'False'   (Opsiclientd.pyo|111)
[5] [Feb 07 16:56:48] [ event processing on_demand{user_logged_in}] Starting notification server on port 44003   (EventProcessing.pyo|196)
[6] [Feb 07 16:56:48] [ opsiclientd                   ] Notification server starting   (Message.pyo|610)
[5] [Feb 07 16:56:49] [ event processing on_demand{user_logged_in}] Notification server started   (EventProcessing.pyo|223)
[6] [Feb 07 16:56:49] [ event processing on_demand{user_logged_in}] Action processor name 'opsi-winst', version '4.11.3.3'   (EventProcessing.pyo|353)
[5] [Feb 07 16:56:49] [ opsiclientd                   ] Block login now set to 'False'   (Opsiclientd.pyo|111)
[5] [Feb 07 16:56:49] [ event processing on_demand{user_logged_in}] Starting notifier application in session '1'   (EventProcessing.pyo|324)
[6] [Feb 07 16:56:49] [ opsiclientd                   ] Searching pids of process name winlogon.exe (session id: 1)   (Windows.pyo|1215)
[6] [Feb 07 16:56:49] [ opsiclientd                   ] Found process winlogon.exe with matching name (pid 532, session 1)   (Windows.pyo|1237)
[5] [Feb 07 16:56:49] [ opsiclientd                   ] Executing: 'C:\Program Files\opsi.org\opsi-client-agent\\opsiclientd_rpc.exe "dell-380.sdc.fdi" "*** confidential ***" "4441" "setCurrentActiveDesktopName("1", System.getActiveDesktopName())"' in session '1' on desktop 'winsta0\winlogon'   (Windows.pyo|1394)
[6] [Feb 07 16:56:49] [ opsiclientd                   ] Process startet, pid: 3632   (Windows.pyo|1397)
[6] [Feb 07 16:56:49] [ opsiclientd                   ] Waiting for process ending: 3632 (timeout: 60 seconds)   (Windows.pyo|1400)
[6] [Feb 07 16:56:50] [ control server                ] Worker <ocdlib.ControlServer.WorkerOpsiclientdJsonRpc instance at 0x03F10350> started processing   (Worker.pyo|244)
[5] [Feb 07 16:56:50] [ control server                ] New session created   (Session.pyo|179)
[5] [Feb 07 16:56:51] [ control server                ] Authorization request from dell-380.sdc.fdi@127.0.0.1 (application: opsi jsonrpc module version 4.0.1)   (ControlServer.pyo|144)
[5] [Feb 07 16:56:51] [ opsiclientd                   ] -----> Executing: backend_getInterface()   (JsonRpc.pyo|123)
[6] [Feb 07 16:56:51] [ opsiclientd                   ] Got result   (JsonRpc.pyo|131)
[6] [Feb 07 16:56:52] [ control server                ] Worker <ocdlib.ControlServer.WorkerOpsiclientdJsonRpc instance at 0x04026558> started processing   (Worker.pyo|244)
[6] [Feb 07 16:56:52] [ control server                ] Reusing session for client '127.0.0.1', application 'opsi jsonrpc module version 4.0.1'   (Worker.pyo|391)
[5] [Feb 07 16:56:52] [ control server                ] Authorization request from dell-380.sdc.fdi@127.0.0.1 (application: opsi jsonrpc module version 4.0.1)   (ControlServer.pyo|144)
[5] [Feb 07 16:56:52] [ opsiclientd                   ] -----> Executing: setCurrentActiveDesktopName(1, u'Default')   (JsonRpc.pyo|123)
[5] [Feb 07 16:56:52] [ opsiclientd                   ] rpc setCurrentActiveDesktopName: current active desktop name for session 1 set to 'Default'   (ControlServer.pyo|517)
[6] [Feb 07 16:56:52] [ opsiclientd                   ] Got result   (JsonRpc.pyo|131)
[6] [Feb 07 16:56:53] [ control server                ] Worker <ocdlib.ControlServer.WorkerOpsiclientdJsonRpc instance at 0x040334B8> started processing   (Worker.pyo|244)
[6] [Feb 07 16:56:53] [ control server                ] Reusing session for client '127.0.0.1', application 'opsi jsonrpc module version 4.0.1'   (Worker.pyo|391)
[5] [Feb 07 16:56:53] [ control server                ] Authorization request from dell-380.sdc.fdi@127.0.0.1 (application: opsi jsonrpc module version 4.0.1)   (ControlServer.pyo|144)
[5] [Feb 07 16:56:53] [ opsiclientd                   ] -----> Executing: backend_exit()   (JsonRpc.pyo|123)
[6] [Feb 07 16:56:53] [ opsiclientd                   ] Got result   (JsonRpc.pyo|131)
[5] [Feb 07 16:56:53] [ opsiclientd                   ] Process 3632 ended with exit code 0   (Windows.pyo|1410)
[6] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Running command C:\Program Files\opsi.org\opsi-client-agent\\notifier.exe -p 44003 -i event -s notifier\\event.ini in session '1' on desktop 'default'   (EventProcessing.pyo|300)
[6] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Searching pids of process name winlogon.exe (session id: 1)   (Windows.pyo|1215)
[6] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Found process winlogon.exe with matching name (pid 532, session 1)   (Windows.pyo|1237)
[5] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Executing: 'C:\Program Files\opsi.org\opsi-client-agent\\notifier.exe -p 44003 -i event -s notifier\\event.ini' in session '1' on desktop 'winsta0\default'   (Windows.pyo|1394)
[6] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Process startet, pid: 2792   (Windows.pyo|1397)
[6] [Feb 07 16:56:53] [ event processing on_demand{user_logged_in}] Session id set to 1   (EventProcessing.pyo|175)
[6] [Feb 07 16:56:53] [ control server                ] client connection made   (Message.pyo|459)
[6] [Feb 07 16:56:56] [ event processing on_demand{user_logged_in}] User is allowed to cancel connection after 30 seconds   (EventProcessing.pyo|133)
[6] [Feb 07 16:56:56] [ event processing on_demand{user_logged_in}] Starting ServiceConnectionThread, timeout is 30 seconds   (OpsiService.pyo|163)
[5] [Feb 07 16:56:56] [ service connection            ] Connecting to config server 'https://172.115.1.40/rpc' #1   (OpsiService.pyo|308)
[5] [Feb 07 16:56:57] [ service connection            ] Disabling mysql backend and license management module: no customer in modules file   (JSONRPC.pyo|506)
[6] [Feb 07 16:56:57] [ service connection            ] <OPSI.Backend.JSONRPC.JSONRPCBackend instance at 0x03E55558>: Connected to service   (JSONRPC.pyo|427)
[5] [Feb 07 16:56:57] [ service connection            ] Connected to config server 'https://172.115.1.40/rpc'   (OpsiService.pyo|329)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Trying to read config from file: 'C:\Program Files\opsi.org\opsi-client-agent\opsiclientd\opsiclientd.conf'   (Config.pyo|270)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed{cache_ready}.reboot   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.log_level   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.wait_for_gui_timeout   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.server_cert_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.opsi_host_key   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.block_login_notifier   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.verify_server_cert   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.locale_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.state_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.verify_server_cert_by_ca   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.log_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.host_id   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.timeline_db   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.log_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value global.base_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_on_demand.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_on_demand.name   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_on_demand.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value opsiclientd_rpc.command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_on_demand{user_logged_in}.shutdown_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_on_demand{user_logged_in}.name   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_software_on_demand.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_software_on_demand.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_net_connection.active   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_net_connection.wql   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_net_connection.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_net_connection.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value cache_service.extension_config_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value cache_service.storage_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value cache_service.product_cache_max_size   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value config_service.url   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value config_service.connection_timeout   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value config_service.user_cancelable_after   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{cache_ready}.use_cached_config   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{cache_ready}.use_cached_products   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{cache_ready}.action_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{cache_ready}.action_user_cancelable   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_warning_repetition_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.cache_products   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_message   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.max_repetitions   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.use_cached_config   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.cache_dynamic_bandwidth   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.block_login   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.cache_max_bandwidth   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.lock_workstation   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_notifier_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_message[fr]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.post_sync_config_to_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.process_shutdown_requests   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_user_cancelable   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.write_log_to_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.get_config_from_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.reboot   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.pre_action_processor_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_processor_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.event_notifier_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_processor_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.notification_delay   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_warning_message   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.post_sync_config_from_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.process_actions   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.sync_config_to_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.update_action_processor   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_processor_timeout   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_warning_message[de]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.update_config_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.event_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_message[de]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.sync_config_from_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.post_action_processor_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.shutdown_warning_message[fr]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.logoff_current_user   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.interval   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.activation_delay   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_user_cancelable   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.use_cached_products   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_default.action_notifier_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_cache_ready.products_cached   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_cache_ready.config_cached   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value notification_server.interface   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value notification_server.popup_port   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value notification_server.start_port   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value notification_server.port   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value control_server.ssl_server_cert_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value control_server.static_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value control_server.ssl_server_key_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value control_server.interface   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value control_server.port   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.process_actions   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.event_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.cache_products   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.sync_config_to_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.sync_config_from_server   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.cache_dynamic_bandwidth   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup.name   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup.block_login   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value opsiclientd_notifier.command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.delete_user   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.filename   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.create_environment   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.create_user   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.local_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.remote_dir   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value action_processor.run_as_user   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.process_actions   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.event_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.get_config_from_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.write_log_to_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_message   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.write_log_to_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.block_login   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.active   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_message[fr]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_processor_timeout   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.process_shutdown_requests   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.update_config_file   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.event_notifier_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_message[de]   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.get_config_from_service   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_processor_command   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.event_notifier_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.action_processor_desktop   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_user_login.update_action_processor   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_user_logged_in.user_logged_in   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{user_logged_in}.shutdown_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{user_logged_in}.name   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_gui_startup{user_logged_in}.block_login   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed{cache_ready_user_logged_in}.shutdown_warning_time   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed{cache_ready_user_logged_in}.reboot   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_sync_completed{cache_ready_user_logged_in}.shutdown_user_cancelable   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value depot_server.url   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value depot_server.username   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value depot_server.drive   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value depot_server.depot_id   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_timer.active   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_timer.interval   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_timer.super   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value event_timer.type   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_cache_ready_user_logged_in.user_logged_in   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_cache_ready_user_logged_in.products_cached   (Config.pyo|197)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Setting config value precondition_cache_ready_user_logged_in.config_cached   (Config.pyo|197)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Config read   (Config.pyo|318)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Getting config from service   (EventProcessing.pyo|244)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Getting config from service   (Config.pyo|465)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.depot.id, values [u'srv-opsi.sdc.fdi']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId software-on-demand.show-details, values [True]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_windows.editable, values [True]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_linux.editable, values [True]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_windows.description, values [u'ping, started in a Windows terminal']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.depot.dynamic, values [False]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.configserver.url, values [u'https://172.115.1.40/rpc']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.productonclient_displayfields_netboot, values [u'actionRequest', u'installationInfo', u'installationStatus', u'productId', u'versionInfo']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId software-on-demand.product-group-ids, values [u'software-on-demand']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId product_sort_algorithm, values [u'algorithm1']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.depot.drive, values [u'z:']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_linux.description, values [u'ping, started in a Linux environment']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId license-management.use, values [False]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.license_inventory_extradisplayfields, values []   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_linux, values [u'xterm +hold -e ping %host%']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId opsi-linux-bootimage.append, values [u'acpi=off', u'irqpoll', u'noapic', u'reboot=b']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId software-on-demand.active, values [True]   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.remote_control.ping_windows, values [u'cmd.exe /c start ping %host%']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.depot.protocol, values [u'cifs']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId clientconfig.windows.domain, values [u'SDC.FDI']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.host_displayfields, values [u'clientConnected', u'clientDescription', u'clientIPAddress', u'clientLastSeen', u'clientName']   (Config.pyo|499)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config state from service: configId configed.productonclient_displayfields_localboot, values [u'actionRequest', u'installationInfo', u'installationStatus', u'productId', u'versionInfo']   (Config.pyo|499)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Got config from service   (Config.pyo|520)
[5] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Reconfiguring event generators   (EventProcessing.pyo|252)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Precondition 'cache_ready' created: {u'products_cached': True, u'config_cached': True}   (Events.pyo|839)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Precondition 'user_logged_in' created: {u'user_logged_in': True}   (Events.pyo|839)
[6] [Feb 07 16:57:01] [ event processing on_demand{user_logged_in}] Precondition 'cache_ready_user_logged_in' created: {u'user_logged_in': True, u'products_cached': True, u'config_cached': True}   (Events.pyo|839)
the instlog.txt you have posted is created by an interactice run:
If the opsi-winst window appears there should be any log. Have also a look at c:\opsi.org\log .
regards
http://www.opsi.org
Zakyl
Beitrag von Zakyl »
Hello,
I had a problem with the swondemand : I needed to reinstall the opsi client agent on computers where swondemand is activate. After that I could reach the swondemand interface from the client. Try it maybe !
Michelfdi
I just reinstall opsi-client and nothing change.
It's normal I haven't acces to https://localhost:4441/ but I have acces to https://localhost:4447/ ?
Infact I install directly in my client with opsit-winst to try if my script work and it's work.
I always have my opsi-winst appears and in c:\opsi.org\log I don't have anything.
Thanks for your help.
Zakyl
Beitrag von Zakyl »
In my case I can access to :
And I can't access to :
Michelfdi
Humm, https://localhost:4447/ is the opsi config editor.
What do you do for swondemand ?
you just change true on software-on-demand.active and software-on-demand.show-details ?
Zakyl
Beitrag von Zakyl »
Yes, like your screenshot ! You just need before to select clients you want to change the settings.
After that, on your client computer, you have the "software on demand" link in your startup menu in opsi.org folder.
